Hier onder de commando die gevraagd zijn:
root@vusolo2:~# mount
rootfs on / type rootfs (rw)
ubi0:rootfs on / type ubifs (rw,sync,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=286116k,nr_inodes=71529,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
tmpfs on /media type tmpfs (rw,relatime,size=64k)
/dev/sda1 on /media/hdd type ext4 (rw,relatime,barrier=1,data=writeback)
tmpfs on /var/volatile type tmpfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620)
nfsd on /proc/fs/nfsd type nfsd (rw,relatime)
root@vusolo2:~# free
             total         used         free       shared      buffers
Mem:        572408       202384       370024            0          568
-/+ buffers:             201816       370592
Swap:            0            0            0
Swap:            0            0            0
root@vusolo2:~# free^C
root@vusolo2:~# df -h
Filesystem                Size      Used Available Use% Mounted on
ubi0:rootfs             196.7M     79.7M    117.0M  41% /
devtmpfs                279.4M      8.0K    279.4M   0% /dev
tmpfs                    64.0K         0     64.0K   0% /media
/dev/sda1                 1.8T      1.4T    476.1G  74% /media/hdd
tmpfs                   279.5M    296.0K    279.2M   0% /var/volatile
root@vusolo2:~# ethtool eth0
Settings for eth0:
        Supported ports: [ TP MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Half 1000baseT/Full
        Supported pause frame use: No
        Supports auto-negotiation: Yes
        Advertised link modes:  10baseT/Half 10baseT/Full
                                1000baseT/Full
        Advertised pause frame use: Symmetric
        Advertised auto-negotiation: Yes
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                             1000baseT/Full
        Link partner advertised pause frame use: Symmetric
        Link partner advertised auto-negotiation: Yes
        Speed: 1000Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 3
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: ags
        Wake-on: d
        SecureOn password: 00:00:00:00:00:00
        Link detected: yes
netsh int tcp set global autotuninglevel=disabled
getest op mijn win7 pc -> zelfde
Ik heb ook enkele testen gedaan met flashfxp.
Copieren van de pc naar de vusolo2 gaat wel, al is de snelheid niet alles (gemiddeld 7,94 mb/s)
Copieren van de vusolo2 naar de pc gaat niet, snelheid: blijft hangen op 0 kb/sµ
Ondertussen weer de vusolo2 naar de router (100mb) verplaatsd.
Pc blijft op de switch zitten.
Nieuwe ftp testen
Van PC naar Vusolo2: gemiddelde snelheid 11mb/s (een pak sneller...)
Vusolo2 naar de pc: ook 11mb/s
Die klopt dus wel.
bericht #16 ziet er allemaal fatsoenlijk uit, dus eigenlijk geen issues
blijft de vraag of de router ook een 1000Mbit router is (welke router is het en is de UTP poort snelheid in te stellen?)
zoals je al van Pedro Newbie en >moi< kon lezen is 40~45 MByte/sec mogelijk.
- om te stellen dat iets aan de NIC van de VU+ mankeert moet je toch nog twee tests doen
-a aan je buurman zijn netwerk hangen (zelfde ip range is het makkelijkst / zelfs zonder coax kun je opstarten)
-b met een crossover kabel direkt aan je PC aansluiten
- ervan uitgaande dat het echte cat5 twisted pair kabels zijn (een niet twisted pair levert direct problemen)
als daar dan ook blijkt dat de verbindingsnelheid niet hoger komt dan de genoemde 11MByte/s
zou ik hem onmiddellijk aanmelden voor moederbord vervanging bij de leverancier...
meer kan ik niet helpen van hier uit.
ciao
Minuano
Pat Metheny Group
  • Moderator
crossover kabels zijn van voor 2000 :). Iedere moderne pc / laptop doet dat tegenwoordig zelf.
VU+ Duo4kSe  met VTi    VU+ duo2 met VTi
Triax 78, astra 1,2,3, HB
De router is een 100mb router.
Dus internet connectie zal nooit sneller kunnen dan 100mb.
Maar als de vusolo2 en mijn 2 pc's allemaal op de 1gb switch zitten dan kunnen deze tegen hogere snelheid werken.
Dit is ook wel degelijk het geval als ik van de ene pc naar de andere copieer.
Enkel de vusolo2 doet het niet als ik deze op de 1gb switch, daarmee is het voor mij toch wel duidelijk dat het probleem bij de vusolo2 ligt.
Ik ben blijkbaar ook niet alleen met dit probleem (zie Duits forum).
