cedric14 Geplaatst: 16 maart 2011 Auteur Geplaatst: 16 maart 2011 Het lijkt niet aan de herstart te liggen, het herhalen van bovenstaande procedure zonder herstart werkt gewoon.
cedric14 Geplaatst: 16 maart 2011 Auteur Geplaatst: 16 maart 2011 Als ik cat doe, en dat bestand met mplayer afspeel werkt het geheel feilloos: $ cat /dev/dvb/adapter1/dvr0 > test.ts Code: $ mplayer -identify test.ts MPlayer SVN-r32792-4.5.2 © 2000-2011 MPlayer Team161 audio & 351 video codecsmplayer: could not connect to socketmplayer: No such file or directoryFailed to open LIRC support. You will not be able to use your remote control.Playing test.ts.TS file format detected.VIDEO MPEG2(pid=3061) AUDIO MPA(pid=3062) NO SUBS (yet)! PROGRAM N. 0ID_VIDEO_ID=3061ID_AUDIO_ID=3062VIDEO: MPEG2 480x576 (aspect 3) 25.000 fps 15000.0 kbps (1875.0 kbyte/s)Load subtitles in ./ID_FILENAME=test.tsID_DEMUXER=mpegtsID_VIDEO_FORMAT=0x10000002ID_VIDEO_BITRATE=15000000ID_VIDEO_WIDTH=480ID_VIDEO_HEIGHT=576ID_VIDEO_FPS=25.000ID_VIDEO_ASPECT=0.0000ID_AUDIO_FORMAT=80ID_AUDIO_BITRATE=0ID_AUDIO_RATE=0ID_AUDIO_NCH=0ID_START_TIME=37819.71ID_LENGTH=172.38ID_SEEKABLE=1ID_CHAPTERS=0==========================================================================Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec familySelected video codec: [ffmpeg2] vfm: ffmpeg (FFmpeg MPEG-2)==========================================================================ID_VIDEO_CODEC=ffmpeg2==========================================================================Opening audio decoder: [mp3lib] MPEG layer-2, layer-3AUDIO: 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000)ID_AUDIO_BITRATE=128000ID_AUDIO_RATE=48000ID_AUDIO_NCH=2Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)==========================================================================AO: [oss] 48000Hz 2ch s16le (2 bytes per sample)ID_AUDIO_CODEC=mp3Starting playback...Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.ID_VIDEO_ASPECT=1.7778VO: [vdpau] 480x576 => 1024x576 Planar YV12 A:37823.9 V:37824.8 A-V: -0.872 ct: -0.380 97/ 97 6% 4% 0.3% 0 0 Exiting... (Quit)ID_EXIT=QUIT
cedric14 Geplaatst: 16 maart 2011 Auteur Geplaatst: 16 maart 2011 Voor de volledigheid nog even de regel van discovery uit channels.conf: Code: Discovery Channel:498000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_2_3:FEC_AUTO:QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:3061:3062:36
Lamko Geplaatst: 16 maart 2011 Geplaatst: 16 maart 2011 Zorg dat je alle logs realtime kunt lezen op verschillende terminals en ja de volgorde van programma's starten maakt zeker uit. Je doet het nu goed Dit is mijn regel, waar je niet veel aan hebt want ik zit op een andere zender. Discovery Channel:474000000:INVERSION_AUTO:BANDWIDTH_8_MHZ:FEC_1_2:FEC_1_2: QAM_64:TRANSMISSION_MODE_8K:GUARD_INTERVAL_1_4:HIERARCHY_NONE:3061:3062:36 Wanneer is de vertraging in sasc, waar is hij meebezig. Je kunt bijv ook coderingssystemen weggooien die je toch niet gebruikt ! Denk erom tzap is ook niet heilig je moet het puur als test gebruiken werkt het allemaal stap dan over op iets fatsoenlijks zoals Kaffeine (niet de sc versie gebruiken met sasc)of Mythtv. Mythbuntu 12.04 Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
