Heeft iemand ervaring met de Target DVB en Multidec (met common interface)?
Ik heb wel wat specs kunnen vinden :
PC DIGITAL SATELLITE TV CARD W/COMMON INTERFACE
KEY FEATURES
DVB Protocol support.
Common Interface (DVB EN50221).
PCMCIA Interface.
Support DVB Data Broadcasting (ETSI301 192).
Support MPTE (multiprotocol encapsulation.
Digital Satellite TV and Radio Program Receiving.
Real time Digital Video Recording (DVR) and Scheduling Recording.
Time-shifting/Preset Time-Shifting.
Electronic Program Guide (EPG).
Still Frame Capture.
Multi-Channel Preview.
Channel, Transponder, Satellite Auto Scan.
Viewing and Recording Different Channels simultaneously.
MPEG-II Software Decoding.
Software Upgradable.
Video Quality Adjustment.
Favorite List.
Teletext.
SYSTEM REQUIREMENTS
Windows 98SE/ME/2000/XP or Linux series or WinCE.
500MHz CPU or above.
128M RAM or above.
VGA Card with at least 8Mb Memory.
Sound Card.
Microsoft Direct X 7.0 or above.
Digital Satellite Dish & LNB.
TUNER
Input terminal: F-type 75 Ohm.
Receiving frequency: 950 ~ 2150MHz tuning range.
Input level: -65~25dbm.
QPSK & FEC
Symbol rate: 2 ~ 45Msps.
QPSK filter: Root-raised cosine filter with roll-off 0.35.
Viterbi decoding: 1/2, 2/3, 3/4, 5/6, 7/8 and Auto.
LNB & Switch control
LNB supply voltage: 13 or 18V.
DiSEqC: 1.0.
Support Data Brust & Tone Brust.
Antenna and LNB control: 22KHz tone.
Max LNB supply current: 400MA with short circuit and surge protection.
PCI Interface
PCI bus: PCI 2.2 compliant.
Host bus burst rate: 132MB/s.
Host bus width: 32bit.
Demultiplexing
Max.no. Section filtering: 32PIDs.
Engine: Software.
Descarambler: DVB descrambler.
Streams capture: PES and TS.
Syntax Error: CRC or Parity.
A/V Format
Video format: MPEG-II Main Profile & Main Level.
Audio format: MPEG-II Audio layer I & II. br>
Above specifications are subject to change without prior notice.
Aan de hand van deze specs kan je niet weten of de kaart met multidec werkt, dit kan je enkel zien aan de gebruikte chip. De kaart moet gebaseerd zijn op de SAA-7146 maar ik vrees dat jou kaart een buitenbeentje is.
Als je meer info wenst moet je de site van happysat eens bekijken, dit is DE referentie voor DVB zoals duwgati dat voor satinfo is.
Wat je via internet niet vindt hoef je meestal niet verder te zoeken.
Kathrein UFS-910 (AAF2.0e/E2 versies) +WiFi +sataHD & Multytenne Twin
Samsung LE46A552: 46" Full HD.
