Als ik de reader opstart zie ik dit in het log:
(reader) DELTA [smartreader] creating thread for device TripleP1;Serial:00000cb9
(reader) DELTA [smartreader] Reader initialized (device=TripleP1;Serial:00000cb9, detect=cd, mhz= AUTO, cardmhz=600)
(reader) DELTA [smartreader] card detected
(reader) DELTA [smartreader] ATR: 3B 9F 21 0E 49 52 44 45 54 4F 20 41 43 53 20 56 37 2E 30 9F
(reader) DELTA [smartreader] Effective reader settings mhz =600 F= 558 D= 1 N=0 T=14 inv=0 parity=NONE
(reader) DELTA [smartreader] detect irdeto card
(reader) DELTA [smartreader] Irdeto SC 70 version 2 revision 0, patch level 0
(reader) DELTA [smartreader] caid: 0618, acs: 0.06, country code: NLD
(reader) DELTA [smartreader] providers: 4, ascii serial: ##########, hex serial: ######, hex base: ##
(reader) DELTA [smartreader] Warning: needed try nr 2, next ECM has some delay
(reader) DELTA [smartreader] card system not supported
(reader) DELTA [smartreader] Normal mode failed, reverting to Deprecated Mode
(reader) DELTA [smartreader] Effective reader settings mhz =534 F= 372 D= 1 N=0 T=14 inv=0 parity=NONE
(reader) DELTA [smartreader] active providers: 4 (03fb42,ffffff,ffffff,ffffff)
(reader) DELTA [smartreader] found card system irdeto
(reader) DELTA [irdeto] THIS WAS A SUCCESSFUL START ATTEMPT No  1 out of max allotted of 1
(reader) DELTA [irdeto] entitlements for provider: 1, id: 03FB42
(reader) DELTA [irdeto] chid: 000F, date: 2016/12/20 - 2017/01/04
(reader) DELTA [irdeto] chid: 7FFD, date: 2024/03/22 - 2024/04/01
(reader) DELTA [irdeto] chid: 7FFE, date: 2023/12/09 - 2024/01/08
(reader) DELTA [irdeto] chid: FFD8, date: 2023/10/28 - 2023/11/27
(reader) DELTA [irdeto] chid: 006D, date: 2024/03/21 - 2024/04/21
(reader) DELTA [irdeto] chid: 006E, date: 2024/03/21 - 2024/04/21
(reader) DELTA [irdeto] ready for requests
(reader) DELTA [irdeto] card ejected
oscam.server
[reader]
label                         = DELTA
protocol                      = smartreader
device                        = TripleP1;Serial:00000cb9
caid                          = 0618
boxkey                        = 1122334455667788
rsakey                        = 3C8633A --- Ahum kuch ---  FC599B87D08CEA47BE1B6C76A
force_irdeto                  = 1
detect                        = cd
mhz                           = 600
cardmhz                       = 600
ident                         = 0618:000000
group                         = 7
emmcache                      = 1,3,2,0
blockemm-unknown              = 1
blockemm-g                    = 1
lb_weight                     = 500
dropbadcws                    = 1
auprovid                      = 03FB42
De kaart heeft het toch echt gedaan in deze kaartlezer en met deze config.
Weet iemand of er iets veranderd is?
VU+ Duo
/ Dreambox DM800 / TBS 5925
De Irdeto controlChID’s zijn verlopen. Bij Ziggo kaarten (Delta gebruikt dezelfde kaarten) moeten de Global EMM’s doorgelaten worden.
needsglobalfirst = 1
blockemm-g = 0
9 uren geleden, Mimisiku zei:
blockemm-g = 0
Ik dacht dat het needemmsfirst =1 was, maar dan nog wat heb je daaraan?   Die setting doet niks behalve zorgen dat oscam een melding geeft.
IPTV:  KPN Glas (AoN) 1 Gbit & IPTV KPN plus+ TV box  / Android 4K IPTV box / Kodi & Plex / 100+ TB Storage
Als ik die needsglobalfirst eruit haal is het gedaan met de 0606 kaart van Ziggo. Hij springt dan terug naar mijn basis 0604 kaart...
Maar die globals komen toch wel en zijn niet afhankelijk van die setting.   Met de ORF kaart die ook emm's nodig heeft maakt het absoluut geen verschil.
Als ik weer in Zeeland ben, ga ik het wel proberen.
In de tussentijd doet de andere kaart (ik meen een 0604) het wel.
VU+ Duo
  • 6 maanden later...
Ik heb niet meer getest, maar de 0618 kaart in een Humax gedaan, die redelijk snel beeld gaf.
De 0604-kaart die daar in zat, heeft geen 'needsemmfirst' nodig.
VU+ Duo