cedric14 Geplaatst: 17 maart 2011 Auteur Geplaatst: 17 maart 2011 Ik heb op het moment 8 terminals open, ik volg real-time oscam.log, everything.log en sasc-ng.log De vertraging in sasc=ng begint als ik tzap start. Op dat moment zie ik het volgende in sasc-ng.log. Zo te zien wacht sasc-ng op nit, alleen ik zou niet weten wat dat is: Mar 16 13:29:00.091 CHANNEL: Tuning frontend Mar 16 13:29:00.162 CSA: Got command(1): I idx: 0 pid: 0 Mar 16 13:29:00.117 : Listening on port 5456 Buffer has room, reading 32900 bytes Returning 32768 <knip> Buffer has room, reading 32900 bytes Returning 32768 <<<Hier zit 45 seconde pauze>>> Mar 16 13:29:48.291 CHANNEL: start: giving up reading nit Mar 16 13:29:48.722 CAM(core.pids): 0: now tuned to source 1(1) transponder 0 Mar 16 13:29:48.772 CAM: SC completed Tune cmd Mar 16 13:29:48.806 CAM(core.pids): 0: update SID 36 (zero=0 noshift=0) Mar 16 13:29:48.851 CAM(core.pids): 0: pids typ5=0bf5 typ5=0bf6 typ5=0bf7 Pas na de 45 seconde pauze zie ik in oscam.log dat er een sleutel gevraagd wordt: 2011/03/16 13:28:57 5969 s client(1) connect from 127.0.0.1 (pid=7014, pipfd=14) 2011/03/16 13:28:57 7014 c01 encrypted newcamd:15050-client 127.0.0.1 granted (user2, au(auto)=reader1) 2011/03/16 13:28:57 7014 c01 user user2 authenticated successfully (generic) 2011/03/16 13:28:57 7014 c01 AU enabled for user user2 on reader reader1 2011/03/16 13:29:50 7014 c01 user2 (0B00&00E030/0024/47:60BF): found (265 ms) by reader1 2011/03/16 13:29:54 7014 c01 user2 (0B00&00E030/0024/47:5029): found (264 ms) by reader1 2011/03/16 13:30:04 7014 c01 user2 (0B00&00E030/0024/47:EC3D): found (261 ms) by reader1 2011/03/16 13:30:14 7014 c01 user2 (0B00&00E030/0024/47:3EDF): found (265 ms) by reader1 Mijn doel is uiteindelijk om inderdaad mythtv te gebruiken. Het lijkt erop dat ik nu de goede versies gebruik, ik zie geen programma's meer vastlopen. Blijft over dat er fouten in mijn configuratie zitten. Kan je jouw configuratie posten? Dan kan ik het naast mijn configuratie leggen. Voor zover ik kan zien zijn het de volgende configuratiebestanden, klopt dat? /etc/oscam/oscam.conf /etc/oscam/oscam.services /etc/oscam/oscam.server /etc/oscam/oscam.user /etc/camdir/cardclient.conf /etc/camdir/override.conf /etc/camdir/cardslot.conf /etc/camdir/smartcard.conf /etc/camdir/ecm.cache /etc/camdir/SoftCam.Key
Lamko Geplaatst: 17 maart 2011 Geplaatst: 17 maart 2011 Je hebt alles goed nu, die 45 sec heb ik geen last van maar het is volgens mij een bug in sasc. Andere versie proberen, ik heb hier nog versie : SC version 1.0.0pre-HG-28d5438fad67+ Het enige bestand wat belangrijk is voor sasc kwa config is cardclient.conf en die is goed. En ik gebruik geen Oscam dus daar kan ik je niet meehelpen. Hier kun je een uitleg vinden over dvb techniek : http://www.digitalekabeltelevisie.nl/techniek/dvb.shtml met de nit begint het mee die verteld hoe alles in elkaar steekt. Heb de source eens doorgelezen. Mythbuntu 12.04 Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
