Hoi, I currently have canal digitaal over here in Aberdeen (Scotland) on a 60 cm standard dish with duo lnb. I must admit reception is not that great all the time especially when it's raining. Iam wanting to size up to a 1m dish and get a triple lnb so can get 19,2 23 & 28. Will this work on 1m dish and should this help with the rain issue?
Thanks
Ale
As only one of the LNBs will be in focus in the dish, the other two won´t get the full signal.
So, I would go for 4 feet (about 120 cm.), the rainreserve will also be better.
When you watch following link, you can see for the sats you want to receive:
http://www.satbeams.com/footprints
See almost above and klick on the desired degree i.e. 19.2, 23.5 and 28 degrees.
As there are more sats on one possition, you better check them all.
Make the map a bit bigger and klick between the lines, just there where you live, you now get a baloon with relevent info.
Here another site where you can find the different sats with there positions: http://www.flysat.com/satlist.php
when you click on i.e. Astra 19.2 E, you get a list of frequencies and almost on the right 2C, 1KR etc.
Just click on 2C, 1KR and you´ll get a footprint.
aangepast door Emekli
Vu+ Uno 4K SE en 1TB HDD / Samsung 65'' UHD Smart TV.
Vier schotels, 150, 120, 90 en 120** cm., voor Astra 1 & 3, Hotbird/Eurobird, Türksat,   ** is tijdelijk buiten gebruik.
  • Beheerder
I'm sorry to disappoint you,l but this forum is Dutch language only. You are welcome to read, but you can only post in the Dutch language.
Gast
