Gast Geplaatst: 14 april 2003 Delen Geplaatst: 14 april 2003 sorry about the English, i can read but not write Dutch. I've just brought a pace dsr610 back from South Africa and have the following questions/problems: 1.can the S.A. box flashed with the Dutch software? 2.I can't change the satellite setup because a PIN code is required and standard combinations like 1,2,3,4 or 0,0,0,0 don't work, any ideas? kind regards tim Link naar reactie Delen op andere sites Meer opties om te delen...
Tull Geplaatst: 14 april 2003 Delen Geplaatst: 14 april 2003 1. There is Dutch software, I am not sure if you can flash Dutch over English. Take a look at the Huts site for the 610 firmware. 2. Code in the Dutch software is 9949. You could give it a try... Good luck, Tull Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 14 april 2003 Delen Geplaatst: 14 april 2003 9949 works!! Many Thanks, Tull tim Link naar reactie Delen op andere sites Meer opties om te delen...
