Als er een opname gestart wordt dan zie ik in de log dit:
Code:
15:34:40.263 CCcam: found irdeto caid: 0x622 ecmpid: 0x567 id: 0x015:34:40.265 CCcam: found nagra caid: 0x1817 ecmpid: 0x70b id: 0x015:34:40.265 CCcam: found nagra caid: 0x1818 ecmpid: 0x71f id: 0x015:34:40.265 CCcam: found nagra caid: 0x1819 ecmpid: 0x733 id: 0x015:34:40.265 CCcam: found seca caid: 0x100 ecmpid: 0x643 id: 0x6a15:34:40.265 CCcam: found seca caid: 0x100 ecmpid: 0x70b id: 0x6a15:34:40.266 CCcam: found seca caid: 0x100 ecmpid: 0x71f id: 0x6c15:34:40.266 CCcam: found seca caid: 0x100 ecmpid: 0x733 id: 0x6d15:34:40.266 CCcam: found seca caid: 0x100 ecmpid: 0x76f id: 0x6b15:34:40.266 CCcam: found viaccess caid: 0x500 ecmpid: 0x57b id: 0x4250015:34:40.266 CCcam: found viaccess caid: 0x500 ecmpid: 0x58f id: 0x4250015:34:40.266 CCcam: found irdeto caid: 0x622 ecmpid: 0x568 id: 0x015:34:40.267 CCcam: found nagra caid: 0x1817 ecmpid: 0x70c id: 0x015:34:40.267 CCcam: found nagra caid: 0x1818 ecmpid: 0x720 id: 0x015:34:40.267 CCcam: found nagra caid: 0x1819 ecmpid: 0x734 id: 0x015:34:40.267 CCcam: found seca caid: 0x100 ecmpid: 0x644 id: 0x6a15:34:40.267 CCcam: found seca caid: 0x100 ecmpid: 0x70c id: 0x6a15:34:40.267 CCcam: found seca caid: 0x100 ecmpid: 0x720 id: 0x6c15:34:40.267 CCcam: found viaccess caid: 0x500 ecmpid: 0x57c id: 0x4250015:34:40.267 CCcam: found seca caid: 0x100 ecmpid: 0x734 id: 0x6d15:34:40.268 CCcam: found seca caid: 0x100 ecmpid: 0x770 id: 0x6b15:34:40.268 CCcam: found viaccess caid: 0x500 ecmpid: 0x590 id: 0x4250015:34:40.268 CCcam: found irdeto caid: 0x622 ecmpid: 0x566 id: 0x015:34:40.268 CCcam: found nagra caid: 0x1817 ecmpid: 0x70c id: 0x015:34:40.268 CCcam: found seca caid: 0x100 ecmpid: 0x644 id: 0x6a15:34:40.268 CCcam: found seca caid: 0x100 ecmpid: 0x70c id: 0x6a15:34:40.269 CCcam: ignore equal capmt version for device 015:34:40.269 CCcam: ignore equal capmt version for device 115:34:40.269 CCcam: cam[2] set PMT for sid=fac
Bij opname 4 (die mislukt) komt dit niet tevoorschijn.
Als ik de EMM THREADS op 6 zet veranderd er niet echt veel, maar als ik naar de zender switch die mislukt start hij wel een nieuwe cam[x] instance. Dit gaat dus niet automatisch en dat is dus het probleem vermoed ik. Maar waarom hij het niet meer automatisch doet sinds de aanpassingen bij canaldigitaal is mij een raadsel.
/edit als ik dus de emm threads niet aanpas (dus staat uit) dan blijft het scherm gewoon zwart, met de aanpassing naar 6 heb ik dan wel beeld op het kanaal van de opname(s) die mislukt
VU+ ULTIMO 4K (OPENPLi-8.1) :: 1x DVB-C FBC :: ZIGGO
VU+ ULTIMO 4K (OPENPLi-8.1) :: 1x DVB-C FBC en 1x DVB-S2 FBC :: ZIGGO
  • Reacties 96
Origineel bericht van: _HarmeN
Opname ned1,2,3, gaan goed, sbs6 en net5 mislukken.
RTL4 blijft op zwart, RTL5 blijft op zwart, SBS6 blijft op zwart, RTL7 blijft op zwart, RTL8 blijft op zwart, NET5 blijft op zwart, VERO blijft op zwart.
Wanneer ik een 'zwarte zender' laat staan komt uiteindelijk de volgende melding in beeld:
Zender ongeldig!
(Timeout reading PAT)
OF
Geen data op transponder!
Hier presies het zelfde, ik heb niets bijzonders in cccam.cfg staan.
Na 3 opnames zapt de Vu erg langzaam.
