Sky de nds v13 smardcard start niet met newcs 1.67 wie kan me helpen
Hallo met Ambilight
dit is de melding als ik newcs start en onderaan deze melding heb ik mijn config staan
[root@premiere csserver]# cd /root/csserver
[root@premiere csserver]# ./newcs.i686
This is NewCS 1.67 RC1 [build: 95] - the New CardServer by the Butter-team..
Compiled on Jul 14 2009 at 12:12:45
Reading Config file from /etc/newcs.xml
TCP-log password is disabled!
TCP-log set to advanced mode
level: normal
type: init
output: all
logger config: level 1 type 3 output 255
Console log options: level 1 type 3
logger: no logfile option found, file log disabled
udp log: host 192.168.1.10 port 1000
UDP log options: level 1 type 3
TCP log options: level 1 type 3
[ 08:17:57 ] [ Box detect ] Box type 1 (General Boxtype - Generic)
[ 08:17:57 ] [ Config ] Option <blockc0> for device 0 (Phoenix) not present, defaulting to NO
[ 08:17:57 ] [ Config ] Option <crypto-special> for device 0 (Phoenix) not present, defaulting to NO
[ 08:17:57 ] [ Config ] Option <PTShandshake> for device 0 (Phoenix) not present, defaulting to NO
[ 08:17:57 ] [ Config ] /dev/ttyUSB0 ECM priority: round
[ 08:17:57 ] [ Config ] Option <spider> not present for User: local, defaulting to NO
[ 08:17:57 ] [ EMM Cache ] Initialising dynamic Cache
[ 08:17:57 ] [ ECM Cache ] Initialising dynamic Cache
[ NewCS ] Process ID is: 17487
[ 08:17:57 ] [ Loader ] Starting Telnet on port 3001
[ 08:17:57 ] [ Loader ] Reader type 2 on node /dev/ttyUSB0
[ 08:17:57 ] [ Phoenix ] Opening device /dev/ttyUSB0
[ 08:17:57 ] [ Phoenix ] Setting Parity to: ODD
[ 08:17:57 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 08:17:57 ] [ Phoenix ] Setting Baud to custom 16129
[ 08:17:58 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
[ 08:18:00 ] [ ATR ] T=0 1etu=62.00us Guardtime:15etu WWT:9600etu
[ 08:18:00 ] [ ATR ] Historical bytes: A [b0] [07] i [FF] J P p [00] [00] P 1 [01] [00] [11]
[ 08:18:00 ] [ Loader ] Init NDS card
[ 08:18:00 ] [ Phoenix ] Setting Parity to: ODD
[ 08:18:00 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 08:18:00 ] [ Phoenix ] Setting Baud to custom 16129
[ 08:18:03 ] [ Loader ] Card 0900 on port /dev/ttyUSB0 failed
[ 08:18:03 ] [ Loader ] Starting Newcamd Server on port 10180
[ 08:18:03 ] [ NewCS ] Ready to GO! smile
[root@premiere csserver]# [ 08:18:03 ] [ Newcamd ] Newcamd thread Server started on port 10180
newcamd: main loop
[ 08:18:03 ] [ Loader ] Reinit card with caid 0900
[ 08:18:03 ] [ Loader ] Reader type 2 on node /dev/ttyUSB0
[ 08:18:03 ] [ Phoenix ] Opening device /dev/ttyUSB0
[ 08:18:03 ] [ Newcamd ] recv: error! 88: Socket operation on non-socket
[ 08:18:03 ] [ Phoenix ] Setting Parity to: ODD
[ 08:18:03 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 08:18:03 ] [ Phoenix ] Setting Baud to custom 16129
[ 08:18:04 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
[ 08:18:05 ] [ Loader ] Reset failed ...
[ 08:18:05 ] [ Loader ] Reinit card with caid 0900
[ 08:18:05 ] [ Loader ] Reader type 2 on node /dev/ttyUSB0
[ 08:18:05 ] [ Phoenix ] Opening device /dev/ttyUSB0
[ 08:18:05 ] [ Phoenix ] Setting Parity to: ODD
[ 08:18:05 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 08:18:05 ] [ Phoenix ] Setting Baud to custom 16129
[ 08:18:06 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
[ 08:18:07 ] [ ATR ] T=0 1etu=62.00us Guardtime:15etu WWT:9600etu
[ 08:18:07 ] [ ATR ] Historical bytes: A [b0] [07] i [FF] J P p [00] [00] P 1 [01] [00] [11]
[ 08:18:07 ] [ Loader ] Init NDS card
[ 08:18:07 ] [ Phoenix ] Setting Parity to: ODD
[ 08:18:07 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 08:18:07 ] [ Phoenix ] Setting Baud to custom 16129
hier mijn config ik er een smargo aan hangen
instelling smargo
mode= autoswitch
kernel=dreambox
Tmode=T=1
Egt=0
?xml version="1.0"?>
<newCSconfig>
<readers name="Phoenix">
<device>
<name>Phoenix</name>
<type>phoenix</type>
<mhz>600</mhz>
<node>/dev/ttyUSB0</node>
<parity>odd</parity>
<reset>normal</reset>
<export>Yes</export>
<enabled>Yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<carddetect>yes</carddetect>
<newcamd_port>10180</newcamd_port>
<autosid>Yes</autosid>
<Seca-PPV>no</Seca-PPV>
<priority>round</priority>
</device>
</readers>
<cache>
<emm>10</emm>
<ecm>10</ecm>
</cache>
<debug>
<mode>advanced</mode>
<level>normal</level>
<type>init</type>
<output>all</output>
<udp_host>192.168.1.10</udp_host>
<udp_port>1000</udp_port>
<tcp_port>3001</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>premiere</name>
<deskey>21 16 02 24 55 06 17 08 99 10 11 14 13 14</deskey>
<user>
<name>local</name>
<password>local</password>
<au>on</au>
</user>
</newcamdserver>
</newCSconfig>
Hallo met Ambilight
ik ben er uit de kaart draait met Newcs 1.67 en de Smargo
wat ik gedaan
instelling Smargo
Mode= Autoswitch
Kernel=dreambox
T mode= T=1
EGT=0
Mijn Newcs.xml (dit draai met Linux Sme 7.5 )
Even een vraag voor de kenners als jullie nog Suggesties of verbeteringen zien zo ik het graag willen weten. ik heb mij zelf tot zo ver geholpen ik hoop dat jullie mij kunnen helpen
Groet Ambilight
<?xml version="1.0"?>
<newCSconfig>
<device>
<mhz>600</mhz>
<blockua>Yes</blockua>
<blockga>Yes</blockga># staat normaal op no
<boxkey>00000000</boxkey>
<irdetomode>0</irdetomode>
<PTShandshake>No</PTShandshake>
<carddetect>Yes</carddetect>
<pincode>0000</pincode>
<priority>fifo</priority>
</device>
</readers>
<cache>
<emm>10</emm>
<ecm>10</ecm>
</cache>
<debug>
<type>init</type>
</debug>
<newcamdserver>
<deskey>22 76 22 84 95 76 17 08 09 10 11 18 13 16</deskey>
<user>
<name>local</name>
<au>on</au>
</user>
</newcamdserver>
</newCSconfig>
