Gast Geplaatst: 2 augustus 2002 Delen Geplaatst: 2 augustus 2002 i`ve got dutch pace dvr501 g4 from canal+ (thats really old stuff) do you know what i can do with software there is L9 i was trying to change that software but result is E11, i found also italian soft (probably) and i had uploading about 10 sec then E3. please i need to do it for my friend, is it possible? i count on you Link naar reactie Delen op andere sites Meer opties om te delen...
Snurker Geplaatst: 3 augustus 2002 Delen Geplaatst: 3 augustus 2002 Hello over there, Do you see the codes in the display or on the screen ??? Most of the times the cause of this is a download time problem, I think you uses a to quick PC...Just try another..(Old One) Good Luck Snurker ( A man who sleeps with a lot of nose sound ) [color:"green"] [/color] ( Straks zijn meer behangers nodig om OLED schermen tegen de wand te plakken) Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 3 augustus 2002 Delen Geplaatst: 3 augustus 2002 i was trying on pIII450 and p166 same result information "IRD status" IRD CA Module Smart Card ok ok ERROR current service S0 E04 plase insert smart card (i did not put any card in) IRD:2.14.2 Firmware: 1.1 Loader 1.8 7:0:9:OK Softwarev1.3.06a MSB 01/12/97 (L-9) CA Module: V1.10c Smartcard: None PLEASE !!!! HELP ME !!! Link naar reactie Delen op andere sites Meer opties om te delen...
Snurker Geplaatst: 4 augustus 2002 Delen Geplaatst: 4 augustus 2002 Hello Mario, Software for G4 must be P136X009.S0E You can try to receive the FTA Dutch channel BVN 12574 H 5/6 22000 This channel works also without Card and without Cam-Unit When it's works you don't need another Eprom loading ( 1.306a ) is the latest But you need the Kit16 Irdeto files for you Goldcard or 24C16 and Pic 16F84 card As long Canal + sends in Irdeto you see freely their nice movies. When you rebuild the Cam to Seca it will be more difficult and every month change of the Seca key's and you will also need a Funcard. So far enough stuff See you Snurker goes to sleep again....gr gr gr gr grrr ( Straks zijn meer behangers nodig om OLED schermen tegen de wand te plakken) Link naar reactie Delen op andere sites Meer opties om te delen...
Snurker Geplaatst: 7 augustus 2002 Delen Geplaatst: 7 augustus 2002 Hé Mario, Where are you and how is the little Pace baby ?? When we are helping someone...so I also interesting in the project See you Snurker ( Straks zijn meer behangers nodig om OLED schermen tegen de wand te plakken) Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 16 augustus 2002 Delen Geplaatst: 16 augustus 2002 hi my pace 500 g4, do not accept the rebuild ca-modul, alsas 4.1 it works on nokia 9200 with a original cam, i watch all the iderto but not the seca channels bj Link naar reactie Delen op andere sites Meer opties om te delen...
jeveha Geplaatst: 17 augustus 2002 Delen Geplaatst: 17 augustus 2002 Hi, You must put Allsas4.4 in the eprom,otherwise it won't work. best regards, jeveha LG 77G1 RLA oled tv, Gigablue UHD QUAD 4K Mut@nt HD51, ZgemmaH2H, Dreambox7025+, dreambox7020,VU+duo Triax 88cm met 4 twin lnb's, Echostar 1mtr draaibaar, Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 17 augustus 2002 Delen Geplaatst: 17 augustus 2002 hi thank's i will do then send you a confirmation, when it's done regards Bjorn Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 18 augustus 2002 Delen Geplaatst: 18 augustus 2002 hi when i unzipped my alsas 4.4 the txt-file said : alsas 4.3 - anybody have the original 4.4 please emailme Bj. Link naar reactie Delen op andere sites Meer opties om te delen...
Snurker Geplaatst: 18 augustus 2002 Delen Geplaatst: 18 augustus 2002 I also read your e-mail adress in my mailbox, so I will send you the Amon 4.4 for the Pace/Echostar/Nokia Cam. But on this very moment there are problems to decode the Seca Canal+ movie channels...on the Pace only. You can only receive the Seca Eurosport/ Animal Planet/ Nat.Geogr./ TCM / Cartoon and Discovery with a Funcard with Pacefiles on it. Snurker ( Straks zijn meer behangers nodig om OLED schermen tegen de wand te plakken) Link naar reactie Delen op andere sites Meer opties om te delen...
