Overzicht alle huidige (Rebranded) Ipbox modellen / Vizyon HD ontvangers
Inmiddels heeft Vizyon zijn complete HD reeks uitgebracht, zijn allen rebranded Abcom/Ipboxen tegen een lagere prijs.
In een ander topic wordt hier ook al melding van gemaakt, maar toch ff in het juiste forum vermeld.
Hierbij dus het overzicht van alle modellen (ook de voorgaande modellen van Relook/Ipbox:
Mutant200 = IPBox200
Specifications
MPEG-2 PSI, DVB-S, and DVB-SI
Features
Multilingual User Interface
Fast & Easy to use OSD
Set all values for searching programs in one menu page
Satellite List by exclusive RCU button
Subtitle & Teletext (OSD)
Aspect Ratio: 4:3, 16:9
LINUX open source(some parts under the terms of GPL, accordingly expandable)
4,000 Channels Programmable
Powerful Channel Sorting and Grouping
Favorite Channel Lists for TV
Parental Control & Radio and Video Mode
"ETHERNET SUPPORTED"
Improved Features
Powerful IBM Power PC implemented.
Faster CPU performance : 350MIPS(252MHz)
Dolby AC-3 (SPDIF output for High-Fi Audio)
Faster channel change time between different TPs. (less then 1sec)
Improved tuner sensitivity for high quality and better reception.
Additional OSD language available. User friendly larger font size.
Faster response between Remote Control Unit via STB
CubeCaFe250 = IPBox250
Specifications
Features
"ETHERNET SUPPORTED" and external PSTN modem(dial up modem) supported
3.5" HDD or 2.5" HDD possible and inner side of top cover mounted style
CVBS, RGB, YUV, S-video supported
Variable HDD Size is Applicable
Multi TimeShifting Function - Unlimited trick play on any of Real Time Live Programs/ Recording Program/ Playback on Prerecorded Program
Improved Features
CubeCaFePrime = IPBox350
Specifications
Plug & Play tuner(DVB-T, DVB-C, DVB-S) supported
USB 1.1(Host)
MPEG-2 PSI, DVB-S, DVB-T, DVB-C and DVB-SI
Max. 16MB flash memory ( normal 8MB Nor type flash memory + 8MB serial flash memory additionally - Applicant's choice)
"ETHERNET SUPPORTED" and external PSTN MODEM(dial up modem) supported
Web interface, PC editor, Telnet, Samba, FTP, mount manager(CIFS, NFS) supported
Multicast, Unicast, VLC streaming supported.
Improved Features
AC power on/off switch
CubeCaFe400 = Relook400 = IPBox4xx
(IPBox420: 1 x DVB-S support, IPBox422: 2 x DVB-S support)
Advanced Features
LINUX open source (some parts under the terms of GPL, accordingly expandable)
Max. Two Channels Recording and one Prerecorded Program Playback
Enjoy enhanced watching and recording of TV programs
Simultaneous Double Descrambling on Viaccess CAM (Only available on relook-300S, 400S)
Watching 1 Viacess ch. while recording another Viacess ch. with only 1
Viacess CAM. Playback of prerecorded programs without Viacess CAM
Simultaneous Double Descrambling with two kinds of CI CAM except ASTON CAM
Watching 1 scrambled ch. while recording another scrambled ch. by using 2 CAMs Play back of prerecorded programs without CAMs.
Playback without CAMs
Playback on a prerecorded scrambled program without CAM
Almost Unlimited Channel Memory
10,000 channels
Production from 40GB up to 250GB or above
Enhanced Search Channel Option
Search by all satellite
Search by satellite/ network
Search by all TP scanning
Multi Time Shifting Function
Smart EPG
Automatically updates Program Info. EPG shows by all Satellites/ Search programs by Genre on the EPG
Enhanced Recording Plan
Timer setting/ User friendly designed EPG
USB Connection to PC
PC Editor via USB connection(USB 1.1 supported)/ Enhanced program utility
Ethernet port supported such as telnet, FTP, Samba, mount manager, PC editor and etc.
CubeRevo = IPBox9000 = Vizyon Revolution 8000 HD
Features
DVB-S compliant ,DVB-S2, DVB-T, DVB-C supported
Smart tuner supported(Plug & Play)
MPEG-2 MP@HL Video Decoder
MPEG-4 AVC/H.264 HP@L4 Video Decoder
DIVX supported
MP3 decoder
Dolby AC3 downmix decoder
HDMI with HDCP supported
Multi-format Audio Decoder
High Definition and Standard Definition
DVB Common Interface (2 slots) supported
Format resolution: 1080i, 720p, 576p
USB 2.0(Host) supported
USB 1.0(Client) supported
Network Interface Supported( high speed Ethernet)
VFD Display : Capability for display of various information
SCPC and MCPC receivable from C/Ku-band satellites
Channel list editing
Favorite channel list editing
True-color On-Screen Display (OSD)
Full Picture In Graphic (PIG) function
Electronic Program Guide (EPG) for on screen channel information
Subtitle & Teletext supported
Parental lock facility by channel and program event
Silver color and Black color supported
SATA-I(1.5Gbps) supported
Added hardware parts for future use.
S-ATA cable and 3.5" HDD cradle(bracket)
2 x mini PCI socket for several kinds of tuner
2 x smartcard reader
IPTV function to be added.
CubeRevo Mini = IPBox900 = Vizyon Revolution 810 HD
Features
DIVX supported
MP3 decoder
DVB Common Interface (1 slot) supported
External E-SATA interface or internal SATA supported
SATA-I (1.5Gbps) supported
Improved Features
E-SATA cable and 3.5"HDD cradle(bracket)
CubeRevo-3000HDPVR = IPBox910 = Vizyon Revolution 820 HD
Features
LINUX OS (some parts under the terms of GPL, accordingly expandable)
DVB compliant, DVB-S2 with Blind Scan, DVB-S, DVB-T, DVB-C tuner module supported
Smart tuner supported (Plug&Play)
1 X Smartcard reader
DVB Common Interface (2slot) supported
DIVX supported
Dolby digital decoder
MP3 decoder
Format resolution: 1080i, 720p, 576i
USB 2.0(Host) for DiVx, MP3, Photo Album, Video Player
Network Interface Supported (high speed Ethernet)
Multi-point Mount Manager supports to access to various media storages in one or many PCs.
Software update via internet or USB memory stick
External SATA interface supported or internal SATA interface supported with 2.5" HDD bracket
2 channel recording and 1 another channel watching in the TP at the same time
Cuberevo-250HD = IPBox91HD = Vizyon Revolution 800 HD
Features
Plug in and Add on supported
DVB compliant, DVB-S2 with Blind Scan supported or Terrestrial DVB-T tuner supported
1 x Smartcard card reader
USB 2.0(Host) for DiVx, MP3, Photo Album, PVR
TV SCART supported to CVBS only
1 channel recording and 1 another channel watching in the TP at the same time
__________________
VU+ Duo2 met  4x DVB-S2 / 2x Dual DVB-S2 Tuner. Plugin remote channel stream converter
Wavefrontier T90. 6x Google TV Android 4K clients.
