roymar Geplaatst: 6 juni 2010 Geplaatst: 6 juni 2010 Neues VTi "Vu+ Team Image " - V1.2-06.06.2010 Master Enigma 04.06.2010 Driver 04.06.2010 Plugins 06.06.2010 Skins 06.06.2010 Changes: VTi Bootlogos and new Radiomode Logo. Multiple fixes at Imagesources and diffs, link from /usr/keys to /var/keys created and different litlle things in the image. NEW* Vuplus Duo 1. Fix 4:3 video mode problem. 2. Turn off FAN at stadnby mode when there is no channel recording.(Duo only) 3. Fix udev problem. 4. Change mbox-dvb-modules.bb to download driver from vuplus server. ( ** All build trees are being moved to vuplus git server **) 5. Move kernel-module dependency to mbox-dvb-modules.bb from initscripts-mbox_1.0.bb 6. Clean up udev-static-devices 7. Internal test routine is added to e2 8. Fix framerate information(20100603 driver) fixed or changed by VTi TEAM NEW* VTi Panel (Blue Button) - supported languages are Englisch, German, Dutch - short press on blue button opens VTi Panel, longer press opens Pluginmenu - multiple new tools, have a look at the screenshots - Support for USB-Inputdevices like Keyboard/Mouse for several applications which support it, like Webbrowser, external IR-Receiver, (untested!) - Support for Cronjobs (fully supports Cronmanager Plugin from our Feed) - AIO grab renewed - Plugin List doesn't need to be reloaded after installing a plugin - DVD Player: stuttering has been fixed - Rytec EPG integrated Bugfixes: - Generic Enigma2 Unicable Support - Simple Enigma2 EPG-Caching Known Bugs: - No Formatsizeinformation 4:3/16:9, SD/HD and Stationresolution shown in Skins. - The Genuine - and Universal Remotecontrollers are reacting slower. Download in der Database HowTo ---> Flashen per USB Stick Vu+ Duo The New Experience Groeten Roymar Mutant HD2400,Vu+ Duo, Xtrend ET6000, 2x Relook 400s, Skystar2 en Wavefield WV85THDS schotel 1W/5E/9-10E/13E/19.2E/23.5E/28.2E en de satellietmeter Xsarius HD easy
roymar Geplaatst: 6 juni 2010 Auteur Geplaatst: 6 juni 2010 Net wat tests gedaan en de DVD-player werkt inderdaad weer goed. Het enigste waar ik even neit uitkom is dat ik in PLI een map in de opnamelijst had met opname's, maar die map zie ik hier niet terug in de vu+duo, terwijl ik in de timer wel kan verwijzen naar deze map. Heeft iemand hier een oplossing voor?? Gr.Roymar Mutant HD2400,Vu+ Duo, Xtrend ET6000, 2x Relook 400s, Skystar2 en Wavefield WV85THDS schotel 1W/5E/9-10E/13E/19.2E/23.5E/28.2E en de satellietmeter Xsarius HD easy
TheMystery Geplaatst: 6 juni 2010 Geplaatst: 6 juni 2010 Welke versie van de dvd player zit er in dit image? VU+ Duo, ET9200, XP1000, PLI
roymar Geplaatst: 6 juni 2010 Auteur Geplaatst: 6 juni 2010 Geen Idee, geeft hij niet een, maar werkt perfect. Mutant HD2400,Vu+ Duo, Xtrend ET6000, 2x Relook 400s, Skystar2 en Wavefield WV85THDS schotel 1W/5E/9-10E/13E/19.2E/23.5E/28.2E en de satellietmeter Xsarius HD easy
roymar Geplaatst: 6 juni 2010 Auteur Geplaatst: 6 juni 2010 Toch weer terug naar OpenPLI, naar wat aanpassingen, wou VTI niet meer herstarten, en weet niet waarom, en die aparte map is voor mij voorlopig nog even te belangrijk. Ik hoop dat PLI ook snel met een dvd-fix komt, want ik denk dat de drivers voorlopig niks gaan oplossen Mutant HD2400,Vu+ Duo, Xtrend ET6000, 2x Relook 400s, Skystar2 en Wavefield WV85THDS schotel 1W/5E/9-10E/13E/19.2E/23.5E/28.2E en de satellietmeter Xsarius HD easy
Littlesat Geplaatst: 7 juni 2010 Geplaatst: 7 juni 2010 Ik denk dat VTI de versie van de DVD speler heeft teruggedraaid. Als je de oudere versie in PLi installeerd dan werkt het ook... Ergens jammer dat VTI niet open is... Als dat zo was kon iedereen echt zien hoe ze dat gefixt hebben. Binnenkort is bijna alles in MPEG4 bij CanalDigitaal... je SD ontvanger kan dus in de Kliko
hactec Geplaatst: 7 juni 2010 Geplaatst: 7 juni 2010 @Littlesat, is die oude(werkende) versie ergens te vinden ? Kan je eventueel per pm laten weten waar en/of met welke versie de DVD wel werkt.
