1. put the module in SetTopBox (STB)
STB-CI-Menue: DreamLoad (ready for upload) or:
select "Prepare for loading" and press OK
"YES - Activate loader" and press OK
(now: the old file in the module is deleted)
remove and re-insert the module
Now the module is in upload-mode
2. insert programmer into the module
(green LED = power), connect RS232-cable to PC comport 1 or 2
3. start loader-programm
select comport in menue "Settings"
press connect
4. load file *.mbf by clicking "Program module ..."
select file
upload begin
5. remove and re-insert the module
Groeten
<img src="/ubbthreads/images/icons/grin.gif" alt="" /> <img src="/ubbthreads/images/icons/grin.gif" alt="" /> <img src="/ubbthreads/images/icons/grin.gif" alt="" />
Verwarrend is dat deze beschrijving klopt voor een reeds geladen MM
Heb je een maagdelijk nieuwe dan hoef je niet "prepare for loading"te kiezen.
Kan trouwens ook niet, omdat je deze keuzemogelijkheid niet kunt zien. Wordt pas zichtbaar bij een MM die al geladen is.
Dit ter aanvulling. Het kostte mij nl. ook de nodige tijd voor ik er achter was
bert
The load he program :
1. The load he program after that start
2. Select the Com haven over "Settings" now
3. Make the connection to the module over "Connect"
4. Select modules "a file over" Program
5. The load he program starts now the Upload to the module
6. Module successfully loaded
The load he program ( Download start ) ( Linux load he program )
Loader tip: from You
I wanted to load the G09 into mm, but in mine
Humax 5300 did not get the Programmer operating voltage.
In technibox the cam1 plus functioned it however
by XY Delete the mm:
In order to bring the module back into the Upload mode,
it must get three times a RESET without map.
(receiver on out on out on out on)
Remove software mm:
ton remove software from mm of modules
Instead OF putting your more reciever 3 times off and on isn't it better tons
remove 3 times the mm module(that is working for ME)?
Guidance Nr.1 programming of the mm in a HUMAX by XY
Programming of the mm in a Humax.
1. Reveiver completely attach and switch on
2. Mm without map into upper pit put
3. Menu key on remote control press
4. On ' installation ';OK goes pressing
5. On ' general interface ';OK goes pressing
(announcement on TV:Schlitz 1.Gammacrypt 0.x beta)
6. Mm raus pull
(announcement: Slot 1. CI module is not installed)
7. Mm again put in
(announcement: Slot 1. Gammacrypt 0.x beta)
8. This procedure 3mal repeat
(announcement after the 3ten mark:Schlitz 1.Dream load)
Mm now is in the Progammier mode
9. Programmer into mm are and and over R-S Kabel(kein o-modem) to the PC attach
10.-green LED on the Programmer shines
If the green and the red LED, put then the Programmer in from the mm of rausziehen shine and again.
11-load he program open, interface select, current file (at present version 0.9)anwaehlen, and load he program start.
12. Current version is loaded.
13. Programmer from the mm take.
14. Announcement on TV:Initialisierung
Please INSERT card
15. Smartcard into mm put.
16. Anzeige:Schlitz 1 Gammacrypt 0,9 beta
17. Much fun
sent in of XY
Guidance Nr.2 programming of the mm in a Humax 5600 with the firmware 5100 by Dennis
Vorraussetzungen: PC with WIN98
Nulmodem cable
Receiver
Mm
Mm of firmware
Programmer for mm
Programmer Sofware
1. Receiver switch off
2. Reveiver completely attach (is very important that the LNB is attached)
3. Mm with map into lower pit put
4. Receiver turn on
5 in CI the menu goes (see picture) and the entry "GAMMACRYPT *******" to select
(instead of GAMMACRYPT..... there also something other stehen.(sollte there however Dream load can stands uses please the guidance Nr.1))
6. now go into menu of the mm
7. Select "Prepare for Loading" and confirm
8. Select "YES - Activate more loader"
9. Take your map from the mm
10. Switch the receiver off
11. Switch the receiver on
12. go again into CI the menu
13. nu DREAM LOAD should stand there is that the case does not begin from the front: - ( otherwise far at point 14
14. remains in this menu
1ä. connects the Programmer with your PC (best at COM1)
15b. is the Programmer into mm
16. RED and GREEN shine
17. Programmer rausziehen
18. Programmer clean-put
19. only for GREEN shines
20. Start the program MAGIC of MODULES LOADER
21. select "Connect"
22. the red writing "EMERGENCY CONNECTED" changes after green "CONNECTED"
23. should that do not happen continues to begin still times at point 15b otherwise
24. select "Program of modules."
25. in the new window select your firmware and confirm with opening
26. The software begins to transfer now the firmware (RED shines and GREEN flashes)
27a. the green writing "CONNECTED" changes after "PROGRAMMING"
27b. the bars indicates runs forward
28. and it runs
29. and runs
30. that can last few minutes in no case a something to switch off: -)
31. if the procedure is terminated verschwiendet the bars indicates
32. and the green writing "PROGRAMMING" changes MODULES to "LOADED"
3á. selects now "Disconnect
33b. and the green writing of "MODULES LOADED" change to red "EMERGENCY CONNECTED"
34. pull the Programmer from the mm
35. switch off your receiver
36. put your map into the receiver
37. turn on your receiver
38. go into CI the MENU and please you of your new firmware.
