Origineel bericht van: Dennis DaMenaCe
"Turn off LNB power when not in use"
Dit is nieuw. Misschien dat hij nu wel cool blijft zonder ventilator als de box uit staat.
in elk geval blijft de lnb cool :D
VU+ Ultimo Open PLI 4, astra 19, 23 en 28 met multytenne
  • Reacties 35
Laat je dat even weten of die nu cool blijft aan ons. wink
~ VU+ ULTIMO ~ Open pli® 4 ~ HUMAX 5100 ~ Kabelbox ~ TRIAX 78 ~ Astra (19,2) Astra (23,5)
Origineel bericht van: roymar
Neues VTi "Vu+ Team Image " - V1.2-06.06.2010 Master
Enigma 04.06.2010
Driver 04.06.2010
Plugins 06.06.2010
Skins 06.06.2010
Changes: VTi Bootlogos and new Radiomode Logo.
Multiple fixes at Imagesources and diffs, link from /usr/keys to /var/keys created and different litlle things in the image.
NEW* Vuplus Duo
1. Fix 4:3 video mode problem.
2. Turn off FAN at stadnby mode when there is no channel recording.(Duo only)
3. Fix udev problem.
4. Change mbox-dvb-modules.bb to download driver from vuplus server.
( ** All build trees are being moved to vuplus git server **)
5. Move kernel-module dependency to mbox-dvb-modules.bb from initscripts-mbox_1.0.bb
6. Clean up udev-static-devices
7. Internal test routine is added to e2
8. Fix framerate information(20100603 driver)
fixed or changed by VTi TEAM
NEW* VTi Panel (Blue Button)
- supported languages are Englisch, German, Dutch
- short press on blue button opens VTi Panel, longer press opens Pluginmenu
- multiple new tools, have a look at the screenshots
- Support for USB-Inputdevices like Keyboard/Mouse for several applications which support it, like Webbrowser, external IR-Receiver, (untested!)
- Support for Cronjobs (fully supports Cronmanager Plugin from our Feed)
- AIO grab renewed
- Plugin List doesn't need to be reloaded after installing a plugin
- DVD Player: stuttering has been fixed
- Rytec EPG integrated
Bugfixes:
- Generic Enigma2 Unicable Support
- Simple Enigma2 EPG-Caching
Known Bugs:
- No Formatsizeinformation 4:3/16:9, SD/HD and Stationresolution shown in Skins.
- The Genuine - and Universal Remotecontrollers are reacting slower.
Download in der Database
HowTo ---> Flashen per USB Stick
Vu+ Duo The New Experience
Groeten Roymar
wat een heerlijk image van het VTI team
kwam er heden toe om het erop te zetten per usb flash
geen wensen meer alles functioneert PRIMA
op dat klein puntje na:
probeer het en dump niet teveel plugins en skins in je image (elk image)
ciao
We Live And Die
Morcheeba
Er staat iets in over webbrowser. Nu heb ik begrepen dat dat niet werkt in Pli. Werkt het in VTI en heb je er werkelijk iets aan(lees websites fatsoenlijk openen)?
Groeten Thomas
Rule #1 Good computers don't go down.
Rule #2 There is no such thing as a good computer.
Heb nu deze image geinstalleerd en werkt goed. Alleen lopen mp3's niet achter elkaar door. Iemand hetzelfde probleem?
Groeten Thomas
Origineel bericht van: Thomas2000
gebruik eens een usb muis en een usb toetsenbord
zul je zien hoe leuk dat is met VTI
je tweede bericht inzake mp3,
heb je die opgeroepen per mediaplayer? of wat anders
hier speelt het gewoon achter elkaar door
ciao
We Live And Die
Morcheeba
Origineel bericht van: stefan.wolfrum
usb muis en toetsenbord?
hang je dat in de vu+ om te internetten?
wel eens van een pc gehoord? die is daar speciaal voor gemaakt...
ja we hebben natuurlijk een veel betere en snellere oplossing middels de pc
daar heb je volledig gelijk
maar met de webbrowser plugin kun je nu toch heel aardig je VU+ als multimediabox gebruiken
't is omdat Thomas2000 de webbrowser plugin noemde, dat ik erop wijs dat die echt heel leuk werkt met de usb ondersteuning.
ciao
We Live And Die
Morcheeba
Voor de liefhebbers.
VTI1.3 is nu uit met weer wat verbeteringen en de laatste drivers.
Gr.Roymar
Mutant HD2400,Vu+ Duo, Xtrend ET6000, 2x Relook 400s,
Skystar2 en Wavefield  WV85THDS schotel 1W/5E/9-10E/13E/19.2E/23.5E/28.2E en de satellietmeter Xsarius HD easy
Bedankt voor de uitleg.
Ik krijg alleen die browser niet geinstaleerd. Heeft tekort geheugen. Hoe kan ik dat oplossen?
Groeten Thomas
Origineel bericht van: Tonskidutch
ciao
Met de standaard mediaplayer die in het menu zit.
Groeten Thomas
geheugen tekort? (heb 76MB vrij -> telnet commando >df<)
zal wel een massa picons geladen hebben of meerdere skins?
ciao
We Live And Die
Morcheeba
