Iemand dit aan de loop?
Heb al meerdere versies getest, kaart wordt wel herkend en geeft ook ecm en emm maar geen beeld?
Getest zover:
2.0.9 - 2.1.1 - 2.1.4 - 2.2.1
Ook die camdata en camkey
16:24:49.317 CCcam: starting CCcam 2.1.1 compiled on Apr 30 2009@23:37:01
16:24:49.318 CCcam: ======================================================================
16:24:49.319 CCcam: online using nodeId e45dcbf3b347cc14
16:24:49.329 CCcam: dvb api1 detected
16:24:49.332 CCcam: DM56xx/500/600 detected
16:24:49.332 CCcam: create 2 cam device(s)
16:24:49.584 CCcam: /dev/sci0 configured clock frequency: 6000000 Hz
16:24:49.596 CCcam: irdeto card found
16:24:50.679 CCcam: card added to broker with caid 612
16:24:50.680 CCcam: readKeyfile: cannot open /var/keys/SoftCam.Key or not found
16:24:50.680 CCcam: readKeyfile: cannot open /var/keys/AutoRoll.Key or not found
16:24:50.681 CCcam: static cw not found or bad
16:24:50.681 CCcam: parsed 0 entries from /var/etc/CCcam.prio
16:24:50.682 CCcam: readProviderfile: cannot open /var/etc/CCcam.providers or not found
16:24:50.682 CCcam: readChannelList: cannot open /var/etc/CCcam.channelinfo or not found
16:24:50.683 CCcam: server started on port 12000
16:24:50.691 CCcam: found irdeto caid: 0x612 ecmpid: 0x44f id: 0x0
16:24:50.692 CCcam: cam[0] set PMT for sid=65
16:24:50.694 CCcam: start EMM
16:24:50.769 CCcam: EMM demux 1 set
16:24:50.771 CCcam: EMM: start filter on irdeto emmpid: 0x464 caid: 0x612 id: 0x0
16:24:51.524 CCcam: chid 0001
16:24:51.525 CCcam: chid 0003
16:24:51.525 CCcam: local ecm -> card /dev/sci0 0x612(0x000) sid 0x065
16:24:51.640 CCcam: local ecm <- card /dev/sci0 error
16:24:51.640 CCcam: local ecm -> card /dev/sci0 0x612(0x000) sid 0x065
16:24:51.778 CCcam: local ecm <- card /dev/sci0 ok
16:24:51.779 CCcam: cam[0] ecm even ok caid:0x612 id:0x0 pid:0x44f Unknown
16:24:54.112 CCcam: local emm -> card /dev/sci0 0x612(0x000)
16:24:54.208 CCcam: local emm <- card /dev/sci0 ok
16:24:54.208 CCcam: local emm -> card /dev/sci0 0x612(0x000)
16:24:54.328 CCcam: local emm <- card /dev/sci0 ok
16:24:56.299 CCcam: local emm -> card /dev/sci0 0x612(0x000)
16:24:56.360 CCcam: local emm <- card /dev/sci0 ok
2 x Maxytec Multibox 4K
1 x Zgemma H9 combo
zet de optie "try all chids" eens aan, ik neem overigens aan dat deze smartcard wel werkt in een orginele ontvanger.
Diverse meuk... maar dat boeit niemand toch.. ;)
Try all chids ook geprobeerd natuurlijk.
Hier komt het vreemde CCcam ziet de kaart als 0612 in de orginele ontvanger is het 0608??????
Heeft misschien te maken met de "preview" periode, ik wacht deze ff af en kijk dan weer.
Kanalenlijst is in orde was vers gescanned
1 x Zgemma H9 combo
  • 2 jaren later...
Ik heb ook een kabelnoord kaart kan iemand me helpen  hoe de beste config er voor is ik gebruik 2.3.0 versie.
Kun je de zelfde cam-key-camdata gebruiken als voor ziggo ?
Tevens als iemand een complete kanalenlijst heeft voor een E1 versie zou fijn zijn
aangepast door kjonker1
Mijn ontvangers zijn: 1x Vu Ultimo
  • 3 weken later...
Heb het hier wel werkend gekregen
Volgende toegevoegd aan CCcam.cfg
CAMKEY: /dev/sci0 11 22 33 44 55 66 77 88
CAMDATA: /dev/sci0 3C...... ( hele lange weet niet of ik die hier mag plaatsen )
TRY ALL CHIDS : /dev/sci0
En dan kaart bovenin ;-)
Succes.
  • 2 weken later...
kjonker1,
Ik heb zelf geen kabel Noord en kan het hier dus niet testen.
Als het goed is is het deze die bedoeld wordt hier in het topic :
CAMDATA: /dev/sci0 3c 86 33 aa c0 d3 67 53 3d ec 7b b2 ee ed eb 8c a3 ad a5 2e 58 b9 9b b3 46 72 78 32 77 a1 da ac 3b 61 06 ad 09 09 77 4e 03 1b 2a 6e 30 19 5b 43 76 83 ad 0f c5 99 b8 7d 08 ce a4 7b e1 b6 c7 6a
CAMDATA: /dev/sci1 3c 86 33 aa c0 d3 67 53 3d ec 7b b2 ee ed eb 8c a3 ad a5 2e 58 b9 9b b3 46 72 78 32 77 a1 da ac 3b 61 06 ad 09 09 77 4e 03 1b 2a 6e 30 19 5b 43 76 83 ad 0f c5 99 b8 7d 08 ce a4 7b e1 b6 c7 6a
Gebruikte CCcam versies die mij het beste lijken zijn bijv. : 2.0.4, 2.0.9, 2.1.0 en zeker niet de laatste 2.3.0
Evt. zou je als extra try all chids aan kunnen zetten :
TRY ALL CHIDS : /dev/sci1
Gr.
Zilverster.
You are "The last in line" - Ronnie James Dio R.I.P.
Ik kan zelf ook niet testen maar ik heb die kaart ook maar gekregen.
Welke caid en providers heeft deze kaart ik heb zo rode ik denk laatste versie
de ene zegt 0612 of 0606
@kjonker1,
" Welke caid en providers heeft deze kaart "
De eenvoudigste manier om dat te kunnen zien is even "uitlezen" met CCcam, gr.
Zilverster.
