Ik neem op van:
NED1SD 19.2 Astra 1H/1KR/1L/1M, 12515, 22000, Hor, 5/6, 4011
NED2SD 19.2 Astra 1H/1KR/1L/1M, 12515, 22000, Hor, 5/6, 4012
NED3SD 19.2 Astra 1H/1KR/1L/1M, 12515, 22000, Hor, 5/6, 4013
RTL4SD 19.2 Astra 1H/1KR/1L/1M, 12344, 27500, Hor, 3/4, 2004
RLT5SD 19.2 Astra 1H/1KR/1L/1M, 12344, 27500, Hor, 3/4, 2005
SBS6SD 19.2 Astra 1H/1KR/1L/1M, 12515, 22000, Hor, 5/6, 4002
RTL7SD 19.2 Astra 1H/1KR/1L/1M, 12344, 25700, Hor, 3/4, 2006
RTL8SD 19.2 Astra 1H/1KR/1L/1M, 12344, 27500, Hor, 3/4, 2035
NET5SD 19.2 Astra 1H/1KR/1L/1M, 12515, 22000, Hor, 5/6, 4003
VEROSD 19.2 Astra 1H/1KR/1L/1M, 12344. 27500. Hor, 3/4, 2031
Zoals eerder aangegeven eerder was dit absoluut geen probleem. Sinds de nagravision tests zijn de problemen begonnen. Erg vervelend, ik betaal canaldigitaal gewoon voor de diensten, ik mag toch zelf wel bepalen hoevaak ik opneem :@
VU+ ULTIMO 4K (OPENPLi-8.1) :: 1x DVB-C FBC :: ZIGGO
VU+ ULTIMO 4K (OPENPLi-8.1) :: 1x DVB-C FBC en 1x DVB-S2 FBC :: ZIGGO
  • Reacties 96
12:49:31.676 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfad
12:49:31.684 CCcam: cam[2] ecm even ok caid:0x100 id:0x6a pid:0x70b Unknown
12:49:31.988 CCcam: local ecm <- card /dev/sci1 ok
12:49:31.997 CCcam: cam[0] ecm even ok caid:0x100 id:0x6a pid:0x70d Unknown
12:49:40.752 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0x7d4
12:49:41.061 CCcam: local ecm <- card /dev/sci1 ok
12:49:41.062 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfa2
12:49:41.073 CCcam: cam[1] ecm odd ok caid:0x100 id:0x6a pid:0x70b Unknown
12:49:41.371 CCcam: local ecm <- card /dev/sci1 ok
12:49:41.372 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfab
12:49:41.382 CCcam: cam[3] ecm even ok caid:0x100 id:0x6a pid:0x709 Unknown
12:49:41.688 CCcam: local ecm <- card /dev/sci1 ok
12:49:41.689 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfad
12:49:41.698 CCcam: cam[2] ecm odd ok caid:0x100 id:0x6a pid:0x70b Unknown
12:49:42.006 CCcam: local ecm <- card /dev/sci1 ok
12:49:42.015 CCcam: cam[0] ecm odd ok caid:0x100 id:0x6a pid:0x70d Unknown
12:49:50.771 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0x7d4
12:49:51.076 CCcam: local ecm <- card /dev/sci1 ok
12:49:51.077 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfa2
12:49:51.085 CCcam: cam[1] ecm even ok caid:0x100 id:0x6a pid:0x70b Unknown
12:49:51.383 CCcam: local ecm <- card /dev/sci1 ok
12:49:51.383 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfab
12:49:51.391 CCcam: cam[3] ecm odd ok caid:0x100 id:0x6a pid:0x709 Unknown
12:49:51.695 CCcam: local ecm <- card /dev/sci1 ok
12:49:51.695 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfad
12:49:51.704 CCcam: cam[2] ecm even ok caid:0x100 id:0x6a pid:0x70b Unknown
12:49:52.011 CCcam: local ecm <- card /dev/sci1 ok
12:49:52.019 CCcam: cam[0] ecm even ok caid:0x100 id:0x6a pid:0x70d Unknown
12:50:00.754 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0x7d4
12:50:01.059 CCcam: local ecm <- card /dev/sci1 ok
12:50:01.059 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfa2
12:50:01.068 CCcam: cam[1] ecm odd ok caid:0x100 id:0x6a pid:0x70b Unknown
12:50:01.366 CCcam: local ecm <- card /dev/sci1 ok
12:50:01.366 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfab
