12345hazekamp Geplaatst: 22 september 2010 Delen Geplaatst: 22 september 2010 hierbij weer een nieuwe linux ontvanger gezien op een_of_andere_website het gaat om een hd ontvanger van het merk skybox s9 zie hier de technische gegevens. prijs 125 euro FUNCTION: FTA+USB+PVR+MULTI CAS+CI+LAN (CCCAMD, NEW CAMD,MG CAMD EMBEDDED) •Fully MPEG-4 H.264/AVC •Main Profile Level 3 & High Profile Level 4.1 Complaint. •Fully MEPG-2 MP@HL & MP@ML;MPEG-1 Layer Dolby Audio (AC3) Compliant. •SCPC & MCPC Receivable from C/KU Band. •DiSEqC1.0/1.1/unicable/1.2/1.3 (USALS) Supported. •NIT Search, MPEG-5, HDMI1.3 Supported. •PVR (External USB), EPG for 7 Days Supported. •Multi-lingual DVB Subtitle and Teletext supported. •Teletext and Subtitle Out Through OSD. •Multimedia Files Playback (by USB). •Automatic and Manual Channel Scan Options. •Multi-lingual on Screen Menu Supported (English, French, Dutch, Deutsch, Italian, Spanish, Swedish, Danisch, Greece, Potuguese, Finland, Turkish, Czech, .. •Multiple Display Mode: 1080i/720p/570p/576i/480p •MPEG-2/H.264 Hardware Decoding, Videotext Decoder. Full Specifications Acessories Main board (DB-M3602-02V01) ALi 48 Keys IR Controller USB HDD Box (optional) Board Configuration 396MHz MIPS CPU 128MB DDR400 RAM Memory clock 198MHz 2MB Serial Flash Single Tuner DVB-S2 demodulator Linux OS Power Supply Input 100V ~ 240V 50/60Hz Power Consumption 30W max / 1W standby RS232 FW upgrade only Standard Receiver DVB-S2 (ETSI EN 302 307) Input Frequency Range 950MHz ~ 2150MHz Impedance: 75Ohm Input Signal Level -25dBm ~ -65dBm Demodulation QPSK, 8PSK, 16APSK Transport Stream MPEG2 ISO/IEC 13818 Teletext ETS 300 472 Standard MPEG Profile Level MPEG2 SD & MPEG2 HD H.264/AVC SD & H.264/AVC HD Dolby Digital Audio(AC3) H.246 LNB Power & Polarisation Vertical: + 13.5V Horizontal: + 18V Current: max 500mA Multi satellite receiver 22k switcher DISEqC1.0, DISEqC1.1 & DISEqC1.2 Unicable, USAL Automatic and manual channel scan options Conditional Access System 1 * common interface slot 1 * CA card reader slot A/V Output ports YPrPb RCA with CVBS SCART with CVBS HDMI 1.3 (HDCP) RCA analog audio (R/L) Digital audio (coaxial or fiber) S-PDIF Digital Output Output Level 0,5 Vss on 75 Ohm Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz S/PDIF-Output optical Aspect Ratio Auto 16:9 pillar box 4:3 pan & scan 4:3 letter box 1080i/720p/570p/576i/480p Audio Decoding MPEG1 layer I, II & III MPEG2 AC3 Audio Mode Stereo / Mono / Left / Right Digital Video Recording (DVR) USB external HDD (optional) Internal flash disk (limited capacity) Timeshifting USB2.0 High Speed Host 1 * USB2.0 port Media player (lnternal flash disk, external USB HDD, USB card reader with memory card) Firmware upgrade File System FAT12, FAT16, FAT32 NTFS (first partition only) Media Supported JPG, BMP, MP3, WMA Ethernet Interface 10/100Mbit Physical specification Ambient Temperature +15 °C...+35 °C Humidity < 80% Size (W x D x H): 300 mm x 220 mm x 56 mm Weight: 1,8 kg without HDD Miscellaneous Support Electronic Program Guide(EPG) for 7 days; Teletext and subtitle out through OSD; Support multi-lingual DVB subtitle and teletext; LED Display Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, etc. SKYBOX S9 HD PVR RECEIVER DVB-S2 CCCAM Objectnummer: 280562266471 Link naar reactie Delen op andere sites Meer opties om te delen...
