Hiermee heeft zich de vraag over de BETA zowiezo een einde! <img src="/ubbthreads/images/icons/grin.gif" alt="" />
De Firmware is nu per OTA te krijgen
OTA upgrade via Astra is available. (Oct 30 '02)
The default TP is 12603MHz of Astra and the PID input should be 347.
It will take max. 17.5 minutes to upgrade via OTA.
------------- List of Firmwares on Air --------------
--- Newly updated firmwares from the last OTA (7th Oct 2002)
1- TF4000PVR (Appl : 4.57.59, Last update : Oct 28 2002)
2- TF3000COCI (Appl : 3.57.59, Last update : Oct 28 2002)
3- TF4000PVR COCI (Appl : 4.57.59, Last update : Oct 28 2002)
4- TF3000Fi (Appl : 3.57.59, Last update : Oct 28 2002)
5- TF3000CIpro (Appl : 3.57.59, Last update : Oct 28 2002)
6- TF3000CIPpro (Appl : 3.57.59, Last update : Oct 28 2002)
7- TF3000FEi (Appl : 3.57.59, Last update : Oct 28 2002)
8- TF3100FEPpro (Appl : 3.57.59, Last update : Oct 28 2002)
9- TF3100FEi (Appl : 3.57.59, Last update : Oct 28 2002)
Snopper
Xtrend ET9500 met OpenPli 3.0 met Kathrein 90cm (19.2 en 23.5)
Dit is er nieuw in deze versie:
1. IRD status of Oct 28 2002 version
(1) system id : 206
(2) loader version : A3.06
(3) device version : v4.3.60
(4) application version : TF-JPC 4.57.59
(5) last update : Oct 28 2002
2. Improvements of this version
(1) There shall be no problem in descrambling France2/3 in Astra 12515MHz with the Aston CAM.
(2) There was a problem while watching the subtitle with the software teletext. The previous subtitle line was not erased. It is fixed.
(3) The problem of delayed recording with weekly mode is fixed.
(4) When the system records a service with the descrambled format, the system will keep it as the decrambled format even menu, EPG or some other operations except for channel change and time-shift mode.
(5) The overall performance is a little bit enhanced. You can try it with the menu in teletext services.
(6) There was an index number in the date cell of recorded file list when you saved the cut file. It is fixed.
(7) If a recorded file is locked, the image of instant view window will be also locked.
(8) The delayed recording menu is completely changed to VCR style.
(9) The running time of the cut & saved file was not so correct. It is improved.
(10) There is a change in EPG processing scheme. The EPG speed is a little bit faster than the previous version.
(11) There was a problem of marking two events as the current simultaneously in EPG. It is fixed.