Dolf.
VU+ Ultimo, OpenPLI, 2TB hdd. CCcam 2.3.0
VU+ Duo, OpenPLI.
Dreambox 7025+, OpenPLI image, Swapfile 64mb op CF kaart, Magic skin.
iPad met Dreambox live.
Misschien is het wel CCcam die er niet mee overweg kan ofzo?
Ik ga eens proberen of ik mgcamd aan de praat krijg..
Gast Tha Great Mac
Vreemd eigenlijk dat CCcam dit niet zou kunnen op de Vu+, op andere ontvangers gaat het wel goed.
Het is zoeizo een heel raar probleem, 1 ding is zeker als ik het niet kan oplossen zeg ik CD op smile
En dan? Ga je naar een kabelmaatschappij die je hun hardware dwingt te gebruiken en je nog minder vrijheid hebt?
Ik kan hier op de ET9000 gewoon 5 opnames tegelijk hebben lopen die allemaal goed gaan.
CanalDigitaal, blijf met je vingers van onze opnamemogelijkheden af!
Xtrend ET-9000, Samsung HD322HJ 320Gb, OpenPLi 2.1
Visiosat G4 Quadro, Astra 19.2, Hotbird 13.0, Astra 28.2, Astra 23.5
Mja ook weer zo, ik ga kijken of ik mgcamd aan de praat krijg als het daar ook mee is moet het iets met de kaartlezer zijn van de vu ofzo ? frown
Als ik mgcamd 1.35a-r5 vanuit het menu download geeft hij links onderin, cannot parse this emu. Lijkt me niet goed?
werkt mgcamd wel op openpli 2?
_HarmeN,
denk dat je met mgcam minder goed zult scoren
dan beter de OSCAM + CCcam... daar die oscam veel beter omgaat met meerdere caid's simulcrypt
ciao
Mr. Blue Sky
Electric Light Orchestra
Ok dan bedoel je dus:
oscam-cs (1.0-r0) OSCAM as cardserver
cccam (2.2.1-r0)
Gast Tha Great Mac
Dat wordt ongetwijfeld bedoeld ja.
Ok deze heb ik geinstalleerd, na heel lang klooien van mijn kant geen beeld. Toen heb ik in een ander topic hier op sat4all het volgende gevonden:
oscam.server:
[reader]
label = canal_digitaal
enable = 1
protocol = mouse
device = /dev/com1
services =
caid = 0100
detect = cd
mhz = 358
cardmhz = 358
ident =
group = 1
emmcache = 1,3,2
lb_weight = 100
oscam.conf:
[global]
usrfile = oscamuser.log
logfile = oscam.log
nice = -1
maxlogsize = 1024
preferlocalcards = 1
saveinithistory = 1
readerrestartseconds = 4
resolvegethostbyname = 1
[newcamd]
port = 12345@0100:00006A
key = 0102030405060708091011121314
allowed =
keepalive = 1
mgclient = 1
[cccam]
port = 12345
reshare = 0
ignorereshare = 0
version = 2.2.1
updateinterval = 0
minimizecards = 0
keepconnected = 1
[webif]
httpport = 8080
httpuser = administrator
httppwd = 1234
httprefresh = 5
httpallowed = 127.0.0.1,192.168.0.1
httphideidleclients = 0
httpreadonly = 0
httpsavefullcfg = 0
oscam.user:
[account]
user = client
pwd = password
group = 1
monlevel = 2
au = canal_digitaal
caid = 0100
ident = 0100:000000,00006A
Dit heb ik gewoon eens in alle bestanden gezet, hiermee kom ik tot 6 opnames, ned1,2,3,sbs6,net5,rtl4
Gast Tha Great Mac
Netjes toch? 6 Opnames...
Weet niet hoe ik het voor elkaar kreeg maar het werkt nu niet meer frown. Volgens mij loopt het ook niet via oscam. Als ik via telnet oscam kill blijft alles gewoon doorlopen. Mgoed zoveel verstand heb ik er ook weer niet van frown
Origineel bericht van: Dolf
Dolf.
Maar wij kijken bijna nooit live TV, er worden door ons gezin ongeveer 60 opnames per week met een timer (autotimer) gemaakt maar zie niet dat er één mislukt. En ik zie wel eens 4 opnames lopen en ook nog een opname van de DM7025 (interne share) lopen. Ik kan dan nog zappen op de transponders waar van wordt opgenomen.
Heb je al een test gedaan waarbij je meerdere opnames start van uit een timer met ruime tijd tussen het starten van de opname? Mogelijk is er dan meer tijd voor Cccam om alles uit te geven.
Dolf.
VU+ Duo, OpenPLI.