M_Z Geplaatst: 22 september 2010 Delen Geplaatst: 22 september 2010 Ik betwijfel of dit een Linux ontvanger is, zeker geen open source, het is weer een Ali-M3602 ontvanger die aan dit lijstje kan worden toegevoegd: Chip ALi-M3602 HD (4Mb) HD 35004-01001 = Smart MX04 HDFTA [HDTV][HDMI][uSB] 35004-01001 = Smart MX04 HDCI [HDTV][CI-Slot][HDMI][uSB] 35004-01001 = Smart MX04 HDCA [HDTV][HDMI][uSB][CR] 35004-01021 = SatElita 2000HD [HDTV][CI-Slot][HDMI][uSB][CR][VFD][LAN] 35004-01029 = VIZYON 10000 HD [HDTV][CI-Slot][HDMI][uSB][CR][VFD][LAN] 35004-01034 = Seoul Hiremco X3 Turbo HD [HDTV][CI-Slot][HDMI][uSB][CR][VFD][LAN] 35004-01047 = Ferguson Ariva 200 [HDTV][CI-Slot][HDMI][uSB][CR] [VFD][LAN] 35004-01047 = Ferguson Ariva 100 [HDTV][HDMI][uSB][CR][LAN] 35004-01048 = Megasat HD 800 HDTV [HDTV][CI-Slot][HDMI][uSB][CR][VFD][LAN] 35004-04002 = Lexuz Box F90HD PVR [HDTV][HDMI][uSB][CR][VFD][LAN] 35004-04002 = Az-America S900HD [HDTV][HDMI][uSB][CR][VFD][LAN] Ze maken er zo'n 32000 stuks per week van, en bij een minimum aankoop van 1000 stuks kun je je eigen naam erop laten zetten. Prijs ligt dan rond de 36 USD per stuk (zonder invoerrechten en verzending uiteraard). M_Z Link naar reactie Delen op andere sites Meer opties om te delen...
riaad Geplaatst: 24 september 2010 Delen Geplaatst: 24 september 2010 Ik heb er een paar besteld en ontvangen Prijs 85 USD, verzending 15 USD, geen invoerrechten of BTW Moet zeggen loopt stabiel Beeldkwaliteit is goed maar ik ken betere CCcam is simpel en stabiel Zappen is best snel Helaas geen mogelijkheid om met een NAS te verbinden Heeft beperking van max. 5.000 zenders Software ontvanger is niet open source Conclusie van korte test: Ideale ontvanger voor de slaapkamer Link naar reactie Delen op andere sites Meer opties om te delen...
Mumzel Geplaatst: 30 september 2010 Delen Geplaatst: 30 september 2010 zou je mij via pm kunnen vertellen waar te bestellen, zoek nl. voor de kinderslaapkamer een ontvanger. mvg mumzel Als je geen vergissingen maakt, ben je (waarschijnlijk) al dood !Waarschijnlijk kan wel weg , je krijgt gewoon strafpunten hier. Link naar reactie Delen op andere sites Meer opties om te delen...
Franck Geplaatst: 7 oktober 2010 Delen Geplaatst: 7 oktober 2010 Weet iemand waar ik nieuwe settingslijst vandaan kan halen? Alvast bedankt. Xtrend ET9500 DVB-S2/C (500 Gb HDD & open Pli 4.0), Scientific Atlanta D9232 IRD op draaibare Wavefield WV100SHDS offset, MTI High Line Pro Single LNB, Amiko DM3800 positioner, Cisco D9865H op Selfsat H21D, Roku 2400x USTVNOW, Amazon Fire TV Kodi, Panasonic TX-P42G20E en LG 42LB630V, beide CI+ (Smit) Link naar reactie Delen op andere sites Meer opties om te delen...
