Anton48 Geplaatst: 9 oktober 2002 Delen Geplaatst: 9 oktober 2002 Hallo Ik heb dit op internet gevonden maar mijn Engels is er niet na. Kan hier iemand wijs uit en mijn vertellen wat dit inhoud. I recommend to use Fun_6in1_AT90S8515_V3.81+.hex. For Multivision (TPS) ECM-Pids attack we must use Fun_6in1_AT90S8515_V4.10.hex (both flash working OK with Magic Module). For Humax 5400 users is recommended to install new HIC 1.05.00 + CAM TuxOnHumax v2.0 patch and Xamuh_ECMfix_CAMToH20_2109.hdf ECM-Fix ... after that we can see all channels with New or Old CoCo's <img src="/ubbthreads/images/icons/smile.gif" alt="" /> Card type: - Fun2 Card with Fun_6in1_AT90S8515_V4.xx flash - Fun2 Card with Fun_5in1_AT90S8515_V3.xx flash - Ds9v504x Hardware: Humax IRCI-5400(Z) patched with HIC 1.05.00 + CAM TuxOnHumax v2.0 Null-modem cable Software: PMC-EDIT-ToH20.exe This PMC-Table working OK with New and Old CoCo! With this PMC-Table (Xamuh_PMCtable_CAM_ToH2.0_2109.csv) is for: - deactivate two transmitters for automatic Dolby Digital (DD) select (Premiere 1 and 2) - some Canal+ Digitaal (C+ NL) channels (C+ Rood, C+ Blauw, C+16/9, The Studio and X-Zone) - MTV Networks channels (MTV's, VH1's) - Mezzo's and MCM Europe - MTV F and VH1 on Hotbird - some ABsat Hotbird channels forced TPScrypt over Viaccess2 - Eurosport's and Eurosport News's on Hotbird - All Stream forced Irdeto over Seca2 and Time Offset fixed - All TPS including Multivision's forced TPScrypt over the Seca1 ATTENTION: - This PMC-Table working ONLY with HIC 1.05.00 + CAM TuxOnHumax v2.0 (last firmware for Humax 5400) - You must have this channel setting: Antenna 1 = Astra (in Humbox = 0) Antenna 2 = Hotbird (in Humbox = 1) Otherwise you must edit your Antenna settings! Enjoy Groetjes, Anton. Link naar reactie Delen op andere sites Meer opties om te delen...
FredjeV Geplaatst: 9 oktober 2002 Delen Geplaatst: 9 oktober 2002 Er staan meerdere dingen in, in het kort: een filesetje wat anti-attack is voor de magic module, moet wel gebruikt worden met de laatste patch en PMC tabel. Rebox RE8500 V2.11.34 Link naar reactie Delen op andere sites Meer opties om te delen...
