Dream Multimedia ERROR UC0 -- Help !!!
Help !!! <img src="/ubbthreads/images/graemlins/confused.gif" alt="" /> Mijn Dreambox wil niet meer !
Foutmelding: ERROR UC0
Aan de specialisten onder ons, ik heb hier een logging gemaakt van het opstarten van de Dreambox, mogelijk dat er iemand iets uit kan halen !!!
Dreambox D M7000
DM7000 BIOS v.2.0 (Sep-22-2002)
RAM: 48 MB, LCD: OK, CPU 252 MHz, BUS 63 MHz
--- Device Configuration ---
Power-On Test Devices:
000 Disabled System Memory [RAM]
002 Disabled Ethernet [ENET]
Boot Sources:
001 Enabled Application in Flash [FLASH]
002 Enabled Ethernet [ENET]
local=0.0.0.0 remote=255.255.255.255 hwaddr=000934001fec
003 Enabled Serial Port 1 [s1]
Baud = 9600
Update Flash : Disabled
Automatic Boot: Enabled
1 - Toggle Power-On Tests
2 - Change a Boot Device
3 - Change IP Addresses
4 - Ping test
5 - Change Baud Rate for S1 Boot
D - Display Configuration
0 - Exit Menu and Boot Application
->0
trying 1 (1)
Booting from [FLASH] Application in Flash...
loaded at: 00500000 006111F8
relocated to: 00400000 005111F8
board data at: 0050E128 0050E168
relocated to: 00404BDC 00404C1C
zimage at: 00405118 0050D410
avail ram: 00512000 02000000
Linux/PPC load: console=null root=/dev/mtdblock/0 ro console=ttyS0,115200 root=/dev/mtdblock/0
Uncompressing Linux...done.
Now booting the kernel
Linux version 2.4.20 (ghost@client) (gcc version 3.2.1) #24 Mon Mdr 17 00:08:28 CET 2003
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: console=null root=/dev/mtdblock/0 ro console=ttyS0,115200 root=/dev/mtdblock/0
Console: colour dummy device 80x25
Calibrating delay loop... 251.49 BogoMIPS
Memory: 29812k available (1880k kernel code, 588k data, 92k init, 0k highmem)
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
POSIX conformance testing by UNIFIX
PCI: Probing PCI hardware
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
OCP uart ver 1.6.2 init complete
Starting kswapd
Journalled Block Device driver loaded
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
JFFS2 version 2.1. © 2001 Red Hat, Inc., designed by Axis Communications AB.
i2c-core.o: i2c core module
i2c-dev.o: i2c /dev entries driver module
i2c-core.o: driver i2c-dev dummy driver registered.
i2c-proc.o version 2.6.1 (20010825)
pty: 256 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
ttyS00 at 0xe0040000 (irq = 20) is a 16550A
ttyS01 at 0xe0000000 (irq = 21) is a 16550A
ttyS02 at 0xe00e0000 (irq = 31) is a 16550A
Uniform Multi-Platform E-IDE driver Revision: 6.31
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
IBM IDE ocp driver version 2.2
ide_redwood: waiting for drive ready......Drive spun up
loop: loaded (max 8 devices)
smc91111.c:v1.0saa 08/22/01 by Daris A Nevil (dnevil@snmc.com)
eth0: SMC91C11xFD(r:1) at 0xc3081300 IRQ:28
INTF:<NULL> MEM:8192b NOWAIT:0 ADDR 00:09:34:00:1f:ec
SCSI subsystem driver Revision: 1.00
kmod: failed to exec /sbin/modprobe -s -k scsi_hostadapter, errno = 2
dreambox: flash mapping: 800000 at 7f800000
disable flash VPP
Creating 5 MTD partitions on "DreamBOX rev3+":
0x00000000-0x00600000 : "DreamBOX cramfs"
0x00600000-0x007c0000 : "DreamBOX jffs2"
0x007c0000-0x00800000 : "DreamBOX OpenBIOS"
0x00000000-0x007c0000 : "DreamBOX (w/o bootloader)"
0x00000000-0x00800000 : "DreamBOX (w/ bootloader)"
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb-ohci.c: USB OHCI at membase 0xc3886000, IRQ 18
usb-ohci.c: usb-ocp, builtin
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 2 ports detected
usb.c: registered new driver hiddev
hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik <vojtech@suse.cz>
hid-core.c: USB HID support drivers
usb.c: registered new driver dc2xx
dc2xx.c: v1.0.0:USB Camera Driver for Kodak DC-2xx series cameras
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
IBM On-chip iic (i2c) algorithm module 2002.30.04
iic_ibmocp_init: IBM on-chip iic adapter module
i2c-dev.o: Registered 'IBM OCP IIC adapter' as minor 0
i2c-core.o: adapter IBM OCP IIC adapter registered as adapter 0.
i2c-dev.o: Registered 'IBM OCP IIC adapter' as minor 1
i2c-core.o: adapter IBM OCP IIC adapter registered as adapter 1.
