Hoi iedereen,
Ik kijk al een tijdje digitenne met vdr en oscam. Dit heeft altijd gewerkt. Tot ongeveer een week geleden. De versleutelde kanalen worden niet meer opgenomen. In de logfile van oscam zie ik nu deze meldingen langskomen:
2012/02/05 18:22:34 F44BA700 r Error processing ecm for caid 0B00, srvid 006F (servicename: 0B00:006F unknown) on reader reader1.
2012/02/05 18:22:34 F44AE700 c user2 (0B00&00E030/006F/47:22AA): not found (155 ms) by reader1 (of 1 avail 1)
2012/02/05 18:22:34 F44AE700 c user2 (0B00&00E030/006F/47:22AA): not found (0 ms) by reader1 (of 1 avail 1)
2012/02/05 18:22:44 F44BA700 r Error processing ecm for caid 0B00, srvid 006F (servicename: 0B00:006F unknown) on reader reader1.
2012/02/05 18:22:44 F44AE700 c user2 (0B00&00E030/006F/47:3D86): not found (152 ms) by reader1 (of 1 avail 1)
2012/02/05 18:22:44 F44AE700 c user2 (0B00&00E030/006F/47:3D86): not found (0 ms) by reader1 (of 1 avail 1)
Meldingen tijdens opstarten van oscam:
2012/02/05 18:26:41 D287D700 s waiting for local card init
2012/02/05 18:26:41 D286F700 r reader thread started (thread=D286F700, label=reader1, device=/dev/ttyUSB0, detect=cd, mhz=500, cardmhz=500)
2012/02/05 18:26:41 D287B700 h HTTP Server listening on port 8888
2012/02/05 18:26:44 D286F700 r reader1 card detected
2012/02/05 18:26:48 D286F700 r ATR: 3B 24 00 30 42 30 30
2012/02/05 18:26:49 D286F700 r Maximum frequency for this card is formally 5 Mhz, clocking it to 5.00 Mhz
2012/02/05 18:26:51 D286F700 r type: Conax, caid: 0B00, serial: 1428098758, hex serial: 551f0ec6, card: v64
2012/02/05 18:26:51 D286F700 r Providers: 1
2012/02/05 18:26:51 D286F700 r Provider: 1 Provider-Id: 000000
2012/02/05 18:26:51 D286F700 r Provider: 1 SharedAddress: 002A8F87
2012/02/05 18:26:51 D286F700 r found cardsystem conax
2012/02/05 18:26:51 D286F700 r Package: 1, id: 1010, classes: 0100000F, date: 2011/12/01 - 2011/12/31, name: Digitenne
2012/02/05 18:26:51 D286F700 r Package: 2, id: 1010, classes: 0100000F, date: 2011/11/01 - 2011/11/30, name: Digitenne
2012/02/05 18:26:51 D286F700 r [conax-reader] ready for requests
2012/02/05 18:26:51 D287D700 s init for all local cards done
2012/02/05 18:26:51 D287D700 s anti cascading disabled
2012/02/05 18:26:51 D2863700 c client connected to 15050 port
2012/02/05 18:26:51 D2863700 c encrypted newcamd:15050-client 127.0.0.1 granted (user2, au=auto (1 reader))
2012/02/05 18:26:51 D2863700 c user user2 authenticated successfully (generic)
2012/02/05 18:26:51 D2863700 c AU disabled for user user2
2012/02/05 18:26:51 D286F700 r Error processing ecm for caid 0B00, srvid 006F (servicename: 0B00:006F unknown) on reader reader1.
Iemand een idee? Hieronder mijn configuratiebestanden.
Groetjes,
Cedric
cat /etc/oscam/oscam.conf
# main configuration
[global]
nice = -1
WaitForCards = 1
# logging
pidfile = /var/run/oscam.pid
logfile = /var/log/oscam/oscam.log
usrfile = /var/log/oscam/oscamuser.log
cwlogdir = /var/log/oscam/cw
# monitor
[monitor]
port = 8988
aulow = 120
monlevel = 1
# web interface
[webif]
httpport = 8888
httpuser = myusername
httppwd = mypassword
httpallowed = 192.168.31.201
# protocols
[newcamd]
key = 000102030405060708090A0B0C0D
port = 15050@0B00:0E030
# cat /etc/oscam/oscam.server
# reader configuration
[reader]
label = reader1
protocol = mouse
detect = CD
device = /dev/ttyUSB0
group = 1
emmcache = 1,3,2
services = services1
caid = 0B00
mhz = 500
cardmhz = 500
# cat /etc/oscam/oscam.services
# definition of services
# format:
# [name]
# caid=CAID[,CAID]...
# provid = provider ID[,provider ID]...
# srvid = service ID[,service ID]...
[services1]
caid=0B00
provid=0E030
srvid=
# cat /etc/oscam/oscam.user
# user configuration
[account]
user = user1
pwd = password1
monlevel = 0
uniq = 0
group = 1
au = 1
ident = 0B00:0E030
caid = 0B00
# user for group 2 with monitor access, AU enabled
#[account]
user = user2
pwd = password2
monlevel = 0
uniq = 0
group = 1
au = 1
ident = 0B00:0E030
caid = 0B00
Volgende ronde je cardserial wegpoetsen!!!
Kortom, sleutels zijn verlopen. Je hebt dus de afgelopen periode alleen sleutels van je kaart gehaald maar het update proces liep niet.
Nu passen de oude sleutels niet meer en moet je dus eerst de kaart updaten.
Ik weet voor digitenne niet hoe je dat correct moet instellen maar daar moet wel achter te komen zijn met google of wellicht dat iemand anders hier het wel weet.
suc6!
Dikke kans dat hij het gebruik van EMM in cardclient.conf heeft uitgeschakeld.
Probeer dit eens:
newcamd:ipnummervanoscam:15050:1/0B00/0000:user1:password1:000102030405060708090A0B0C0D
Met de 1 (die ik bold heb gemaakt) zet je EMM updates aan.
aangepast door Niels Wagenaar
Woonkamer : Xubuntu 8.04 met VDR 1.7.4 en WinTV NOVA-HD-S2 icm Reel Extension HD.
Slaapkamer : Een MediaMVP icm de vompserver v0.30 VDR plugin.
EMM updates staan aan bij mij in het volgende bestand:
/var/lib/vdr/plugins/sc/cardclient.conf
Ik heb de makkelijke maniet gekozen, en de digitenne kaart in een officiele ontvanger gestoken. Na 15 minuten had ik daar weer beeld, en werkt het in mijn PC ook weer.
Bedankt voor de hulp,
Cedric