12:50:01.374 CCcam: cam[3] ecm even ok caid:0x100 id:0x6a pid:0x709 Unknown
12:50:01.676 CCcam: local ecm <- card /dev/sci1 ok
12:50:01.683 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfad
12:50:01.694 CCcam: cam[2] ecm odd ok caid:0x100 id:0x6a pid:0x70b Unknown
12:50:02.002 CCcam: local ecm <- card /dev/sci1 ok
12:50:02.010 CCcam: cam[0] ecm odd ok caid:0x100 id:0x6a pid:0x70d Unknown
12:50:10.753 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0x7d4
12:50:11.058 CCcam: local ecm <- card /dev/sci1 ok
12:50:11.058 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfa2
12:50:11.067 CCcam: cam[1] ecm even ok caid:0x100 id:0x6a pid:0x70b Unknown
12:50:11.363 CCcam: local ecm <- card /dev/sci1 ok
12:50:11.364 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfab
12:50:11.373 CCcam: cam[3] ecm odd ok caid:0x100 id:0x6a pid:0x709 Unknown
12:50:11.675 CCcam: local ecm <- card /dev/sci1 ok
12:50:11.676 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfad
12:50:11.685 CCcam: cam[2] ecm even ok caid:0x100 id:0x6a pid:0x70b Unknown
12:50:11.985 CCcam: local ecm <- card /dev/sci1 ok
12:50:11.994 CCcam: cam[0] ecm even ok caid:0x100 id:0x6a pid:0x70d Unknown
12:50:20.753 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0x7d4
12:50:21.061 CCcam: local ecm <- card /dev/sci1 ok
12:50:21.062 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfa2
12:50:21.073 CCcam: cam[1] ecm odd ok caid:0x100 id:0x6a pid:0x70b Unknown
12:50:21.375 CCcam: local ecm <- card /dev/sci1 ok
12:50:21.375 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfab
12:50:21.383 CCcam: cam[3] ecm even ok caid:0x100 id:0x6a pid:0x709 Unknown
12:50:21.686 CCcam: local ecm <- card /dev/sci1 ok
12:50:21.686 CCcam: local ecm -> card /dev/sci1 0x100(0x06a) sid 0xfad
12:50:21.694 CCcam: cam[2] ecm odd ok caid:0x100 id:0x6a pid:0x70b Unknown
12:50:21.997 CCcam: local ecm <- card /dev/sci1 ok
12:50:22.005 CCcam: cam[0] ecm odd ok caid:0x100 id:0x6a pid:0x70d Unknown
Volgens mij maakt hij per opname een soort van instance aan?
cam[0] [1] [2] [3], echter bij 5 opnames zijn er nog steeds 4 'instances'
Als jij weet hoe dat gaat? ik zie geen prio file
ik heb de laatste ccam geinstalleerd en werk niet met een .cfg file
card reader /dev/sci0
no or unknown card inserted
card reader /dev/sci1
handled 547(547) ecms and 0(0) emms
SECA card 00.571.749.231 entitlements:
0000 MANAGMENT : 2011-07-22
006a CANALDIGITAAL : 2011-07-23
Available providers:
|Caid| Provider | Provider Name| System|
| 100| |Unknown |seca |
| 100| 6a|Unknown |seca |
Ik heb een file aangemaakt met dit erin:
P: 0100:00006A # CANAL DIGITAAL [sECA]
vervolgens de log:
14:28:16.745 CCcam: starting CCcam 2.2.1 compiled on Nov 21 2010@02:20:48
14:28:16.745 CCcam: ============================================================
14:28:16.745 CCcam: online using nodeId 7af2834e62f8134
14:28:16.747 CCcam: read config: cannot open /var/etc/CCcam.cfg or not found
14:28:16.748 CCcam: dvb api3 detected
14:28:16.749 CCcam: DM8000 detected
14:28:16.750 CCcam: create 8 cam device(s)
14:28:22.750 CCcam: seca card found
14:28:23.320 CCcam: card added to broker with caid 100
14:28:23.530 CCcam: readKeyfile: cannot open /var/keys/SoftCam.Key or not found
