dorus43 Geplaatst: 14 januari 2011 Geplaatst: 14 januari 2011 Daar VLC 1.14 integenstelling met VLC 1.06 de weergave van ondertitels in opgenomen DVB-s bestanden niet ondersteunt, zou ik graag de versie 1.06 installeren doch dit lukt me niet. Via google vond ik "http://www.videolan.org/vlc/download-ubuntu.html" . Citaat: Ubuntu Maverick Meerkat 10.10 Graphical way Open Synaptic application Click on System -> Administration -> Synaptic Package Manager. In Settings -> Repositories, make sure you have an universe repository activated. Search for vlc and install it. You should install vlc-plugin-pulse and mozilla-plugin-vlc as well. If you are interested in streaming or transcoding, you should additionnally install libavcodec-extra-52 from a multiverse repository. Command line way You need to check that a universe mirror is listed in your /etc/apt/sources.list file. % sudo apt-get update % sudo apt-get install vlc vlc-plugin-pulse mozilla-plugin-vlc Ubuntu Lucid Lynx 10.04 LTS VLC version 1.0.6 in Ubuntu 10.04 is out-of-date. We recommend you install VLC 1.1.x manually. If you wish to install VLC 1.0.6 anyway, please refer to the instructions above for Ubuntu 10.10. Note that there will be some bugs; you are on your own. At your OWN risks, install VLC from PPA: Command line way % sudo add-apt-repository ppa:lucid-bleed/ppa % sudo apt-get update % sudo apt-get install vlc vlc-plugin-pulse mozilla-plugin-vlc Na uitvoering van deze 3 commands krijg ik nog steeds in pakketbeheer slechts versie 1.14 tezien( ook na apt-get update en herstarten) Het eerste command geeft dit weer (naar mijn gevoel is dit fout), is dat zo? Citaat: dorus@dorus-M68M-S2P ~ $ sudo add-apt-repository ppa:lucid-bleed/ppa [sudo] password for dorus: Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --secret-keyring /etc/apt/secring.gpg --trustdb-name /etc/apt/trustdb.gpg --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver keyserver.ubuntu.com --recv 8997B7E84F8C59212829643BEC7B7B7D4439DBD6 gpg: opvragen sleutel 4439DBD6 van hkp sleutelserver keyserver.ubuntu.com gpg: sleutel 4439DBD6: “Launchpad lucidbleed” niet veranderd gpg: Totaal aantal verwerkt: 1 gpg: Onveranderd: 1 dorus@dorus-M68M-S2P ~ $ k heb ondertussen als "work around" de laatste Windows versie van VLC via wine geïnstalleerd, daarin werkt gelukkig de ondertiteling. Ik ben uiteraard niet zo gelukkig met deze oplossing, dus graag een beetje hulp om de versie 1.06 in Linux te installeren. Ik heb ook al getracht de /etc/apt/sources.list manueel aan te passen, maar ik vrees dat ik de juist bron voor 10.4 niet heb geplaatst. Alvast bedankt voor jullie reakties. met vriendelijke groet. Dorus Octagon 4K UHD SF8008 (OpenPli 8.3) (Oscam ) ( Vu+Zero) (OpenPli 7.3) (Oscam )
Lamko Geplaatst: 14 januari 2011 Geplaatst: 14 januari 2011 Het eerste wat je moet leren hoe je een ppa toevoegt Dit is je ppa : https://launchpad.net/~lucid-bleed/+archive/ppa klik dan op Technical details about this PPA op die site En lees de link naast signing key eens goed door dan moet het goedkomen Mythbuntu 12.04 Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
dorus43 Geplaatst: 14 januari 2011 Auteur Geplaatst: 14 januari 2011 bedankt Lamko groet Dorus Octagon 4K UHD SF8008 (OpenPli 8.3) (Oscam ) ( Vu+Zero) (OpenPli 7.3) (Oscam )
