Gast Geplaatst: 27 augustus 2002 Geplaatst: 27 augustus 2002 Hi everybody! I'm a complete newbie to this digital satellite thing and am interested in buying a digital system to receive some new tv channels. Since I'm portuguese, I'm very interested in receiving the portuguese channels, like Sport TV, RTP, SIC, TVi, etc. but Sport TV most of all, because they air a lot of soccer matches. I'm also interested in buying a programmer, so that I can program the cards myself every month or so to be able to watch the scrambled transmisions. So here are my questions: - What brand of receiver should I purchase in order to receive the channels mentioned above? I understood that Humax and Philips are the main models??? - How large should the dish be minimal? - What kind of programmer and cards should I purchase? - Where can I download the new codes monthly to program on the cards? Do you have an URL for this information? Please give me all your advice and opinions, since it will help me a lot. Thanks in advance, With kind regards, Vitor
prutsie Geplaatst: 27 augustus 2002 Geplaatst: 27 augustus 2002 Hi Vitor. because you're Portugese I think it's better to try to locate Portugese bulletinboards. I'm sure there are some in Portugal where most if not all your questions are answered in Portugese. The problem is this is a Dutch bulletinboard, and although there is some info to be found about Portugese channels it is all in Dutch. You best can use www.google.com to locate satellite bulletin boards in your native language, or English ones. best regards, Peter. Niet gehinderd door enige vorm van technische kennis zet ik onbevangen overal mijn schroevendraaier en soldeerbout in.
Gast Geplaatst: 27 augustus 2002 Geplaatst: 27 augustus 2002 Hoi Peter, Nederlands is geen probleem voor mij! <img src="/ubbthreads/images/icons/wink.gif" alt="" /> Ik spreek de nederlandse taal namelijk vloeiend. Echter, ik heb mijn bericht vanavond op voornamelijk engelstalige forums gezet, dus vandaar dat ik ook hier mijn bericht gecopied en gepaste heb. Zorgt er weer voor dat ik het bericht in het nederlands moet gaan vertalen.... Toch?! Dus Peter, mocht je mij alsnog willen helpen met informatie op mijn vragen, dan hoor ik dat graag! <img src="/ubbthreads/images/icons/grin.gif" alt="" /> Vitor
prutsie Geplaatst: 27 augustus 2002 Geplaatst: 27 augustus 2002 Wat een BOEF, mij een beetje laten zweten <img src="/ubbthreads/images/icons/grin.gif" alt="" /> er zijn diverse mogelijkheden, het ligt er een beetje aan wat je uit wilt geven, en wat je wil zien. wat je eerst moet doen is eens bij www.satcodx.com of www.lyngsat.com kijken waar de tv stations zitten die je wilt kijken, of je deze hier wel kan ontvangen, en wat voor codering ze gebruiken. als je dit weet dan kan je gaan shoppen voor een schotel, en een ontvanger en decodermodule. een philips lijkt me dan al snel niet de juiste keuze, maar meer een allround ontvanger zoals bijvoorbeeld de door jou aangehaalde Humax. er zijn er echter veel meer, en je kan je het beste laten voorlichten bij een sat speciaalzaak. dan kan je ook gelijk met meerdere ontvangers spelen en is de keuze beter te maken. decodermodules heb je ook in allerlei smaken, de meeste en populairste worden hier op het bord veelvuldig besproken in het CI forum. wat de key's en files betreft, daar kunnen we je helaas niet mee helpen, maar als je een beetje bent ingelezen struikel je erover op het internet. dit is denk ik de laatste stap die je moet zetten en dat is zeker niet de meest ingewikkelde. een verplichte site is Duwgati ik hoop dat je hier weer wat verder mee komt, en we zien de vragen wel weer verschijnen. groeten, Peter. Niet gehinderd door enige vorm van technische kennis zet ik onbevangen overal mijn schroevendraaier en soldeerbout in.
Alventali Geplaatst: 27 augustus 2002 Geplaatst: 27 augustus 2002 @vads Hoi Vads Voorwat betreft welke receiver je wil zou ik toch ff rondneuzen op dit board bij de verschillende merken receivers.Dan kun je een receiver zoeken die jou het prettigst lijkt. Er zijn receivers die(mits Gepached)meerdere coderingen aan. Zoals b.v De nokia 9200/9500 of een Humax5400(z) of Fortec,Hyundai,Philips en Strong Wat beteft de grote van de schotel ligt er ook weer aan welke satteliet je wilt ontvangen. Een satteliet die ver weg staat heeft een grotere schotel nodig dan eentje die dichterbij staat zoals b.v de Astra en de Hotbird satteliet. Dan komt daar nog bij wil je een vaste opstelling of een draaibare (voor meerdere sattelieten dus)Of een vaste met 2 koppen. Wat programmer betreft een mastera of een multipro. En die laatste vraag daar zijn meeste hier niet van gediend.(het vragen om file's en waar te halen)het is hier namelijk geen vrijschakelbord om onbetaald naar pay tv kanalen te kijken.En om te voorkomen dat dit hele goede board door C+ of een andere provider gesloten wordt wordt dat ook niet getollereerd door de moderators van het board. Maar als je weet welke receiver je wilt.Weet je ook voor welke codering deze gebruikt wordt. Dan ff zoeken met b.v. Google en er gaat een wereld voor je open. Groetjes Alv Groetjes AlvVisiosat bi sat met 4 LNB's & een kabel aansluitingVU+ Duo met 2* DVB-S2, en een Vu+ Duo2 met 2* DVB-C
Alventali Geplaatst: 27 augustus 2002 Geplaatst: 27 augustus 2002 Verdorie weer net wat laat <img src="/ubbthreads/images/icons/confused.gif" alt="" /> <img src="/ubbthreads/images/icons/confused.gif" alt="" /> Nou ja met deze twee verhaaltje's moet je een behoorlijk end kunnen komen. <img src="/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/ubbthreads/images/icons/smile.gif" alt="" /> Groetjes Alv Groetjes AlvVisiosat bi sat met 4 LNB's & een kabel aansluitingVU+ Duo met 2* DVB-S2, en een Vu+ Duo2 met 2* DVB-C
