Crazy Sat Geplaatst: 27 december 2010 Geplaatst: 27 december 2010 Zie dat deze DVB-S2 kaart een blindscanfunctie heeft. Is natuurlijk heel interessant voor feedhunters. Is er iemand die reeds ervaring heeft met deze PC kaart ( of er al ene heeft). Graag had ik even wat meer vernomen omtrent deze PC kaart. Even de specificaties : PCI DVB-S2 TV card supports both DVB-S2 and DVB-S program receiving. It support internet via satellite and dvb data downloading. Main Features: 1.DVB-S2/S Transponders Receiving 2.Transponders blind scan (both for DVB-S2 and DVB-S) 3.Broadband Internet via Satellite* 4.High-speed Data download via Satellite* 5.Windows 7 Media Center compatible 6.Linux S2API drivers compatible with MythTV, VDR, XBMC, DVBLast, VLC, etc. 7.Supported by DVBDream, DVBViewer, DVBlogic, ProgDVB, AltDVB, Skynet, TSreader… Specifications: 1.Receiving Frequency: 925 ~ 2175 MHz Tuning Range 2.Input level: -69 ~ -23dBm 3.DVB-S2/DVB-S DIRECTV 8PSK QPSK Demodulator 4. 8PSK/H-8PSK/QPSK/BPSK mode 5. Symbol Rates: DVB-S: 1 - 45 Msps DVB-S2 QPSK: 1 - 45 Msps DVB-S2 8PSK: 1 - 45 Msps 6. Code Rates: DVS-S: 1/2, 2/3, 3/4, 5/6, 7/8 DVB-S2 QPSK: 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10 DVB-S2 8PSK: 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10 7. Automatic Acquisition Range: ±10MHz 8. DiSEqC 2.x compliant 9. PCI interface, Low profile size System Requirements: Windows 2000 / XP / Vista DirectX9.0C or later Pentium 2.0 GHz CPU or above 256MB RAM or above VGA card with at least 32MB memory Sound card or on board sound chip Digital Satellite Dish & LNB feedhunting , a crazy hobby ! Edison OS mio 4K UHD + Octagon SF8008 4K UHD + Dr.HD F15 + Edison OS mini + Technomate TM-5402 HD M3 CI , Moteck SG2100 + Deltastar 90 cm + Invacom C120 QDF-031 Quad lnb + SkyStar HD2,TBS5927 , en TT-budget S2-1600 kaart. Channel Master 180 cm schotel + ESX241 lnb voor C-band. DVB-T2 via Oostvleteren,Egem,Mont des Cats,Bouvigny en Doornik.