cedric14 Geplaatst: 20 maart 2011 Auteur Geplaatst: 20 maart 2011 Ben ik weer, Ik heb nu mythbuntu 10.10 geinstalleerd, en geupdated. Nu heb ik de volgende kernel versie: # uname -a Linux tvpc 2.6.35-28-generic #49-Ubuntu SMP Tue Mar 1 14:40:58 UTC 2011 i686 GNU/Linux Eerst oscam maar installeren. Ik heb oscam niet gevonden in de package manager, dus dan maar deze guide volgen om het te compileren: http://oscam.ump2002.net/board/print.php...f2768319e381ac4 Depdendensies installeren: apt-get install subversion cmake libssl-dev gcc g++ libusb moet handmatig gebouwd worden: http://sourceforge.net/projects/libusb/files/libusb-1.0/libusb-1.0.8/ ./configure && make && sudo make install Source downloaden: $ svn co http://streamboard.gmc.to/svn/oscam/trunk oscam-svn $ cd oscam-svn/ $ cmake -DWEBIF=1 $ sudo cp oscam /usr/local/bin/ $ sudo cp utils/list_smargo /usr/local/bin Bestanden in /etc/oscam aanpassen # mkdir /var/log/oscam # /usr/local/bin/oscam -c /etc/oscam oscam ziet mijn smargo en de digitenne kaart zonder problemen: Code: ------------------------------------------------------------------------------->> OSCam << cardserver started at Sun Mar 20 13:56:10 2011-------------------------------------------------------------------------------2011/03/20 13:56:10 B78DB6C0 s >> OSCam << cardserver started version 1.00-unstable_svn, build #4842 (i686-pc-linux)2011/03/20 13:56:10 B78DB6C0 s version=1.00-unstable_svn, build #4842, system=i686-pc-linux, nice=-12011/03/20 13:56:10 B78DB6C0 s client max. idle=120 sec, debug level=02011/03/20 13:56:10 B78DB6C0 s max. logsize=unlimited2011/03/20 13:56:10 B78DB6C0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=0 ms2011/03/20 13:56:10 B78DB6C0 s auth size=49722011/03/20 13:56:10 B78DB6C0 s services reloaded: 0 services freed, 1 services loaded2011/03/20 13:56:10 B78DB6C0 s userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled2011/03/20 13:56:10 B78DB6C0 s signal handling initialized (type=sysv)2011/03/20 13:56:10 B78DB6C0 s can't open file "/etc/oscam/oscam.srvid" (err=2), no service-id's loaded2011/03/20 13:56:10 B78DB6C0 s can't open file "/etc/oscam/oscam.tiers" (err=2), no tier-id's loaded2011/03/20 13:56:10 B78DB6C0 s can't open file "/etc/oscam/oscam.provid" (err=2), no provids's loaded2011/03/20 13:56:10 B78DB6C0 s can't open file "/etc/oscam/oscam.ird" (errno=2) irdeto guessing not loaded2011/03/20 13:56:10 B78DB6C0 s monitor: initialized (fd=8, port=8988)2011/03/20 13:56:10 B78DB6C0 s camd33: disabled2011/03/20 13:56:10 B78DB6C0 s camd35: disabled2011/03/20 13:56:10 B78DB6C0 s cs378x: disabled2011/03/20 13:56:10 B78DB6C0 s newcamd: initialized (fd=9, port=15050, crypted)2011/03/20 13:56:10 B78DB6C0 s CAID: 0B002011/03/20 13:56:10 B78DB6C0 s provid #0: 00E0302011/03/20 13:56:10 B78DB6C0 s cccam: disabled2011/03/20 13:56:10 B78DB6C0 s radegast: disabled2011/03/20 13:56:10 B78DB6C0 s http thread started2011/03/20 13:56:10 B78DB6C0 s creating thread for device /dev/ttyUSB02011/03/20 13:56:10 B78DB6C0 s loadbalancer: can't read from file /tmp/.oscam/stat2011/03/20 13:56:10 B78DB6C0 s waiting for local card init2011/03/20 13:56:10 B78D3280 r reader thread started (thread=B78D3280, label=reader1, device=/dev/ttyUSB0, detect=cd, mhz=357, cardmhz=357)2011/03/20 13:56:10 B78DA280 h HTTP Server listening on port 88882011/03/20 13:56:13 B78D3280 r reader1 card detected2011/03/20 13:56:17 B78D3280 r ATR: 3B 24 00 30 42 30 30 2011/03/20 13:56:18 B78D3280 r Maximum frequency for this card is formally 5 Mhz, clocking it to 3.57 Mhz2011/03/20 13:56:20 B78D3280 