Tjonge het gaat nu wel erg snel:
http://sourceforge.net/projects/openblackhole/
Black Hole team is proud to announce a new experimental project OpenBlack Hole:
1) What is OpenBlackHole project ?
OpenBlackHole is an Open Source project based on Openembedded 1.6
OpenblackHole project will provide to image developers an updated universal OE 1.6 git that will support all the main linux stab:
-Vu+ Duo
- Vu+ Solo
- Clarke Tech Et-9000
- dm500hd
- dm800
- dm800se
- dm8000
OpenBlackHole git will be updated every day with the latest updates of DMM Vuplus and ET9000
2) What kind of images are available in OpenBlackHole ?
At the beginning of the project the OpenBlackHole git can compile pure cvs images with latest enigma2 versions for all these machines. If the project will have success and there will be users and coders partecipations the project will start to produce opensource images depending of code implementations and additions.
3) Where are OpenBlackHole git and public sources ?
You can find the project git at sourceforge.net url: http://openblackhole.git.sourceforge.net/git/gitweb-index.cgi
4) Howto compile images with OpenBlackHole OE ?
First of all you have to know howto compile images, this project is for image developers and not an howto for newbies. If you know howto compile e2 images the istructions are really simply:
- create a directory on your linux box
- put in the directory the makefile you find here in attach (unzip before)
- edit makefile to choose machine (ie: MACHINE ?= et9000)
- type the command:
Citation
make -f Makefile-openblackhole-1.6 image
- Once the image is created you can use the command form the build directory:
Citation
source ./env.source
bitbake -k openblackhole-image
to rebuild the image
5) Howto follow the project development ?
You can see all the project additions and modifications checking the commits at the url:
http://openblackhole.git.sourceforge.net/git/gitweb.cgi?p=openblackhole/openblackhole;a=summary
6) How can i help and partecipate to this project ?
- If you are a simple user: you can test images, find bugs and make suggestions.
- If you are an image builder: you can build your own image with OpenBlackHole git, post your compiled images here in the board so all the simple users can test
- If you are an image coder: you can suggest additions to the project or propose your code to be added in the project remembering that this project is open source.
VU+ Duo2 met  4x DVB-S2 / 2x Dual DVB-S2 Tuner. Plugin remote channel stream converter
Wavefrontier T90. 6x Google TV Android 4K clients.
  • Reacties 43
En hier is het eerste image voor de DM800SE
en hier de 500HD op basis van BlackHole.
  • Beheerder
Dat is een goede ontwikkeling.
Goed voorbeeld doet volgen zeggen ze wel eens.
Mvg,
Michel
Wacht met smart op de image voor de DM8000 laugh
* VU+ Duo 2 sat/kabel - Amiko A3 combo - Coolstream Trinity - Dreambox 800 HD SE - Xsarius Fusion HD SE - Mag254 iptv *
* LG 65inch smart 3D tv - Playstation 4 *
Dat zal niet lang meer duren schat ik nu......
Inmiddels heb ik al begrepen van de mods van Blackhole, dat men eerst begint met een standaard CVS image en dat men nu een voor een de zaken gaat toevoegen. Dat drukt even de pret, maar het zal allemaal wel snel gaan.
Het staat ook in hun uitleg:
Eigenlijk zouden de diverse teams zich in dit forum kunnen samenpakken. Angelofsky1980, een japans teamlid, is een van de mods en de belangrijkste driver ontwikkelaar voor de USB tuners voor Blackhole.
Laten wij hopen dat dit project slaagt..
Origineel bericht van: TheMystery
Nu dit image open is kunnen andere image makers natuurlijk ook de dvb-t support overnemen in hun eigen images.
Ik weet niet of dit nu de bedoeling is, eigenlijk zou het andersom moeten zijn dat de teams zich samenpakken om tot een standaard image te komen waar dan elk team zijn eigen schil/huisstijl omheen gooit. Blackhole geeft al aan dat het valt of staat als andere coders ook mee gaan doen.
Dat zal zeer zeker nog niet lukken, daar het huidige open image bijna 100% een OpenDreambox image is...
bron:
At the beginning of the project the OpenBlackHole git can compile pure cvs images with latest enigma2 versions for all these machines..
Binnenkort is bijna alles in MPEG4 bij CanalDigitaal... je SD ontvanger kan dus in de Kliko
Heel positief, dit.
Door gebruik van GIT en sourceforge kunnen de teams toch wel met elkaar integreren. Kleine gescheiden teams werken beter dan een enkele grote club. Alleen al door land-, taal- en tijdverschillen.
De teams zouden wel moeten streven naar aansluiting bij OpenEmbedded.org, blackhole heeft dat ongelukkigerwijs (nog?) niet gedaan.
Dream kan (mag?) hierin geen centrale rol vervullen, want ze doen juist moeite om te zorgen dat Enigma alleen op hun hardware draait...
  • 2 weken later...
Als ik zo'n dingen lees begin ik te dromen ...
Zou er ooit zo´n image bestaan die men op een normale pc kan draaien , meer vendor onafhankelijk kan het niet worden ;-)
  • 2 weken later...
