Dit heb ik gevonden op het www.
firstly cacheex should be done with trusted stable peer that have good setup, and it should be done just between 1 card/provider
this is example for canaldigitaal provider:
create cache user:
[account]
user = xxxx
pwd = xxxx
group = 1
uniq = 3
cacheex = 1
allowedprotocols = cccam
caid = 0100
ident = 0100:00006A
cccmaxhops = 0
cccreshare = 0
cccignorereshare = 1
keepalive = 1
now create a reader that connect to your peer
[reader]
label = xxxx
protocol = cccam
device = dns,portnuber
user = xxxx
password = xxxx
cacheex = 1
caid = 0100
ecmwhitelist = 0100@00006A:64
ident = 0100:00006A
group = 1
lb_weight = 500
cccmaxhops = 0
ccckeepalive = 1
cccreshare = 0
audisabled = 1
your peer has to do the same
some options in global:
- cache delay 0
- max cache time 8 > this is specific for cdnl, maybe for some other provider its different but for cdnl it has to be this or it will be unstable
- max cache count 1000
- cacheex wait time 50 > same as max cache time, dont change it for cdnl
and that is it, works for me
SOME POINTERS, with cache line you have to have normal lines too, anticascading MUST be off on cache users
you will get many requests like this:
2012/02/12 19:06:06 89893F8 c xxxx-cache (0100&00006A/51C7/64:4749): rejected peer (51 ms)
(3 of 3)
that is normal, it just means that it didnt find any cache so oscam rejected it
and this is a hit:
2012/03/01 12:08:11 83A7F68 c xxxx (0100&00006A/5212/64:B749): found (62 ms) by xxxx (4 of 4)