r type: Conax, caid: 0B00, serial: 1428098758, hex serial: 551f0ec6, card: v642011/03/20 13:56:20 B78D3280 r Providers: 12011/03/20 13:56:20 B78D3280 r Provider: 1 Provider-Id: 0000002011/03/20 13:56:20 B78D3280 r Provider: 1 SharedAddress: 002A8F872011/03/20 13:56:20 B78D3280 r found cardsystem conax2011/03/20 13:56:20 B78D3280 r Package: 1, id: 1010, date: 2011/03/01 - 2011/03/31, name: Digitenne2011/03/20 13:56:20 B78D3280 r [conax-reader] ready for requests2011/03/20 13:56:20 B78DB6C0 s init for all local cards done2011/03/20 13:56:20 B78DB6C0 s anti cascading disabled
cedric14 Geplaatst: 20 maart 2011 Auteur Geplaatst: 20 maart 2011 Nu sasc-ng werkend krijgen. Ik volg deze handleiding: http://www.cccamforum.com/forums/showthread.php?t=67988 Eerst de dependenties installeren: sudo apt-get install mercurial gettext Dan source downloaden en compileren: ... zie de bovenstaande link Sasc-ng starten: sudo modprobe dvbloopback num_adapters=1 sudo /usr/bin/sasc-ng -D -j 0:1 --cam-dir=/etc/camdir/ -l /var/log/sasc-ng.log Afstemmen: $ tzap -a 1 -r 'Discovery Channel' ...45 seconden wachten ... In een bestand dumpen: cat /dev/dvb/adapter1/dvr0 > test.ts En afspelen: mplayer test.ts Vreemd, ik heb nu van alle software andere versies, en nog steeds het zelfde probleem.
Lamko Geplaatst: 20 maart 2011 Geplaatst: 20 maart 2011 Je pakt het wel rigoureus aan met allemaal andere versies maar degene die ik bedoelde heb je juist niet gedaan ! hg clone --rev 28d5438fad67 http://85.17.209.13:6100/sc Is een hele oude revisie maar die heb ik hier draaien en werkt ! Ik heb zelf nog nooit met oude revisies gewerkt dus check wel even of het klopt wat ik hier doe. Dit is puur om uit te sluiten dat het niet aan sasc-ng ligt wat ik 99% wel van verdenk. Eerst had ik ook nog mijn bedenkingen bij tzap maar dat heb je wel weggenomen door een hele andere distro te nemen Mythbuntu 12.04 Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
Okkie Geplaatst: 27 maart 2011 Geplaatst: 27 maart 2011 Die revisie wilde bij mij in eerste instantie niet compileren, maar nadat ik in contrib/sasc-ng/dvblb_plugins/plugin_scan.c ergens tussen al die regels met #include bovenin de volgende regel toevoegde: #include <sys/stat.h> Compileerde die wel. Voor mij is dit allemaal nieuw, dus ik heb veel aan het goed gedocumenteerde gepuzzel van cedric gehad, waarvoor dank! Wat heb ik uiteindelijk gedaan? Ik heb deze versie van sasc-ng gecompileerd en de binaries volgens de eerder gedocumenteerde botte bijl in /usr/bin, /lib/modules en /usr/lib geplaatst. Daarnaast heb ik oscam uit die ppa van mirak geinstalleerd, met de configuratiefiles van cedric uit z'n dvd-probleem.tar.gz. Ik start alles nog met de hand op, maar dit is een werkende volgorde: oscam -b -d 255 modprobe dvbloopback sasc-ng -j 0:1 --cam-dir /etc/camfiles/ --sid-allpid Of die --sid-allpid nodig is, weet ik niet. En die 0:1 ligt ook aan de situatie. Bij mij is de module nog niet geladen als de dvb-stick gestart wordt. Ik kan nu met vlc, met dvblast of met mplayer naar alle zenders kijken via /dev/dvb/adapter1. Om zeker te weten of ik de juiste adapter gebruik, draai ik die media als een user uit de groep video en heb ik de originele /dev/dvb/adapter0 mode 700 gemaakt, zodat ik daar niet per ongeluk naar zit te kijken. Ik heb zeker een uur verspeeld door te denken dat ik mplayer naar de gedecodeerde adapter1 liet kijken, terwijl die gewoon nog steeds adapter0 zat te openen... De volgende stap is dat ik ervoor zorg dat alles ook automatisch wordt gestart. Nu draait het allemaal nog in terminals, maar ik ben aardig op weg naar de switch van analoog UPC naar digitenne voor m'n mythtv-setup. Zodra BBC 1 en 2 beschikbaar zijn, moet het klaar zijn, dus ik heb nog even tijd. ;-)
