SimonLeBon Geplaatst: 20 september 2018 Geplaatst: 20 september 2018 Als ik zo de berichten lees lullen jullie compleet langs elkaar heen en hebben jullie beiden gelijk. Bij Inverto valt het volgende te lezen: Citaat ENGELS: The IDLU-UST110-CUO1O-32P is a small form factor Unicable2 multiswitch enabling installations with up to 32 satellite receivers over a single cable based on digital channel stacking technology. Digital channel stacking technology applies digital signal processing after wideband Analog to Digital converters (full band capture) to select and reorder transponder channels. Compared with analog channel stacking, which is based on analog frequency translation to fixed frequency slots, the digital channel stacking implementation removes the need of in-band SAW filters, offers a full flexibility of channel selection, supports many more set top boxes through a single coax cable, greatly simplifies installations at subscribers homes all at much lower cost and lower power consumption.Controlled by the connected receivers over EN50494 or EN50607 protocol, the multiswitch will select the desired transponder channel, convert its frequency to the respective User Band frequency and stack it over the Unicable output ports through Digital to Analog converter (also known as ‘Dynamic’ mode).The multiswitch firmware can be configured to deliver a fixed transponder-to-IF frequency mapping (also known as ‘Static’ mode) and line up to 32 transponders (depending on the bandwidth of the desired transponders) over the Unicable output ports. This allows for an unlimited number of receivers to be connected to the switch making MDU installations substantially cheaper and simpler than ever before. The operation mode - dynamic or static - output power level, channel bandwidth, UB numbers, center frequencies and the functionality of each of the output ports can all be programmed as well.The multiswitch receives (and cascades) 4 satellite IF bands/polarities (LV, LH, HV and HH) and Terrestrial VHF/UHF signals. Both Unicable and Legacy output ports combines the Terrestrial signal. The Terrestrial signal is not amplified. The multiswitch is powered over the supplied AC/DC adapter and power inserter device allowing greater flexibility in various installation scenarios. The communication protocol between the multiswitch unit and the connected receivers is based on EN50494 and/or EN50607 and can be defined per User Band allowing operators to support installations consisting of both EN50494-only and EN50607 compatible Next Generation PVRs and HGWs. Citaat DUITS: Der IDLU-UST110-CUO1O-32P ist ein Unicable2 Multischalter mit dem kleinstmöglichen Formfaktor, der Installationen mit maximal 32 Set Top Boxen über ein einzelnes Kabel ermöglicht. Die digitale Channel-Stacking Technologie nutzt schnelle Breitband analog zu digital Konverter und verwendet die digitale Signalverarbeitung, um die gewünschten Transponderkanäle auszuwählen und zu bündeln. Verglichen mit analogem Channel-Stacking, basierend auf analoger Frequenzumsetzung auf feste vorgegebene Frequenzen, benötigt das digitale Channel-Stacking keine Oberflächenwellenfilter, bietet volle Flexibilität bei der Kanalauswahl und unterstützt viel mehr Set-Top-Boxen über ein einzelnes Koaxialkabel und dies bei viel geringeren Kosten und geringerem Stromverbrauch für den Endverbraucher.Gesteuert durch die angeschlossenen Receiver über das EN50494 oder EN50607 Protokoll, wählt der Mutlischalter nun den gewünschten Transponder, konvertiert die Frequenz auf das entsprechende User Band und kombiniert dieses Signal über den Unicableausgang dank des digital zu analog Konverters (auch bekannt als „dynamischer“ Modus).Die Multischalter Firmware kann so konfiguriert werden, dass sie eine fest vorgegebene Transponder zu ZF-Frequenz Zuweisung bietet (auch bekannt als „statischer“ Modus), und so bis zu 32 Transponder (abhängig von der Bandbreite der gewünschten Transponder) über einen Unicable Ausgang ausgibt. Dies ermöglicht es eine unbegrenzte Anzahl von Receivern mit dem LNB zu verbinden, und somit eine Satelliten Wohnanlagen Verteilungen, deutlich günstiger und einfacher als jemals zuvor zu realisieren. Der Betriebsmodus (dynamisch oder statisch), der Signalpegel, die Kanalbandbreite, die Anzahl der Userbands, die Zwischenfrequenzen und ein Antennenjustier-Modus können mittels eines Programmiergerätes* vor Ort konfiguriert und aktualisiert werden.Der kaskadierbare Multischalter verteilt vier Satelliten-ZF-Bänder (L/V, L/H, H/V und H/H) und terrestrische VHF/UHF-Signale. Die Unicable-Ausgänge und die Legacy-Ausgänge werden mit dem terrestrischen Signal kombiniert. Das terrestrische Signal wird nicht verstärkt. Der Multischalter wird durch ein externes Netzteil und den Power Inserter mit Strom versorgt, was eine größere Flexibilität gewährleistet. Die Kommunikation zwischen dem Multischalter und den angeschlossenen Unicablereceivern, erfolgt nach EN50494 und/oder EN50607 und kann je User Band definiert werden und ermöglicht Installationen bestehend aus sowohl nur EN50494-fähigen oder EN50607 kompatiblen PVRs und HGWs der nächsten Generation. Conclusie: Unicable is gebaseerd op digitale multi stacker technologie Met de programmer definieer je de 32 User Bands. Eke ontvanger/aansluitpunt krijgt een stuk frequentie toegewezen, de User Band. In het filmpje krijgt UB 1 1210MHz met een bandbreedte van 30MHz toegewezen. Tussen de werkgebieden zie ik ook nog eens 6MHz ruimte. Fysiek stemt de tuner van de ontvanger dus af op 1210 MHz en de switch verschuift de datastroom van de transponder naar die frequentie. Je kunt met elke ontvanger de 300+ transponders (of hoeveel er ook zijn) ontvangen. Het is alleen zo dat er maximaal 32 verschillende transponders en of tuners tegelijkertijd over een enkele kabel kunnen gaan. De ontvanger geeft nog steeds op welke transponder afgestemd wordt, maar de switch handelt de afstemming van de LNC af. Even googlen brengt deze heldere tekst van Erik Slagter in de Transponder december 2016 naar boven: Citaat SCR is een systeem op zich, het is geen LNB (of een switch). Van SCR heb je twee soorten, "Unicable" oftewel "Unicable 1" en het nieuwere "JESS" wat ook wel "Unicable 2" wordt genoemd . Het idee is hetzelfde, de mogelijkheden zijn verschillend. De basics: je sluit meerdere tuners aan op één kabel (vandaar de naam). Elke tuner krijgt een bepaalde frequentie toegewezen (de "userband": UB). De tuner geeft aan de "outdoor unit" (ODU, dat kan een LNB of een switch zijn, meestal switch) door welke frequentie die wil ontvangen, inclusief polariteit. De ODU zorgt er dan voor dat die bepaalde frequentie op de frequentie wordt doorgegeven die voor die tuner is gereserveerd (UB). De tuner staat dus altijd continu op dezelfde frequentie, de UB voor die tuner, de ODU zorgt ervoor dat de gewenste frequentie daarop terechtkomt. Bij 4 sat posities worden wideband LNB's toegepast die Horizontale en Vertikale polarisatie ontvangen (ipv ook nog eens de lage en hoge band schakelen zoals bij quattro) De widebands ontvangen dus eigenlijk 2x 2 kwadranten.
Tonskidutch Geplaatst: 21 september 2018 Geplaatst: 21 september 2018 dacht dat men het transponder forum niet mag quoten? maar goed dat ik engels en duits lezen kan Thriller Michael Jackson (viespeuk)
