EL PIÑO Geplaatst: 26 april 2003 Delen Geplaatst: 26 april 2003 Welke zijn dat dan? Dat weet ik niet. Na jaren zonder, ben ik toch weer van plan een schotel aan te schaffen. Link naar reactie Delen op andere sites Meer opties om te delen...
bistro Geplaatst: 27 april 2003 Delen Geplaatst: 27 april 2003 NDS's VideoGuard will initially work in parallel to the existing system using a Simulcrypt headend. This is essential to avoid disruption to the service and in order to start creating a more secure platform. The full rollout will include a total migration of existing digital subscriber set-top boxes to NDS's CA via an over-the-air download. Link naar reactie Delen op andere sites Meer opties om te delen...
bistro Geplaatst: 27 april 2003 Delen Geplaatst: 27 april 2003 Actually it don´t, if you don´t have Viasat as a provider, you don´t have to worry, and the rest of this page have proberbly nothing interresting for you to read. If you have Viasat as a provider, then we will say that we actually don´t know what to expect at this moment. (As soon as we know more on this issue, we will put the info on this page) We do have some ideas thoug, about what will happen for people who have Viasat as a provider, here is what we think will happen: 1. Nokia 9802/9902 and other recivers with embedded Viaccess, can´t be updated to handle NDS-Videoguard. The NDS syetem is build in a way so some acitve parts have to be inside the reciver or the system won´t work, this is made by NDS for security reasons. (Old Viaccess recivers don´t have these parts inside) 2. When Viasat switched from Analog to Digital transmissions, they continued to send a few channels in analog, actually they are still transmitting a few channels in analog - we can hope that they also decide to transmit a few channels in Viaccess when they swtich over to NDS-Videoguard. We think that they proberbly will continue to transmit some of the channels that are cheap and with a lot of commercials on them, like the channel TV3 and 3+. 3. Viasat will proberbly give away free recivers for the subcribers with the most expencive supcriptions, the "gold-subcription", or else Viasat will proberbly make a solution, so you can rent or buy a NDS-reciver cheap. I need a reciver right now what shall i buy ?? 1. As long as we don´t know precise what Viasat are going to do when they change to NDS-Videoguard, the only thing we can say is "Don´t buy a reciver with embedded Viaccess". 2. Canal Digital (an other Nordic provider) have at the moment no public known plans about switching to an other system, Canal digital are using a crypt-system right now called CONAX. Link naar reactie Delen op andere sites Meer opties om te delen...
EL PIÑO Geplaatst: 27 april 2003 Delen Geplaatst: 27 april 2003 Nederlandse postings worden op prijs gesteld. Als je zelf goed Engels kan (zoals jij dus blijkbaar, maar ook ik) lijkt het wel alsof dat geen probleem is, maar zeker niet iedereen kan Engels. Na jaren zonder, ben ik toch weer van plan een schotel aan te schaffen. Link naar reactie Delen op andere sites Meer opties om te delen...
bistro Geplaatst: 27 april 2003 Delen Geplaatst: 27 april 2003 weet ik pino,maar kijk eens naar het uur dat ik dit gevonden heb.Had nog geen zin in vertaling. Link naar reactie Delen op andere sites Meer opties om te delen...
Tonskidutch Geplaatst: 30 mei 2003 Delen Geplaatst: 30 mei 2003 viasat blijft de komende 12 (ja misschien wel 18) in multicrypt zenden viaccess en nds videoguard Ola <img src="/ubbthreads/images/graemlins/smirk.gif" alt="" /> Barricades - The Blanc Mass Recording Editors Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 30 mei 2003 Delen Geplaatst: 30 mei 2003 Ik heb op een Noors board gelezen dat enkel de film kanalen overgaan naar een soort videoguard. De hardware wordt dan aangepast via de software. TV3 etc... zouden gewoon viacces blijven. Maar ja zeker is het natuurlijk nooit. Link naar reactie Delen op andere sites Meer opties om te delen...
Tonskidutch Geplaatst: 30 mei 2003 Delen Geplaatst: 30 mei 2003 de reden daarvoor is (multicrypt) dat de meest gebruikte receiver een Force is welke nu volgens een soort convenant / overeenkomst tussen Force.tv en Viasat omgebouwd moet worden middels de software (als dat al mogelijk blijkt) en het team wat daar aan werkt heeft een planning gemaakt om dat voor elkaar te krijgen. tussentijds zijn er overigens ook al met PACE afspraken gemaakt voor de eigen viasat box welke Pace zou moeten gaan leveren. er zijn zeker 300.000 Force gebruikers die bij direkte wissel en een legaal abonnement niet meer zouden kunnen kijken. Dat zou Viasat heel wat abootjes kosten. dus is besloten om in multicrypt te zenden nieuwe leden moeten een pace kopen oude leden mogen viaccess blijven gebruiken. cheers Barricades - The Blanc Mass Recording Editors Link naar reactie Delen op andere sites Meer opties om te delen...
