Irdeto 2 + CCCam 2.2.1 = wel geluid maar geen beeld
  • 1 maand later...
Ik brei even verder, want het is ook niet gelukt om de TVBS Irdeto2-kaart te tonen op een DM7025+ met de Smargo Smartreader+. Ik heb nog altijd enkel geluid en geen beeld.
CCcam Smargo settings:
De dingen die uit staan heb ik al geprobeerd.
SERIAL READER: /dev/ttyUSB0 smartreader+
CAMKEY: /dev/ttyUSB0 00 00 00 00 00 00 00 00
CAMDATA: /dev/ttyUSB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
TRY ALL CHIDS: /dev/ttyUSB0
#SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB0 6000000
#SMARTCARD WRITE DELAY: /dev/ttyUSB0 10000
#SMARTCARD SID ASSIGN : /dev/ttyUSB0 6
dmesg zegt:
[AUDIO] enable sync
MPEG: Sequence header!
Mpeg errors gaan eindeloos door.
CCcam logs met kaart in:
/dev/sci1
15:04:58.873 CCcam: irdeto card found
15:05:00.381 CCcam: card added to broker with caid 604
15:05:18.128 CCcam: found irdeto caid: 0x604 ecmpid: 0x12d id: 0x0
15:05:18.128 CCcam: cam[0] set PMT for sid=3
15:05:18.129 CCcam: start EMM
15:05:18.191 CCcam: EMM demux 1 set
15:05:18.192 CCcam: EMM: start filter on irdeto emmpid: 0xf0 caid: 0x604 id: 0x0
15:05:18.279 CCcam: chid 001C
15:05:18.280 CCcam: local ecm -> card /dev/sci1 0x604(0x000) sid 0x003
15:05:18.531 CCcam: local ecm <- card /dev/sci1 ok
15:05:18.531 CCcam: cam[0] ecm even ok caid:0x604 id:0x0 pid:0x12d Nova+SCT/Satisfaction/TVB+Sex/ABS/Showtime+ART+JSC/CTI/Bulsatcom/DSTV/TVHOME (13E/9E/5W/7W/15W/39E/68E/DVB-C)
15:05:27.460 CCcam: chid 001C
15:05:27.460 CCcam: local ecm -> card /dev/sci1 0x604(0x000) sid 0x003
15:05:27.702 CCcam: local ecm <- card /dev/sci1 ok
15:05:27.703 CCcam: cam[0] ecm odd ok caid:0x604 id:0x0 pid:0x12d Nova+SCT/Satisfaction/TVB+Sex/ABS/Showtime+ART+JSC/CTI/Bulsatcom/DSTV/TVHOME (13E/9E/5W/7W/15W/39E/68E/DVB-C)
15:05:35.423 CCcam: local emm -> card /dev/sci1 0x604(0x000)
15:05:35.629 CCcam: local emm <- card /dev/sci1 ok
/dev/ttyusb0
16:00:31.688 CCcam: irdeto card found
16:00:33.032 CCcam: card added to broker with caid 604
16:01:54.338 CCcam: found irdeto caid: 0x604 ecmpid: 0x65 id: 0x0
16:01:54.338 CCcam: cam[0] set PMT for sid=1
16:01:54.338 CCcam: start EMM
16:01:54.399 CCcam: EMM demux 1 set
16:01:54.400 CCcam: EMM: start filter on irdeto emmpid: 0xf0 caid: 0x604 id: 0x0
16:01:54.507 CCcam: chid 001A
16:01:54.507 CCcam: local ecm -> card /dev/ttyUSB0 0x604(0x000) sid 0x001
16:01:54.683 CCcam: local ecm <- card /dev/ttyUSB0 ok
16:01:54.683 CCcam: cam[0] ecm odd ok caid:0x604 id:0x0 pid:0x65 Nova+SCT/Satisfaction/TVB+Sex/ABS/Showtime+ART+JSC/CTI/Bulsatcom/DSTV/TVHOME (13E/9E/5W/7W/15W/39E/68E/DVB-C)
Dit is de transponder:
http://nl.kingofsat.net/tp.php?tp=2221
Ik zie er niets bijzonders aan die TVB-zenders, maar ik begin te vrezen dat dit een hardware-probleem is.
aangepast door Jay Jay
SERIAL READER : /dev/usb/tts/0 smartreader+
SMARTCARD CLOCK FREQUENCY: /dev/usb/tts/0 6000000
CAMKEY: /dev/usb/tts/0 00 00 00 00 00 00 00 00
CAMDATA: /dev/usb/tts/0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
TRY ALL CHIDS : /dev/usb/tts/0
SERIAL READER : /dev/usb/tts/1 smartreader+
SMARTCARD CLOCK FREQUENCY: /dev/usb/tts/1 6000000
CAMKEY: /dev/usb/tts/1 00 00 00 00 00 00 00 00
CAMDATA: /dev/usb/tts/1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
TRY ALL CHIDS : /dev/usb/tts/1