jex Geplaatst: 7 juni 2010 Geplaatst: 7 juni 2010 Welke oude versie van de DVD player werkt dan? Is het je eigen ervariung dat deze met Pli werkt. Zo ja, waar is deze versie dan te vinden en hoe te installeren. Hulp wordt zeer gewaardeerd:-) groet. Clarke Tech ET 9000 / Visiosat G4 / 42" Panasonic plasma / Synology DS 710+
carlo666 Geplaatst: 8 juni 2010 Geplaatst: 8 juni 2010 Origineel bericht van: jex Welke oude versie van de DVD player werkt dan? Is het je eigen ervariung dat deze met Pli werkt. De oude DVD player werkt met OpenPli. Ik weet niet waar je hem "los" kan vinden. Zelf heb ik een complete backup van mijn VU van 5-4-2010 waar de oude DVD player inzit. VTI 1.2 test ik nu enkele dagen en ook hier werkt de DVD player goed.
ijsblok Geplaatst: 9 juni 2010 Geplaatst: 9 juni 2010 2. Turn off FAN at stadnby mode when there is no channel recording.(Duo only) In eerste instantie was ik hier blij mee, maar ik merk nu toch dat de ontvanger na een nachtje standby best warm wordt (er wordt niks opgenomen verder, dus Hd kan het niet zijn). Ben ik de enige die hier 'last' van heeft? Vu+ Duo / Draaibaar 42e - 45w Topfield 4000PVR / Dragon Cam Fortec Lifetime Ultra
stefan.wolfrum Geplaatst: 9 juni 2010 Geplaatst: 9 juni 2010 kun je dat in een of ander menu aan en uit zetten of is het gewoon zo, net als tevoren hij altijd aan stond? VU+ Ultimo Open PLI 4, astra 19, 23 en 28 met multytenne
ijsblok Geplaatst: 9 juni 2010 Geplaatst: 9 juni 2010 Ik ben het eerlijk gezegd niet tegengekomen in het menu. Dat je dus deze keus zelf kan maken. Zal vanavond nog eens even het menu doorspitten. Was (en ben) namelijk in de veronderstelling dat dit geen keus is en dus gewoon zo is Vu+ Duo / Draaibaar 42e - 45w Topfield 4000PVR / Dragon Cam Fortec Lifetime Ultra
Gast SatMann Geplaatst: 9 juni 2010 Geplaatst: 9 juni 2010 er zou zeker een optie moeten komen op alle software versies vanaf nu. mensen die willen zonder ventilator in standby of met.
Dennis DaMenaCe Geplaatst: 9 juni 2010 Geplaatst: 9 juni 2010 "Turn off LNB power when not in use" Dit is nieuw. Misschien dat hij nu wel cool blijft zonder ventilator als de box uit staat.
ijsblok Geplaatst: 9 juni 2010 Geplaatst: 9 juni 2010 Zou best eens kunnen. Want ik vraag mij af of het voor de levensduur wel goed is als de ontvanger altijd zo warm blijft in standby. Vu+ Duo / Draaibaar 42e - 45w Topfield 4000PVR / Dragon Cam Fortec Lifetime Ultra
