rtificial Geplaatst: 12 september 2009 Delen Geplaatst: 12 september 2009 Inmiddels ook gelekt en te downloaden: http://rapidshare.com/files/279204201/Firmware_AzBox_HD_0.9.3281.zip DB800HD ~ AZBox HD Premium ~ Archsat 3/1 ~ Apple TV2 XBMC Link naar reactie Delen op andere sites Meer opties om te delen...
Jap Geplaatst: 13 september 2009 Delen Geplaatst: 13 september 2009 Voor de volledigheid : Citaat: # FIXED - Records of HD-Channel freezing are all about 10 Seconds. Tone also is less. Often this is also at recording from SD-Channe - When playing contents recorded on movie player, "Unsupported format" popup window is, to infinity - Subtitles are fail on following channels SID 10892Mhz 27,500 TP 4801 V160 A80 / / CANAL + SID 10892Mhz 27,500 TP 4802 V161 A84 / / CANAL + FILM SID 10892Mhz 27,500 TP 4805 V164 A96 / / Ale Kino! - Channel scanning of DVB-T / C NIT is not working - When playing some MOV contents, STB hangs up - SmartCard is sometimes reset - From the EPG pressing OK and then select PLAY to zap to a channel totally block the Azbox (when the program is currentely broadcasting) - In manual time setting, GMT is not effective - Inaccurate synchronization of subtitles on Astara 28.2E - Invalid screen capture on 4:2:2 feeds # ADDED - Added "subtitle off" option in setting - Added "default audio" option in setting - Freesat EPG is supported - Screen capture on movie player - At setting menu, more options for audio are created, like: DTS: PCM <-> RAW AC3: PCM <-> RAW AAC: PCM <-> RAW Others: PCM <-> RAW AZBoxHD : 19.2 - 23.5 - 28.2 (T55) DSR2210 : 19.2 - 28.2 Link naar reactie Delen op andere sites Meer opties om te delen...
Jap Geplaatst: 14 september 2009 Delen Geplaatst: 14 september 2009 Het schijnt dat deze firmware toch officieel is vrijgegeven. - HD opname en timeshift gaat inderdaad weer goed. - EPG play probleem is inderdaad opgelost. - Ik heb wat meer problemen met afspelen van 1080p HD content. Bij bepaalde geluidsporen begint na verloop van tijd het beeld en geluid te stotteren. - Ik heb bij TV kijken een wazig probleem met geluid na reset. Geen geluid bij TV wel bij opnames en Films ??? Nog even uitzoeken hoe, wat en waarom. AZBoxHD : 19.2 - 23.5 - 28.2 (T55) DSR2210 : 19.2 - 28.2 Link naar reactie Delen op andere sites Meer opties om te delen...
johndegr Geplaatst: 15 september 2009 Delen Geplaatst: 15 september 2009 Hoi, Wat Jap schrijft dat HD content goed weergeeft en afspeeld, is dat bij iedereen?Ik vind de beta wederom een verbetering, met name het opnemen, echter HD weergeven en opnemen gaat niet erg lekker, springt uit de codering dus loopt niet verder.Echter niet HD wordt wel goed bij mij opgenomen en afgespeeld. Ook wil de server niet werken MMP. Het menu laat zich niet activeren en de boel loopt vast. groetjes, John Link naar reactie Delen op andere sites Meer opties om te delen...
