gouden Geplaatst: 4 mei 2014 Delen Geplaatst: 4 mei 2014 Hallo, Weet iemand hoe je handmatig nieuwe software op de powercam kunt zetten ? Ik heb er een aantal met versie 3.0 en ik moet naar de 5.0 of hoger Hopelijk kan iemand mij van de juiste informatie voorzien. Groeten, Gouden Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Mimisiku Geplaatst: 4 mei 2014 Delen Geplaatst: 4 mei 2014 One Cam ( Powercam Pro) One Cam ( POWERCAM.PRO) accepts official cards scrambled in : Viaccess, Médiaguard, Irdeto, Conax, Betacrypt and Cryptoworks Menus in English, French, Spanish & Arabic. A REVOLUTION IN LEGAL CARD READING One Cam ( POWERCAM.PRO ) accepts official cards scrambled in : Viaccess, Mediaguard, Irdeto, Conax, Betacrypt and Cryptoworks Menus in English, French, Spanish & Arabic. SMS and MAIL Functions (Available on the next upgrade by Satellite) Application : CAS System compatible with : 1. Conax, 2. CryptoWorks, 3. Irdeto 1+2, 4. Seca 1+2, (Mediaguard) 5. Viaccess 1+2,6. Betacrypt Professional application : POWERCAM.PRO provides access to a full transponder by using a professional card. POWERCAM.PRO is designed to meet worldwide DVB standards. POWERCAM.PRO is addressable. All new HD2.0 software available for download from HOTBIRD now tune to 12.092 H 27500 3/4 This Card reader module accepts all the REGULAR smart cards from TPS, Canal + and Canalsat (French, Italian, Spanish, Polish), ART Europe and Middle East, Digiturc, all the X-rated smart cards (Sex View, Sex View Plus, Don't Panic, In X World, SCT, Extasi TV, Spice Platinum, ...), the Premi*re subscriptions, the Swiss smart card SSR, AB Sat, Dish Asia Network, RTVI Russian, BRTV... Plus there is no need to worry about encryption changes or obsolecence this CAM upgrades on all the systems indicated automatically and monthly or as required from Hotbird - easy to use - 100% reliable with all official cards Up-date by satelliteFrom Hotbird 13 " east On Transponder 69, Frequency 12 092 Polarization Horizontal Symbol rate 27 500 Fec 3/4 New HD2.0 software turns the CAM into a "Super-CAM" Weet alleen niet of dit vanaf de oude 3.0 versie al werkt. Gewoon naar je menu van je CI CAM en daar de OTA update aanvragen. Eerst op bovengenoemde transponder afstemmen. Link naar reactie Delen op andere sites Meer opties om te delen...
Terradon Geplaatst: 5 mei 2014 Delen Geplaatst: 5 mei 2014 Hoi ota werkt niet meer op deze transponder, geen update beschikbaar ze hebben liever dat je de nieuw versie gaat kopen Groetjes............... Link naar reactie Delen op andere sites Meer opties om te delen...
JoeG135 Geplaatst: 23 augustus 2014 Delen Geplaatst: 23 augustus 2014 Hoi ota werkt niet meer op deze transponder, geen update beschikbaar ze hebben liever dat je de nieuw versie gaat kopen Groetjes............... Ok wat kost zoiets? en wat kan je ermee ontvangen? SAB Titan I & Technisat Multytenne Link naar reactie Delen op andere sites Meer opties om te delen...
Johan45 Geplaatst: 30 augustus 2014 Delen Geplaatst: 30 augustus 2014 Misschien werk ota op Hotbird 11296 H 27500 3/4 Hier haalt de ONE Cam zijn updates vandaan. Afstemmen op een kanaal, cam er uit en weer terug plaatsen. De update moet na 10 minuten beginnen. Als dit ook niet werkt is de cam misschien nog bruikbaar voor Digitenne. Vult u rustig aan !!! Link naar reactie Delen op andere sites Meer opties om te delen...
JoeG135 Geplaatst: 31 augustus 2014 Delen Geplaatst: 31 augustus 2014 was in 2010 zo wil alleen weten wat nwe kost en wat je ermee kan zien ? SAB Titan I & Technisat Multytenne Link naar reactie Delen op andere sites Meer opties om te delen...
