[OpenBox] Er is weer nieuwe openbox firmware voor de s9 en S10
zie hier effe
0622:000000:07D4 "Canal Digitaal - RTL 4 [i2]"
0622:000000:07D5 "Canal Digitaal - RTL 5 [i2]"
0622:000000:07D6 "Canal Digitaal - RTL 7 Nederland [i2]"
0622:000000:07DA "Canal Digitaal - TV Oranje [i2]"
0622:000000:07DF "Canal Digitaal - Discovery Channel Nederland [i2]"
0622:000000:07E4 "Canal Digitaal - Animal Planet [i2]"
0622:000000:07E9 "Canal Digitaal - Eurosport [i2]"
0622:000000:07EE "Canal Digitaal - Test 97 [i2]"
0622:000000:07F3 "Canal Digitaal - RTL 8 [i2]"
0622:000000:07F9 "Canal Digitaal - Hallmark Benelux [i2]"
0622:000000:07FD "Canal Digitaal - Dorcel TV [i2]"
0622:000000:0FA5 "Canal Digitaal - Film1.1 [i2]"
0622:000000:0FA6 "Canal Digitaal - Sport1 Netherlands [i2]"
0622:000000:0FA7 "Canal Digitaal - Film1.2 [i2]"
0622:000000:0FAB "Canal Digitaal - Nederland 1 [i2]"
0622:000000:0FAC "Canal Digitaal - Nederland 2 [i2]"
0622:000000:0FAD "Canal Digitaal - Nederland 3 [i2]"
0622:000000:0FAE "Canal Digitaal - Comedy Central Nederland [i2]"
0622:000000:0FAF "Canal Digitaal - National Geographic NL [i2]"
0622:000000:0FC8 "Canal Digitaal - Classic FM [i2]"
0622:000000:0FCD "Canal Digitaal - Q-Music [i2]"
0622:000000:138C "Canal Digitaal - Net 5 [i2]"
0622:000000:138D "Canal Digitaal - SBS 6 [i2]"
0622:000000:1397 "Canal Digitaal - TMF - The Music Factory Nederland [i2]"
0622:000000:139C "Canal Digitaal - Veronica [i2]"
0622:000000:13A4 "Canal Digitaal - Film1.3 [i2]"
0622:000000:13A6 "Canal Digitaal - ECV 1 [i2]"
0622:000000:13A8 "Canal Digitaal - NL-Radio 2 [i2]"
0622:000000:13A9 "Canal Digitaal - NL-3FM [i2]"
0622:000000:13AA "Canal Digitaal - NL-Radio 4 [i2]"
0622:000000:31F4 "Canal Digitaal - Man-X [i2]"
0622:000000:4F56 "Canal Digitaal - ZoneReality [i2]"
0622:000000:4F57 "Canal Digitaal - Extreme Sports [i2]"
Dreambox 900UHD   4x twin lnb 1x bosat 1.50m .Dreambox 7020hd v2 Dreambox 800 Dreambox 8000  Dreambox 800se
Dreambox 500HD   Sab unix triple    Xsarius Galaxy 4K gigablue trio Gigablue HD Quad Plus  Zgemma H7 Cabel en Sat
Volgens mij zou dan de seca kaart de irdeto commandos krijgen?
lijkt mij niet zo zinvol.
Naar mijn weten werkt de irdeto kaart ook zonder replace list, is namelijk niet getunneld.
Bolt HD, strong srt8000 sattracker 4, srt4125 concord 1.05, hotbird, astra 1,2,3
verhelderend.
Waar kan ik info vinden welk "nummer" bij bv Nederland 2 HD of Eredivise live hoort.
Ik wil de logica snappen.
Gast skybox_ontdekker
beste mensen
een jaartje geleden kocht ik via marktplaats een skybox openbox s9 pvr. Via de verkoper had ik er dan ook een jaar lang alle zenders bij voor eenmalig bedrag. De zenders deden het een week, en daarna kwam er steeds vaker scrambled op. Er was geen support.
Ik wil toch graag hd tv gaan kijken op de ontvanger.
Wat ik allemaal heb gedaan:
nieuwe firmware via usb gedraaid, ging goed. Volgens deze site de goede versie.
skybox ziet nu ook de smartcard van canaldigitaal die ik insteek, echter geen zender. Alleen de free on air. Ook een heractivatie van het kaartje heeft geen resultaat.
Ik heb een replacelist gemaakt volgens dit topic, helpt hem niet.
Ik heb een internetverbinding en een utp kabel naar de modem lopen.
Verder heb ik er dus een smartcard van canal digitaal in... hierop zit een basis abonnenment.
Heel graag zou ik met of zonder canal digitaal tv willen kijken. Met name de normale zenders en dan in HD.
Kan iemand aangeven wat ik nog moet doen?
Alvast veel dank!
(nu ik jullie op dit forum zo zie, begrijp ik dat de skybox nog vele mogelijkheden meer heeft dan alleen hd tv kijken via canal digitaal)
jij had er een abbo voor wan sharing bij gekocht, dat is illegaal en mag hier niet worden besproken, wat ik nog wel kan zeggen is dat het met cccam werkt en dat de adressen in C lines staan, bij het upgraden van de firmware zijn die lijnen waarschijnlijk gewist.
legaal kun je dus alleen naar de zenders in het basis pakket kijken door de prio lijst.
MVG. Gerard
If history repeats itself, and the unexpected always happens, how incapable must Man be of learning from experience.
-George Bernard Shaw
dat is juist ook mijn bedoeling!
echter, de skybox is hiervoor nog niet ready..
hij ziet bij cccam ed allemaal geen informatie
hij leest mijn smartcard waar ik maandelijks netjes voor betaal ook niet uit.
Ik zoek alle juiste files om de skybox s9 te laten werken met canal digitaal. En ik hoop dat iemand me hierbij kan helpen.
Ik weet inmiddels wel hoe het werkt met updaten via usb en waar ik moet zijn in het menu.
Ik hoop dat mijn bedoelingen nu duidelijker zijn. Ik zou het jammer vinden als ik de skybox niet meer kan gebruiken.
zul je eerst moeten weten of je kaart up2date is.
Welke firmware heb je er nu in?
met een basis abbo heb je alleen 1,2,3 in HD
Hi Gerard,
kun je uitleggen wat de prio lijst doet?
wat er in moet staan?
Ik heb alleen een replace.list en dan heb ik beeld.
Wat doet de prio lijst? en wat doet het beter/of niet dan de replace.list?
laad via usb de lijst start normaal dan na het uppen ,,geeft ie mismatch .er gebeurd verder niks , 2 keer de lijst abs ingeladen .steeds hetzelfde antwoordt het werkt bij mij niet
openbox s10
.abs is enkel de firmware, eventueel incl. kanalen.
TP_PROG.dbs is de kanalen lijst.
ik heb de 1508 firmware geinstalleerd via usb
met deze abs file doet kan ik aangeven dat ik de 19,2 en 23,5 astra kan ontvangen. Hij vindt ook een 1800 zenders.
Echter, ook al zegt hij smartcard inserted, hij leest geen canal digitaal in. Alle niet vrije zenders blijven op scrambled staan.
Alle cccam files ed. zijn leeg, of ziet hij niet..
Kan ik allereerst ergens de juiste abs file vinden voor de S9 waarbij ik ook canal digitaal uit kan lezen?
Dan heb ik een begin..alvast dank!
prio file
ik heb een prio file van dit topic gehaald en met succes van de usb ingeladen. Bij info staat prio file ok.
Reboot ... echter, nog steeds alle canal digitaal zenders gewoon op scramble..
Moet ik nog meer files inladen?
