Gast Geplaatst: 27 juni 2002 Delen Geplaatst: 27 juni 2002 Hallo satfreek, hier is nu de dvb2000 emu met amon v5.1 (wanissa van amonn)met twee firmware op een eeprom 27sf512 voor irdeto en seca emulatie ,only voor de nokia 9200 of 9500. Of what consists the new hardware change of the Cam for Wanissa: The change on the Cam serves for arranging 2 firmwares on the same eeprom, it is as if we had two Cam in one. The first Cam is the normal Cam erdito that uses the SC erdito to get the Control Word from it and send them to SAS for the descrambling process of the MPEG This version is Amon5.1 that to difference from it's preceding Allsas4.0, have the following advantages: 1.Removed all the non routines that not needed and the firmware have been realized completely in Asm and without the implementation of the second seriale for the use of CamExplorer, therefore it is a lot more fast in the change channel and the communication with the SC. 2.Eliminated the train of impulses on the line Ecm Interrupt produced by the SAS when it passed over the seca or Viace.., therefore less overheating of the chip most precious SAS, temperature almost zero. 3.Eliminated the part that writes in continuation the small eeprom 24c16 that in the preceding versions causes the block of the dispatch of the Ecms to the SC and it was necessary to mend the Cam using the WallBanger with it inserts and the Season unthreads to resuscitate the Cam. 4.It can be used with an any dvb2000, italtel,FTAx.x or other decoders irdeto. Disadvantages: 1.Secondary serial disabled , therefore no CamExplorers. 2.Removed the routine of the ECM_PID hunter that served x the italtel on the providers of Multi Ident fines tip D -, Taq... To use Amon5.1 any change on the Cam is not needed if is not wanted to have also the Wanissa on the same Eprom, eventhough the Wanissa is present however inside the eprom in the case that one should decide to make the change in the future. If instead it is predisposed for the HW change,is necessary to put the Dip Switch in the position number 1, that is the position ALLSAS, see the scheme of the change. Instead The second Cam is the more desired of everybody, it is the mythical Wanissa with all her advantages: 1.No use of SC. 2.Fast in the change channel. 3.Temperature zero on the SAS. 4.To firmware modifiable from DVBK via SCSI or Seriale, also from CamExplorer via RS232 of the same Wanissa. Disadvantages: 1.Being forced to make the change HW on the Cam............ 2.Used only with the DVBKemu. Any other dvb2000, Italtel or other decoders erdito will not work. It works only with the MM9500/9200 DVBKemu. To use the Wanissa is necessary to put the Dip Switch in the position 3, that is Wanissa with SBR. The position 2, Wanissa without SBR not to be ever used, at least for the moment otherwise either the Cam and the Decoder will hang. Groeten <img src="/ubbthreads/images/icons/wink.gif" alt="" /> <img src="/ubbthreads/images/icons/wink.gif" alt="" /> <img src="/ubbthreads/images/icons/wink.gif" alt="" /> <img src="/ubbthreads/images/icons/wink.gif" alt="" /> <img src="/ubbthreads/images/icons/wink.gif" alt="" /> Link naar reactie Delen op andere sites Meer opties om te delen...