Bigfoot Geplaatst: 30 mei 2003 Delen Geplaatst: 30 mei 2003 Wordt de Force dan omgebouwd dat ie zowel Viaccess als Videoguard aankan? Want de Rus kanalen blijven weer Viaccess natuurlijk. Link naar reactie Delen op andere sites Meer opties om te delen...
Tonskidutch Geplaatst: 30 mei 2003 Delen Geplaatst: 30 mei 2003 dat zal natuurlijk wel moeten... maar als er al conax en viaccess in past zal een nds videoguard er ook nog wel bij passen... dacht ik zo... de nieuwe modellen hebben 8Mb flash memory dus daar kan heel wat software in. de oude modellen hebben 4Mb en of dat genoeg is moet blijken. overigens waren ze al twee jaar geleden aan het kijken of de seca op die oude modellen erbij zou kunnen, maar dat is vanwege licentie problemen gestopt. maar het zal voor nds videoguard wel zo zijn dat je een unieke receivercode krijgt die per afstandbediening kan worden geactiveerd als je betalend abonnee bent (wel te verstaan) dus receiverserialnumber-kaartnummer-klantnummer en effe bellen met viasat om je afstandsbedieningscode te krijgen. dus we zullen maar niet te veel hoop hebben op een gratis NDS'je in ons boxje <img src="/ubbthreads/images/graemlins/grin.gif" alt="" /> cheers Barricades - The Blanc Mass Recording Editors Link naar reactie Delen op andere sites Meer opties om te delen...
Bigfoot Geplaatst: 31 mei 2003 Delen Geplaatst: 31 mei 2003 Het zou wel aardig zijn als je dan met een Sky abokaartje ook de Engelse kanalen kan kijken... Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 9 juni 2003 Delen Geplaatst: 9 juni 2003 Is het niet mogelijk,dat viassat een afwijkende nds codering gaat gebruiken? Te denken valt hier bij dat de duitse ook een afwijkende irdeto norm gebruikt. Ik denk niet dat je met een eventuele nds viassat ontvanger sky zal kunnen gaan kijken en omgekeerd. Volgens mij kunnen ze verschillende nds coderingen gaan gebruiken waardoor de ene nds ontvanger de andere nds coderingen niet kan zichtbaar maken ook al heb je een abonnementskaartje die open staat.Ik denk dat sky dat niet zal toelaten dat je met een viassat nds ontvanger en een sky kaartje sky zal kunnen kijken.wat denken jullie hierover? Link naar reactie Delen op andere sites Meer opties om te delen...
Murdock Geplaatst: 9 juni 2003 Delen Geplaatst: 9 juni 2003 Is het niet zo dat bij Sky het Boxnr en kaartnummer gekoppeld zijn? Receiver: VU+ Solo 4K Schotel: Digiality 85cm multifocus, 4x Triax PLL LNB, 4x Digiality DiSEqC 1.0 High-Iso (Astra1-2-3, Hotbird) Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 10 juni 2003 Delen Geplaatst: 10 juni 2003 Citaat: Is het niet zo dat bij Sky het Boxnr en kaartnummer gekoppeld zijn? murdock, Inderdaad de kaart is gekoppeld aan je ontvanger. groet alphasat. Link naar reactie Delen op andere sites Meer opties om te delen...
rudolfdebeer Geplaatst: 10 juni 2003 Delen Geplaatst: 10 juni 2003 @pino Natuurlijk is dit een nederlands board. Maar toch vraag ik me af??? Buitenlandse kanalen kijken en geen engels, duit, frans, italiaans, russissch, noors, zweeds of deens verstaan? Beetje twee-slachtig??? De meeste ontvangers hebben geeneens een nederlands OSD. Dit is trouwens typisch geen board voor alleen nederlandstaligen met een seca-box en een canal+kaartje. De meesten willen de hele wereld zien en horen tot de laatste exoot uit Kazachstan. Dat is hier de sport. Studeren op die paar exoten en hoe ze te zien. Heeft veel educatieve waarde. Groeten, Rudolf Retired, when I get the Urge to Work, I lay Down until the Urge passes. Link naar reactie Delen op andere sites Meer opties om te delen...