Lamko Geplaatst: 27 maart 2011 Geplaatst: 27 maart 2011 Mooi weer iemand blij Mythbuntu 12.04 Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
cedric14 Geplaatst: 12 mei 2011 Auteur Geplaatst: 12 mei 2011 Hoi Okkie, Is er bij jou ook een vertraging voordat sasc-ng een sleutel aan oscam vraagt, of gebeurt dit direct? Bij mij was de vertraging ong. 45 sec. In andere woorden, hoe snel kan jij door de kanalen heen zappen? Groetjes, Cedric
cedric14 Geplaatst: 14 mei 2011 Auteur Geplaatst: 14 mei 2011 Origineel bericht van: Okkie Die revisie wilde bij mij in eerste instantie niet compileren, maar nadat ik in contrib/sasc-ng/dvblb_plugins/plugin_scan.c ergens tussen al die regels met #include bovenin de volgende regel toevoegde:#include <sys/stat.h>Compileerde die wel. Ik heb 'm ook net proberen te compileren, maar bij mij lukte het niet. Wat doe ik verkeerd? Code: cedric@laptop:~/tmp$ mkdir sasc-ngcedric@laptop:~/tmp$ cd sasc-ng/cedric@laptop:~/tmp/sasc-ng$ hg clone --rev 28d5438fad67 http://85.17.209.13:6100/scdestination directory: scadding changesetsadding manifestsadding file changesadded 532 changesets with 1763 changes to 500 filesupdating to branch trunk314 files updated, 0 files merged, 0 files removed, 0 files unresolvedcedric@laptop:~/tmp/sasc-ng$ cd sc/contrib/sasc-ng/cedric@laptop:~/tmp/sasc-ng/sc/contrib/sasc-ng$ chmod +x configure makelinks.sh dvbloopback/module/config_dvb.pl Toevoegen #include <sys/stat.h> bij plugin_scan.c Code: cedric@laptop:~/tmp/sasc-ng/sc/contrib/sasc-ng$ nano dvblb_plugins/plugin_scan.c Proberen te compileren Code: cedric@laptop:~/tmp/sasc-ng/sc/contrib/sasc-ng$ make cleanMakefile:5: config.mak: No such file or directorymake: *** No rule to make target `config.mak'. Stop.cedric@laptop:~/tmp/sasc-ng/sc/contrib/sasc-ng$ ./configure Using C++ compiler: g++Using compile type debugProcessor capabilities: native ( mmx sse sse2 )Trying various FFdecsa optimizations... PARALLEL_32_INT: test failed PARALLEL_64_2INT: test failed PARALLEL_64_LONG: 79 PARALLEL_64_MMX: 208 PARALLEL_128_2LONG: 97 PARALLEL_128_2MMX: 218 PARALLEL_128_SSE: 258 PARALLEL_128_SSE2: 305Choosing PARALLEL_MODE = PARALLEL_128_SSE2cedric@laptop:~/tmp/sasc-ng/sc/contrib/sasc-ng$ make modulecd dvbloopback/module && make make[1]: Entering directory `/storage/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module'echo "Skipping Modver "Skipping Modver ./config_dvb.pl "BUILD_DIR=/lib/modules/2.6.36-ARCH/build" "EXTRA_CFLAGS=-Idrivers/media/dvb/dvb-core/ -I/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module"Found dvbdev.h from 2.6.22 or latermake -C /lib/modules/2.6.36-ARCH/build M=/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module modulesmake[2]: Entering directory `/usr/src/linux-2.6.36-ARCH' CC [M] /home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.o/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c: In function ‘dvblb_ioctl’:/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c:727:26: warning: passing argument 5 of ‘dvblb_usercopy’ from incompatible pointer type/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c:121:12: note: expected ‘int (*)(struct inode *, struct file *, unsigned int, void *)’ but argument is of type ‘int (*)(struct file *, unsigned int, void *)’/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c: At top level:/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c:981:2: error: unknown field ‘ioctl’ specified in initializer/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c:981:2: warning: initialization from incompatible pointer type/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c:990:2: warning: initialization from incompatible pointer type/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c:1001:2: error: unknown field ‘ioctl’ specified in initializer/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c:1001:2: warning: initialization from incompatible pointer type/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.c:1010:2: warning: initialization from incompatible pointer typemake[3]: *** [/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module/dvb_loopback.o] Error 1make[2]: *** [_module_/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module] Error 2make[2]: Leaving directory `/usr/src/linux-2.6.36-ARCH'make[1]: *** [all] Error 2make[1]: Leaving directory `/storage/home/cedric/tmp/sasc-ng/sc/contrib/sasc-ng/dvbloopback/module'make: *** [module] Error 2 En proberen om het programma zelf te compileren: Code: cedric@laptop:~/tmp/sasc-ng/sc/contrib/sasc-ng$ makeg++ -Wall -D__user= -Werror -g -o objs/forward.o -c -DRELEASE_VERSION=\"0.0.2\" -D__KERNEL_STRICT_NAMES -Idvbloopback/src -Idvbloopback/module -I/lib/modules/2.6.36-ARCH/build/include dvbloopback/src/forward.ccc1plus: warnings being treated as errorsIn file included from /usr/include/asm/sigcontext.h:5:0, from /usr/include/bits/sigcontext.h:28, from /usr/include/signal.h:339, from dvbloopback/src/forward.c:30:/lib/modules/2.6.36-ARCH/build/include/linux/types.h:13:2: error: #warning "Attempt to use kernel headers from user space, see http://kernelnewbies.org/KernelHeaders"make: *** [objs/forward.o] Error 1
Lamko Geplaatst: 14 mei 2011 Geplaatst: 14 mei 2011 Je kernel is vrij nieuw daar zal het hem wel inzitten. Sasc-ng is vrij kieskeurig altijd met kernelupdates. 2.6.32 ofzo moet denk ik wel lukken ! Mythbuntu 12.04 Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
Gast Herman Gerritsen Geplaatst: 14 mei 2011 Geplaatst: 14 mei 2011 Vanaf linux kernel versie 2.6.38 is het oude V4L V1 vrijwel volledig verwijderd en heeft het V4L V2 zijn intreden gedaan. De dvbloopback module van sasc-ng compileert hierdoor niet meer. naar mijn idee is hier ook niemand meer mee bezig (met de ontwikkeling). Verder lijkt het er op dat weinig mensen op een deze nieuwe kernel sasc-ng gebruiken gezien het feit dat er niets op google te vinden is (uitgezonderd van een handje vol forums waar het niet kunnen compileren wordt beschreven zonder oplossingen) Weet iemand of er nog ergens een ontwikkeling gaande is?