14:28:23.531 CCcam: readKeyfile: cannot open /var/keys/AutoRoll.Key or not found
14:28:23.531 CCcam: static cw not found or bad
14:28:23.532 CCcam: parsed 1 entries from /var/etc/CCcam.prio
14:28:23.532 CCcam: readProviderfile: cannot open /var/etc/CCcam.providers or no
t found
14:28:23.532 CCcam: readChannelList: cannot open /var/etc/CCcam.channelinfo or n
ot found
14:28:23.533 CCcam: server started on port 12000
14:28:23.536 CCcam: found irdeto caid: 0x622 ecmpid: 0x567 id: 0x0
14:28:23.537 CCcam: found nagra caid: 0x1817 ecmpid: 0x70b id: 0x0
14:28:23.537 CCcam: found nagra caid: 0x1818 ecmpid: 0x71f id: 0x0
14:28:23.537 CCcam: found nagra caid: 0x1819 ecmpid: 0x733 id: 0x0
14:28:23.537 CCcam: found seca caid: 0x100 ecmpid: 0x643 id: 0x6a
14:28:23.537 CCcam: found seca caid: 0x100 ecmpid: 0x70b id: 0x6a
14:28:23.537 CCcam: found seca caid: 0x100 ecmpid: 0x71f id: 0x6c
14:28:23.537 CCcam: found seca caid: 0x100 ecmpid: 0x733 id: 0x6d
14:28:23.537 CCcam: found seca caid: 0x100 ecmpid: 0x76f id: 0x6b
14:28:23.537 CCcam: found viaccess caid: 0x500 ecmpid: 0x57b id: 0x42500
14:28:23.537 CCcam: found viaccess caid: 0x500 ecmpid: 0x58f id: 0x42500
14:28:23.538 CCcam: cam[0] set PMT for sid=fab
14:28:23.538 CCcam: start EMM
14:28:23.539 CCcam: matched prio list 1
14:28:23.546 CCcam: priority 1 for 100:00006A
is dit wat je bedoeld ?
Origineel bericht van: Tonskidutch
correct
en toevoegen I: >>> zie je CCcamlog voor de nagraident.
ciao
I: 1817:00006A # CANAL DIGITAAL [NAGRAVISION]
I: 1818:00006A # TV VLAANDEREN [NAGRAVISION]
I: 1819:00006A # TELE SAT [NAGRAVISION]
zo dus?
Opname
NED1 15.55 Gaat goed
RTL4 15.56 Gaat goed
SBS6 15.57 Gaat goed
NET5 15.58 Gaat fout
NED3 15.59 Gaat fout
[cam0] [cam1] [cam2] maakt ie aan
Wanneer ik schakel naar Net5:
16:01:51.367 CCcam: found seca caid: 0x100 ecmpid: 0x643 id: 0x6a
16:01:51.367 CCcam: found seca caid: 0x100 ecmpid: 0x70b id: 0x6a
16:01:51.367 CCcam: found seca caid: 0x100 ecmpid: 0x71f id: 0x6c
16:01:51.367 CCcam: found seca caid: 0x100 ecmpid: 0x733 id: 0x6d
16:01:51.368 CCcam: found seca caid: 0x100 ecmpid: 0x76f id: 0x6b
16:01:51.368 CCcam: found viaccess caid: 0x500 ecmpid: 0x57b id: 0x42500
16:01:51.368 CCcam: found viaccess caid: 0x500 ecmpid: 0x58f id: 0x42500
16:01:51.368 CCcam: found irdeto caid: 0x622 ecmpid: 0x565 id: 0x0
16:01:51.368 CCcam: found nagra caid: 0x1817 ecmpid: 0x70b id: 0x0
16:01:51.368 CCcam: found seca caid: 0x100 ecmpid: 0x643 id: 0x6a
16:01:51.368 CCcam: found seca caid: 0x100 ecmpid: 0x70b id: 0x6a
16:01:51.368 CCcam: ignore equal capmt version for device 0
16:01:51.369 CCcam: ignore equal capmt version for device 1
16:01:51.369 CCcam: ignore equal capmt version for device 2
Beeld blijft op zwart
wat doe jij daar eigenlijk?
je logs worden wel preciezer maar onduidelijker qua on topic
als je niet heel precies aangeeft welke share dat was, is die viaccess ook een ignore waard.
ciao
And I Love Her
Pat Metheny
Enige wat ik daar deed was naar net5 switchen, meer niet. Geen idee welke share je het over hebt ik heb alleen een canaldigitaal kaart en die zit in het apparaat.
CCcam.prio ziet er nu zo uit:
I: 500:00006A #
Ook met de 0500 toevoeging nog steeds het probleem.
