Ik probeer in oscam de ECM tijden wat te verbeteren, omdat bij sommige opnames kortstondige freezes ontstaan.
Maar het is mij niet gelukt.
Het probleem is vanaf 3 draadjes van mij kaart.
Met 1 heeft hij al 310ms, de volgende meer.
Heeft iemand een idee wat het probleem kan zijn.
Hieronder mijn log van oscam.
Nico
2012/01/23 22:22:53 767020A0 c DVBApi (0100&00006A/5230/64:A854): found (637 ms) by cd_down (1 of 0)
2012/01/23 22:23:02 767020A0 c DVBApi (0100&00006A/1B6C/64:808E): found (332 ms) by cd_down (1 of 0)
2012/01/23 22:23:02 767020A0 c DVBApi (0100&00006A/1B67/64:C6E3): found (480 ms) by cd_down (1 of 0)
2012/01/23 22:23:02 767020A0 c DVBApi (0100&00006A/1B7B/64:E519): found (799 ms) by cd_down (1 of 0)
2012/01/23 22:23:03 767020A0 c DVBApi (0100&00006A/521C/64:B517): found (333 ms) by cd_down (1 of 0)
2012/01/23 22:23:03 767020A0 c DVBApi (0100&00006A/5230/64:B1DA): found (651 ms) by cd_down (1 of 0)
2012/01/23 22:23:12 767020A0 c DVBApi (0100&00006A/1B6C/64:953F): found (333 ms) by cd_down (1 of 0)
2012/01/23 22:23:12 767020A0 c DVBApi (0100&00006A/1B67/64:6D1A): found (480 ms) by cd_down (1 of 0)
2012/01/23 22:23:12 767020A0 c DVBApi (0100&00006A/1B7B/64:796D): found (800 ms) by cd_down (1 of 0)
2012/01/23 22:23:13 767020A0 c DVBApi (0100&00006A/521C/64:4CDC): found (333 ms) by cd_down (1 of 0)
2012/01/23 22:23:13 767020A0 c DVBApi (0100&00006A/5230/64:0C4A): found (651 ms) by cd_down (1 of 0)
2012/01/23 22:23:22 767020A0 c DVBApi (0100&00006A/1B6C/64:86CF): found (333 ms) by cd_down (1 of 0)
2012/01/23 22:23:22 767020A0 c DVBApi (0100&00006A/1B67/64:18AC): found (480 ms) by cd_down (1 of 0)
2012/01/23 22:23:22 767020A0 c DVBApi (0100&00006A/1B7B/64:F6B7): found (801 ms) by cd_down (1 of 0)
2012/01/23 22:23:23 767020A0 c DVBApi (0100&00006A/521C/64:A102): found (332 ms) by cd_down (1 of 0)
2012/01/23 22:23:23 767020A0 c DVBApi (0100&00006A/5230/64:3A4F): found (650 ms) by cd_down (1 of 0)
2012/01/23 22:23:32 767020A0 c DVBApi (0100&00006A/1B6C/64:1BFF): found (337 ms) by cd_down (1 of 0)
2012/01/23 22:23:32 767020A0 c DVBApi (0100&00006A/1B67/64:F647): found (484 ms) by cd_down (1 of 0)
2012/01/23 22:23:32 767020A0 c DVBApi (0100&00006A/1B7B/64:770B): found (804 ms) by cd_down (1 of 0)
2012/01/23 22:23:33 767020A0 c DVBApi (0100&00006A/521C/64:4A07): found (333 ms) by cd_down (1 of 0)
2012/01/23 22:23:33 767020A0 c DVBApi (0100&00006A/5230/64:E784): found (650 ms) by cd_down (1 of 0)
aangepast door ikbennico
@ theparasol
Blij dat te lezen dat daarin het het probleem niet aan de ECM tijden ligt,
Maar het is echt een decodering probleem, omdat ik de opname file naar mijn pc gezet is en afgespeeld.
Daar zag ook de freezes.
Het zit niet op alle opnames.
Nico
gebruik je ecmratelimiter van oscam? zoja staat die toevallig op 3 oid?
Tot nu toe heb ik nog geen(op mijn oranje kaart) CHID-lock problemen op mijn box gehad.(misschien is het nog niet mijn beurt)
Als het zover is gaat die ecmratelimiter erop.
Nico
Ow... zie nu pas dat je vu+ duo hebt. Die hikups zijn iets wat door de kernel V3 veroorzaakt worden. Loopt op openpli al een draadje over!
Kom, vertel? ;) we mogen toch wel kennis delen!
ciao
Mr. Blue Sky
Electric Light Orchestra
Bedankt voor de tip, ik zal het daar eens opzoeken hoe dat zit.
Ik begon al oscam de schuld te geven, ik dacht op een gegeven moment om een combi van oscam+cccam op mijn box te zetten.
Ik heb deze box pas deze maand aangeschaft.
Dus zoveel ervaring heb ik nog niet met deze box.
Nico
  • 4 maanden later...
Heeft iemand wellicht een link naar dit draadje? Ik heb gezocht maar niet gevonden bij Pli.
Ik heb op de VU+ ook regelmatig freezes/hickups maar ik kom er niet achter wat de oorzaak is.
VU+ Duo + Multytenne 45
Meestal met de laatste PLi
Pana TH-42PV70
XBMC/ASrock ion 330/Wii/ch3snas/TX-SR707/svs 25-31 PCi
