Ongeloofelijk als het waar is MANGO ICE module
MANGO ICE the smart alternative
Since the introduction of digital video formats there have been numerous techniques to protect the digital content of the data. The drawback of such a vast amount of encoding and decoding techniques is the enormous investments in the aforementioned decoders.
If you look at watching television today, you have a number of options. The best quality is watching via satellite. This is however also the most complicated way. On the satellite are about 8 different encryption techniques in use. These are for viewers of the channels, not for professional use.
If you want to watch programs from different providers you need more than one SET TOP BOX or a set top box with open access, like common interface.
BUT TIMES ARE CHANGING………………….
Why buy what you don’t need, for the MANGO ICE is here.
The MANGO ICE is an INTELLIGENT DECRYPTION ENGINE, something the world hasn’t seen before.
Almost all encryption techniques are based on the same principal, you hide the access information in the data stream, without actual encoding the data stream. This means that almost all channels are not encoded at all, but only protected by a digital access system.
The MANGO ICE is therefore not a decoding tool, but only an automatic key finder.
How does it work? Rather simple, all the machine is doing is checking the data stream and trying to find the raw audio and video data. When the machine has found the needed data it can filter out all other data and select the encryption data. This encryption data will be analyzed so that the key can be found. The ICE does not alter the data stream, he only completes it. That is what makes the ICE unique. This also means that the ICE uses NO card.
DOES IT WORK?………….
After long and strenuous testing it is now almost perfect and works on most of the mayor European providers.
The ICE works on IRDETO, BETACRYPT, VIACCESS, NAGRAVISION, CRYPTOWORKS, MEDIAGUARD and CONAX. The only system that does not work at this moment is VIDEOGUARD.
HOW DOES IT WORK? …………….
The use of the ICE is extremely easy, all you need to do is to insert the ICE in the set top box and wait. The ICE wil go to work at the moment you boot up your set top box. It however will need some time to find all the needed data, this can take up to 24 hours. Once the ICE has found the data he will store the needed information in its memory. Once the ICE is initialized on all the providers you want to watch, he will memorize the information in his non-volatile memory. It is advised to run the initializing process every month.
Updating the ICE is not needed, but can be done in the future. Updating the ICE is done in a docking station.
WHY IS THERE AN ICE? ………..
We think that information should be free accessible to everybody and not only those who can afford it. This also was the foundation of the treaty of ROME, where the freedom of information was assured to all people living in the EU.
All mayor satellite TV operators in the EU are violating this treaty. We want free access to information simply because the way we think is being manipulated by the monopolizing satellite operators. This must come to an end.
IS IT LEAGALL? …………….
As far as we know there is NO transgression against any law. Therefore it is NOT illegal. Based on the same freedom of information act we have the right to receive all information from the sky. We do NOT alter the information we receive and we do NOT use any apparatus to bypass encryption data. All we do is join the pieces of a puzzle. In the process all data we receive is usable in a normal CI set top box.
DISCLAIMER……………..
Unfortunately we have a disclaimer as well. We can not guarantee that the ICE will work on all digital set top boxes with common interface. Neither can we guarantee that there will be no legal steps against us, for the statement about the use of the ICE is based on our interpretation of the law. We can not be held responsible for any damage caused by the ICE.
Dit is oud nieuws of beter gezegd geen nieuws
Dit is een leuke 1 april grap over een CI-module <img src="/ubbthreads/images/graemlins/biggthumpup.gif" alt="" />
Voor een niet leuke 1 april grap met een CI-module
kan men terecht bij veel te veel postings op dit board <img src="/ubbthreads/images/graemlins/shocked.gif" alt="" /> <img src="/ubbthreads/images/graemlins/mad.gif" alt="" />
Met vriendelijke groeten <img src="/ubbthreads/images/graemlins/wink.gif" alt="" />
sattaz
Na 1 april 2003 geloof ik ECHT niemand meer op dit board. <img src="/ubbthreads/images/graemlins/tongue.gif" alt="" />
Maar je weet maar nooit, doe mij maar zo'n MANGO ICE.
Groeten Johan. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Vult u rustig aan !!!
