dit zou hem dan moeten worden de tuner voor het digitenne verhaal
Consumenten Richtprijs 169,00
Brainwave
Digi 2000 T NL
Brainwave Digital Satellite Receiver
for reception of Free To Air and
pay-TV with common interface
Basic Specifications
• DVB terrestrial receiver compliant to EN 300 744
• Common Interface
• Embedded Conax CAS
• Active and passive aerial support
• VHF/UHF support
• Re-Modulator output adjustable (PAL)
• Video and Audio out via SCART
• Audio out (left/right) via RCA
• Fast channel search
• Reed-Solomon decoding support (EN 300 744)
• Automatic FEC selection (1/2, 2/3, 3/4, 5/6, 7/8)
• MPEG2 Transport Stream support: ISO/IEC 13818-1
• DVB-Video/-Audio support: ISO/IEC 13818-2, -3
• Update-Over-Air
• Silver slim line housing w/o branding
RF Specification
• QPSK / QAM16/64 demodulation compliant to DVB terrestrial standard EN 300 744
• COFDM 2k and 8k
• VHF/UHF support (47…862 MHz)
• 7/8 MHz channel bandwidth
• Guard Interval Modes: 1/32, 1/16, 1/8, 1/4 active symbol duration
• Fast PLL tuning speed: step size 62,5 kHz / 166,67 kHz
Input / Output specification
• SCART out:
CVBS, Y/C, RGB video out
switching signal: 0 / 6 / 12V
• RCA out:
Audio left & right via adapter cable
• RF input:
connector IEC60169-2 female
termination 75 Ù
Return Loss: min. 6 dB (75 Ù)
Active aerial current support maximal 100 mA
• RF Re-Modulator
connector IEC60169-2 male
adjustable Re-Modulator channel 21 - 69
output termination 75 W
• Loop-Through active if receiver is switched on and Re-Modulator switched off
• Front smart card reader for embedded CAS support
STB Mode Functionality
• Pay- and Free-TV & -Radio terrestrial DVB reception
• Multi language support
• Easy-to-use graphical user interface
• Context referred help function
• Automatic and manual channel scan
• Separated program list for TV and radio
• Up to 2000 programs storable
• Advanced Electronic Program Guide (EPG)
• Short EPG (present/following)
• Aspect ratio: 4:3, 16:9, 2.21:1 (PAL only)
• PAL and NTSC support
• Teletext re-insertion (VBI)
• Excellent quality monitoring to avoid video and audio artefacts if to weak signal
• Excellent help to adjust indoor aerial for maximum input RF signal level
Power Supply
• Power supply 230VAC/50Hz to 12VDC/1.6A
• Operation power consumption less 12 W
• Stand-By power consumption less 2 W Accessories
Accessories
• Receiver (ca. 250 x 140 x 32 [mm])
• Power Supply 230VAC/50Hz to 12VDC/1.6A
• SCART/SCART cable 1m
• Coax cable 1.5m
• Audio cable 3.5mm stereo plug to 2 RCA out
• Remote Control
• 2 Batteries (for remote control)
Standard and Regulation Compliance
• DVB terrestrial standard EN 300 744
• MPEG2 Transport Stream support to ISO/IEC 13818-1
• DVB-Video/-Audio support to ISO/IEC 13818-2, -3
• Teletext in VBI according to ETS 300 472
• Safety and EMC regulations: EN 55013, EN 55020 and EN 60065
Er komen er nog meer aan hoor....
Receiver: VU+ Solo 4K
er zijn er nog wel meer hoor. kijk maar eens in de Digitenne 'draad' . <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Triax TDS 88cm / Inverto Black Ultra LNB / Alsat Dark Motor / Dreambox DM800HD+DM7000 knutselbak
