Dr.Matrix nieuwe firmware
Nu te downloaden bij Dreamsatsoft, de nieuwste van Dr, Matrix,
Dit is de readme file,
Hi there!
This is a very-pre-release of my softcam development
for the Dreambox 7000S.
It's mega buggy...but sometimes it actually works <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
The upper-slot can only handle Irdeto smartcards (at
the moment). The channel change time for Irdeto is
very high (you see there is much to improve).
The lower-slot should be able to handle via/seca/nagra
and......cryptoworks should be detected but will not
work at the moment.
There are no outputs for diagnostic / debug...please
wait for next releases...where you can find a
smartcard-menu (I hope)
This version is for testing only and not very useful
for @home-use. You will often see crashes and so on
so your wife will kill you if you put the box in the
living room:)
The remove detection is broken anyway so the card
removal will not work very fine...often only a reboot
helps.
There is no support for the known funcard at all..but
these things come together later....
Please use the ENGLISH Dreamsatsoft forums for
feedback since I can not read nor write German or
Dutch! I won’t be writing but I sure as hell read
them <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Please let me work in peace! No e-mail and no ICQ
available <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
-[Dr.Matrix]-
Natuurlijk een fantastische ontwikkeling maar heeft ie nu de emu software links laten liggen?
Nix mis mee hoor dat die card readers eindelijk daadwerkelijk te gebruiken zijn, zeker als de bugs eruit zijn maar doe mij maar een emu <img src="/ubbthreads/images/graemlins/grin.gif" alt="" />
You cannot ignore that member
heb hem ook al van de ump server afgehaald <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
scam_pre1.rar <<---- is de file naam <img src="/ubbthreads/images/graemlins/laugh.gif" alt="" />
Hmmm... interessant. Ik heb even de image bekeken. Let wel: ik heb hem nog niet getest. Hier volgen mijn bevindingen.
** Wat betreft de drivers **
Er zitten twee nieuwe/onbekende modules in.
ca.o:
Registreert zich op /dev/ca0 en heeft eigenlijk zowat dezelfde functie als zijn eerste sdev.o module. M.a.w. het schrijven van de CW's naar de demuxer descrambler registers.
sci_inf.o:
De lang verwachte driver voor de smartcards. Alleen komt hij uit een onverwachte hoek. Ik vraag me af hoe Dr.Matrix die module heeft vast gekregen <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> . De auteurs van de module zijn: Mike Lepore en Zongwei Liu. Volgens de module info toch. Na het laden van deze server krijg je twee extra devices: /dev/sci/sci0 en sci1. Leuk <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
De dream.o zelf is ook interessant. Ik zie zo niet onmiddellijk op welke versie van dream.o deze is gebaseerd. Wel zie ik dat de descramblers actief zijn en dat recording van encrypted kanalen zou moeten werken.
** Wat betreft de softcam **
Naast een camd in /bin zitten er ook twee extra files: scam0 en scam1. Deze twee worden opgestart in het start_enigma script. Zij bollen dus altijd. De camd is vrij simpel: hij communiceert de boodschappen van enigma door naar de twee scam daemons. Dit gebeurt via /var/tmp/scam0 en 1. Sockets, pipes of files, ik weet het nog niet.
De scam daemons filteren dan de ECM stream uit de TS via filters op demux0 (dit is wat de camd doet in de ucas emu). scam0 communiceert deze ECM's na enige verwerking door naar /dev/sci/sci0. Het zelfde voor scam1. Indien de scam daemon CW's terug krijgt van de smartcard dan schrijft hij deze weg naar /dev/ca0. Uiteraard komt er allemaal veel meer bijkijken dan deze simpele uitleg. Maar het geeft wel een globaal beeld van de werking.
Zo dat is wat ik op eerste zicht zie. Dit lijkt een mooie release voor iemand die een softcam wil. Nice work Dr.Matrix!.
Is er al iemand die deze image heeft getest?
Greetz
Ik wil de versie graag downloaden maar de link bij dreamsatsoft loopt dood. Waar kan ik hem nog vinden.
Satanixx
Vaak weet ik het, maar soms heb ik een zetje nodig. Hobby is Hobby.
2 x dream + 120 Gbit, 2 x humax 5400 en 1 maal philips 6071
Thanx
Inderdaad geen idee wat ik net fout gedaan heb. Heb verder niets veranderd.
Satanixx
hihihi... eerste indruk: druk niet op info! --> Fatal error.. skin property wrap does not exist
hierna reboot.. <img src="/ubbthreads/images/graemlins/smirk.gif" alt="" />
There is nothing wrong with having a strong opinion... if it comes with an open mind!
Ook geen teletext geen game's wel een nieuwe skin.
Zonder cam geen beeld.
@SATFREAKHOLL,
in de Readme1.txt staat het volgende :
helps.
Dus nu is de vraag heb je gereboot of heb je de kaart in en uit het slot gehaald want dat werkt niet.
Laat even wat weten, groeten,
