Johan45 Geplaatst: 6 augustus 2011 Geplaatst: 6 augustus 2011 Origineel bericht van: RayhTec Veel plezier, Origineel bericht van: READ ME 6071 RayhTec V3.12g build3 firmware for Philips DSX6071 (August 2011) New implemented: MHW: PMT Parsing improved for better overall performance. Memory usage improved BISS working Teletext subtitling improved On screen message when smartcard inserted/extracted EMU: CanalSat 19.2 provider 022610 added (nano DF not yet working) Remarks: Take care of correct communication protocol in antenna configuration menu. For Auto Update Seca card in decoder is needed and Blocker OFF. Zapspeed is independant from +B75 adjustement Features: Menu languages: Dutch, English (Some French is implemented) Seca1, Seca2 and Seca 3 (Merlin) smartcard support (managed by HDL). Cardemulator support: SECA1/SECA2 8 providers VIACCESS 2.3/2.6/3.0 20 providers (Viaccess 2.6/3.0 need 16 Byte opkey in cardemu, use button E). NAGRAVISION2 5 providers IRDETO1/BETACRYPT NOT implemented IRDETO2 9 providers. ProviderId 000622, Fill opkey key X into X and X+1 CRYPTOWORKS 16 providers CONAX NOT implemented. Do not edit Conax keys in cardemu as they are used for CDW! BISS/CDW 12 providers 2000 channels and 254 transponders DiSEqC 1.0 for switch DiSEqC 1.2 for rotor Automatic date/time adjustement at power up. EMM Blocker: Blocks all emm's to smartcard and emulator by disabling EMM loader Servicecard support Remote key option (was used in the past for Funcard) No interactivity Symbolrate 6071: 1…32 MS/s, 6072: 12…30 MS/s EPG according to MediaHighWay and DVB standard Fastscan for CDN and TVV Baudrate adjustable for Advanced Serial Communications (SAC): --> Baudrate adjustment in Menu, 4, 1, 9. Setting will be saved at standby. --> Choose +, B, 7 for set up SAC: 4 for MediaBox Communicator 5 for sssp for CCCam or NewCamd server. Takes effect on channel switch. Works simultanuously with card in decoder. Setting will be saved at standby --> Tested software: HDVB (Reset button in program has to be used often) Fausto (Use other program for opening COM port communication and set 1.5 stopbit) DSR9500Share Remote key functions: A : Tune on channels which broadcasts radiochannels and press this key B : Picture on screen freezes C : No function D : Stream Grabber (Not all options are working anymore) E : zaplist 0 : Returns to previous watched channel + : Some channel information and access to servicemenu ( INFO : Shows now/next information. When inputting keys this is character F EPG : Electronic Program Guide MHW EPG : Working for Canal Digitaal, CanalSat, Cyfra. Sky Italia and D+ is not working DVB EPG : All channels which are broadcasting EPG according to this standard. (Premiere, German FTA, ORF, ABSat, SRG, for PolSat it is needed sometimes to press arrow left few times MENU : Access to Main menu PREF : Switch on/off preference list De 6071 firmware is hier te downloaden. Vult u rustig aan !!!