Opname ned1 2 3 en sbs, rest vd zenders op zwart, switch ik naar BVN (FTA) wel beeld frown
01:24:08.256 CCcam: create 8 cam device(s)
In het begin geeft de debug aan dat hij 8 cam devices maakt wat meer dan genoeg zou moeten zijn volgens mij, maar ik zie dat ie max gebruik maakt van 5 (0,1,2,3,4)
nu ja, hoe ze (CanalDIGITAAL) het geflikt hebben, er is een raar probleem sind die nagravision als crypt ertussen staat
(overigens de irdeto ignoreer je niet zag ik)
maar ik kan er verder ook weinig soep van trekken.
het enige dat me nog opkomt is,
opname gaat voor tv instelling?!?
(en
iets met de EPG > want ik zag wel dit nog:
16:01:51.369 CCcam: ignore equal capmt version for device 2)
maar dat lijkt me eerder uitzonderlijk.
ciao
And I Love Her
Pat Metheny
Ik ignore nu wel doe 0500 zoals je aangaf, maar dit helpt ook niets. En opname gaat inderdaad altijd voor tv. Ik heb alle EPG's uitstaan ik gebruik de Rytec XMLTV EPG.
Heb je enig idee wat het nu dan kan zijn?
Is het de kaartlezer van de VU+ DUO die er niet mee overweg kan?
Is het CCcam die er niet mee overweg kan?
Is het openpli die er niet mee overweg kan?
Is het misschien mn zenderlijst?
En waarom melden zich niet meer mensen met dit probleem?
Had gehoopt op wat meer repsonse zodat we met zn allen naar een oplossing kunnen zoeken!
ik schreef al "maar ik kan er verder ook weinig soep van trekken."
dus men zou jouw methodiek 1:1 moeten repliceren om te zien of meer mensen dat probleem hebben of kennen
ik schreef in het verleden ook al dat ik niet meer dan 4 opnames tegelijk heb lopen hetgeen voor mijn doen al exclusief is
maar met CCcam en met Openpli of VTI
?je zenderlijst kun je natuurlijk zelf nog controleren door "bijvoorbeeld" die van mij te gebruiken :D
ciao
And I Love Her
Pat Metheny
  • Moderator
Origineel bericht van: _HarmeN
Ik heb nog nooit de behoefte gehad om zoveel tegelijk van de nederlandse omroepen op te willen nemen, en met het huidige programma aanbod zal dat er ook niet snel van komen gok ik smile
Ik heb het net even getest, ik kwam tot 6 sd kanalen tegelijk (allemaal 5 minuten opnames), allemaal vanaf 1 transponder, en ik kon nog gewoon zappen. Alleen het duurde wel wat langer voordat ik beeld had, normaal gesproken is dat 2-3 sec, nu was het rond de 8 a 9 sec.
Overigens heeft het het ophogen van EMM threads geen enkele zin, EMM's zijn ervoor om je kaart te updaten. Je wilt ECM's, dus het aantal threads dat luistert naar EMM's heeft geen enkele invloed op het wel of niet kunnen openen van kanalen simultaan.
Ik heb verder niets bijzonders staan in mijn config. Alleen mijn cccam eens gestopt en met -dv op de commandline gestart.
Daar zag ik dat hij 8 cammodules aanmaakte, dus in theorie had ik er nog een opname bij moeten kunnen starten en nog kunnen zappen.
Mijn kaart zit in het bovenste slot, maar ik betwijfel eigenlijk of dat anders zou zijn als deze in de onderste zou zitten.
Dat is op zich vreemd, en denk ik jouw probleem.
stukkie van mijn log:
Code:
19:11:50.766 CCcam: cam[0] ecm even ok caid:0x100 id:0x6a pid:0x709  19:11:51.077 CCcam: cam[1] ecm even ok caid:0x100 id:0x6a pid:0x70a 19:11:51.398 CCcam: cam[4] ecm even ok caid:0x100 id:0x6a pid:0x70d 19:11:51.784 CCcam: cam[3] ecm even ok caid:0x100 id:0x6a pid:0x70e19:11:52.164 CCcam: cam[5] ecm even ok caid:0x100 id:0x6a pid:0x711
Als jij maar 4 cam instances ziet in je logging, dan lijkt het mij dat er op een of andere manier bij jou maar 4 cams worden aangemaakt, en bij de mijne 8.
dit is wat CCcam zegt bij starten bij mij:
Code:
19:37:42.453 CCcam: dvb api3 detected19:37:42.455 CCcam: create 8 cam device(s)19:37:48.457 CCcam: seca card found19:37:49.035 CCcam: card added to broker with caid 100
Welk image draai je eigenlijk op jouw VU?
VU+ Duo4kSe  met VTi    VU+ duo2 met VTi
Triax 78, astra 1,2,3, HB
