Fail2ban Probleem met IPTABLE - HULP! HULP!!
Ik heb dit error uit mijn "/var/log/fail2ban.log" gelezen:
2011-05-18 01:07:10,766 fail2ban.actions.action: ERROR iptables -N fail2ban-cccam_signaturefailed
iptables -A fail2ban-cccam_signaturefailed -j RETURN
iptables -I INPUT -p tcp -m multiport --dports 6677 -j fail2ban-cccam_signaturefailed returned 200
Hier onder mijn JAIL.CONF:
# Fail2Ban configuration file.
# This file was composed for Debian systems from the original one
# provided now under /usr/share/doc/fail2ban/examples/jail.conf
# for additional examples.
# To avoid merges during upgrades DO NOT MODIFY THIS FILE
# and rather provide your changes in /etc/fail2ban/jail.local
# Author: Yaroslav O. Halchenko <debian@onerussian.com>
# $Revision: 281 $
# The DEFAULT allows a global definition of the options. They can be override
# in each jail afterwards.
[DEFAULT]
# "ignoreip" can be an IP address, a CIDR mask or a DNS host
ignoreip = 127.0.0.1 192.168.0.0/24
bantime = 600
maxretry = 3
# "backend" specifies the backend used to get files modification. Available
# options are "gamin", "polling" and "auto".
# yoh: For some reason Debian shipped python-gamin didn't work as expected
# This issue left ToDo, so polling is default backend for now
backend = polling
# Destination email address used solely for the interpolations in
# jail.{conf,local} configuration files.
destemail = root@localhost
# ACTIONS
# Default banning action (e.g. iptables, iptables-new,
# iptables-multiport, shorewall, etc) It is used to define
# action_* variables. Can be overriden globally or per
# section within jail.local file
banaction = iptables-multiport
# email action. Since 0.8.1 upstream fail2ban uses sendmail
# MTA for the mailing. Change mta configuration parameter to mail
# if you want to revert to conventional 'mail'.
mta = sendmail
# Default protocol
protocol = tcp
# Action shortcuts. To be used to define action parameter
# The simplest action to take: ban only
action_ = %(banaction)s[name=%(__name__)s, port="%(port)s", protocol="%(protocol)s]
# ban & send an e-mail with whois report to the destemail.
action_mw = %(banaction)s[name=%(__name__)s, port="%(port)s", protocol="%(protocol)s]
%(mta)s-whois[name=%(__name__)s, dest="%(destemail)s", protocol="%(protocol)s]
# ban & send an e-mail with whois report and relevant log lines
# to the destemail.
action_mwl = %(banaction)s[name=%(__name__)s, port="%(port)s", protocol="%(protocol)s]
%(mta)s-whois-lines[name=%(__name__)s, dest="%(destemail)s", logpath=%(logpath)s]
# Choose default action. To change, just override value of 'action' with the
# interpolation to the chosen action shortcut (e.g. action_mw, action_mwl, etc) in jail.local
# globally (section [DEFAULT]) or per specific section
action = %(action_)s
# JAILS
# Next jails corresponds to the standard configuration in Fail2ban 0.6 which
# was shipped in Debian. Enable any defined here jail by including
# [sECTION_NAME]
# enabled = true
# in /etc/fail2ban/jail.local.
# Optionally you may override any other parameter (e.g. banaction,
# action, port, logpath, etc) in that section within jail.local
[cccam_signaturefailed]
enabled = true
port = 6677
filter = cccam-signature
logpath = /var/log/syslog
bantime = 6000
maxretry = 20
[ssh]
enabled = true
port = ssh
filter = sshd
logpath = /var/log/auth.log
maxretry = 6
Work is work if you're paid to do it. It's a HOBBY if you've to pay to be allowed to do it.
2X Amiko 8900HD SPARK(Schiterrend!!!). T90 in aankoop......
Wanneer gebeuren deze errors, wat wil je ? Een google op fail2ban cccam levert mij allemaal voorbeelden op, kijk daar eens naar !
Mythbuntu 12.04
Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
Inderdaad, er is geen specifieke aantwoord op mijn vraag door te GOOGLEN:
Als iemand een DIREKT Handeling weet om van dit error af te komen en eventueel FAIL2BAN werkend te krijgen.
Alvast dank
  • Moderator
Ik heb wat zitten googlen, en kwam onder meer dit tegen:
Error messages are similar to the following:
iptables -I INPUT -p tcp -m multiport --dports smtp -j fail2ban-rulename returned 400
The error codes can have different values like 200, 100, 400.
It seems to be a timing error with iptables.
A fix can be added to the /usr/bin/fail2ban-client python application:
Add the line
time.sleep(0.1)
to the function
def __processCmd(self, cmd, showRet = True):
beautifier = Beautifier() for c in cmd:
beautifier.setInputCmd©
in front of the beautifier.setInputCmd© command.
The result will look like:
time.sleep(0.1) <--- DEZE zou je moeten toevoegen
Restart fail2ban and it should now work without any problem.
bron: http://oschgan.com/drupal/index.php?q=node/52
Ik ken zelf fail2ban niet, maar je zou bovenstaande eens kunnen proberen om te zien of het inderdaad een timing probleem is met het starten van fail2ban.
groet,
Wiz
VU+ Duo4kSe  met VTi    VU+ duo2 met VTi
Triax 78, astra 1,2,3, HB
Sorry zonder duidelijke antwoord op mijn vraag kan ik niet zoveel als ik niet weet wat je zelf al gedaan hebt.
Ik kan hier wel wat linkjes hier neer gooien maar dat blijft puur gokken. Het programma en de foutmelding is niet zo heel moeilijk om in google te gooien dat is het probleem niet.
Mythbuntu 12.04
Wiz,
Dank voor je hulp. Gedaan en ik blijf het volgende krijgen:
2011-05-19 23:04:47,323 fail2ban.actions.action: ERROR iptables -N fail2ban-cccam_signaturefailed
Ter volledigheid:
"cccam_signaturefailed" is mijn filter_d conf naam
Alvast dank
Origineel bericht van: wiz
Add the line
time.sleep(0.1)
to the function
groet,
Wiz
Dit wordt debuggen dus begin zo simpel mogelijk en bouw het uit. Regel voor regel handmatig invoeren in de shell en kijk of het fouten oplevert.
Mythbuntu 12.04
No offence maar waarom zou je fail2ban gebruiken?
$IPT -A tcp_inbound -p TCP -s IPADRES1-OF-DNS1 --destination-port 6677 -j ACCEPT
$IPT -A tcp_inbound -p TCP -s IPADRES2-OF-DNS2 --destination-port 6677 -j ACCEPT
etc.
zet een "service iptables restart" in cron en laat hem ieder uur uitvoeren, dan worden de IP's van de dnssen ook geupdate mocht een client IP veranderen.
Voeg gewoon de IP's of dnssen toe en mocht er 1 geblokkeerd moeten worden dan # je hem gewoon uit.
CDS: Wij bieden goede beeldkwaliteit, dat u geen goed beeld heeft ligt niet aan onze bandbreedte.