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Mounted root (cramfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 92k init
init started: BusyBox v0.60.5 (2003.03.08-01:32+0000) multi-call binary
JFFS2: Erase block at 0x00000000 is not formatted. It will be erased
JFFS2: Erase block at 0x00020000 is not formatted. It will be erased
JFFS2: Erase block at 0x00040000 is not formatted. It will be erased
JFFS2: Erase block at 0x00060000 is not formatted. It will be erased
JFFS2: Erase block at 0x00080000 is not formatted. It will be erased
JFFS2: Erase block at 0x000a0000 is not formatted. It will be erased
JFFS2: Erase block at 0x000c0000 is not formatted. It will be erased
JFFS2: Erase block at 0x000e0000 is not formatted. It will be erased
JFFS2: Erase block at 0x00100000 is not formatted. It will be erased
JFFS2: Erase block at 0x00120000 is not formatted. It will be erased
JFFS2: Erase block at 0x00140000 is not formatted. It will be erased
JFFS2: Erase block at 0x00160000 is not formatted. It will be erased
JFFS2: Erase block at 0x00180000 is not formatted. It will be erased
JFFS2: Erase block at 0x001a0000 is not formatted. It will be erased
Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes
mount: Mounting /dev/mtdblock/1 on /var failed: Invalid argument
Using /lib/modules/2.4.20/misc/fb.o
Warning: loading fb will taint tfb: loaded
he kernel: non-GPL license - proprietary
See http://www.tux.org/lkml/#export-tainted for information about tainted modules
Warning: loading fb will taint the kernel: forced load
Console: switching to colour frame buffer device 90x36
pfb: fb0: Pallas frame buffer device
Using /lib/modules/2.4.20/misc/sdev.o
Warning: loadingsdev: Loading sdev module
sdev will taint the kernel: forced load
Using /lib/modules/2.4.20/misc/dream.o
Warning: loading dream will taint the kernel: forced load
i2c-core.o: driver DreamBOX frontprocessor registered.
i2c-core.o: client [fp] registered to adapter [iBM OCP IIC adapter](pos. 0).
fp: attaching fp at 0xee to adapter IBM OCP IIC adapter
error occured: 43
incomplete xfer
nack
event: init ...
CICCR:00800088
core: Loaded IBM STB04xxx core driver
write 1 event's ...
registering device.
demux: inited
xp0_clk_stop
[XP1] Init
[XP1] 896KBytes used for Queues
i2c-core.o: driver stv0299 DVB demodulator registered.
error occured: 73
incomplete xfer
nack
lost arb
id is wrong (0 != 0xa1)
error occured: 73
incomplete xfer
nack
lost arb
lcd.o: LCD driver (KS0713) module
Using /lib/modules/2.4.20/misc/avs.o
Warning: loading avs will taint i2c-core.o: driver DreamBOX AV-Switch registered.
the kernel: non-lost arb
GPL license - prlost arb
oprietary
SeeOops: kernel access of bad area, sig: 11
NIP: C0170598 XER: 20000000 LR: C562B114 SP: C1DE7E40 REGS: c1de7d90 TRAP: 0800 Tainted: PF
MSR: 00009030 EE: 1 PR: 0 FP: 0 ME: 1 IR/DR: 11
DEAR: 0000002C, ESR: 00000000
TASK = c1de6000[28] 'insmod' Last syscall: 128
last math 00000000 last altivec 00000000
PLB0: bear= 0x00000000 acr= 0x00000000 besr= 0x00000000
PLB0 to OPB: bear= 0x00000000 besr0= 0x00000000 besr1= 0x00000000
GPR00: C562B114 C1DE7E40 C1DE6000 00000000 C562B910 00000008 00000000 05050328
GPR08: 40000300 C5630000 00000000 C0170588 82004022 10075ED4 00000000 00000000
GPR16: 00000000 00000000 00000000 00000000 00009032 01DE7F40 C1DE7EA8 10087FE0
GPR24: C1DA1000 C02FCE00 C0210000 C0215C68 FFFFFFEA C0230000 C562BAD0 00000000
Call backtrace:
C562B5CC C562B114 C562B758 C0013DF0 C000279C 10021518 10022974
10040E0C 10040A04 0FF426A0 00000000
Warning: loading avs will taint the kernel: forced load
Segmentation fault
insmod: ca.o: no module by that name found
insmod: sci_drv.o: no module by that name found
Warning: loading fb will taint the kernel: non-GPL license - proprietary
insmod: A module named fb already exists
Warning: loading sdev will taint the kernel: forced load
insmod: A module named sdev already exists
insmod: A module named dream already exists
Warning: loading avs will taint the kernel: non-GPL license - proprietary
insmod: A module named avs already exists
umount: /var: Invalid argument
<img src="/ubbthreads/images/graemlins/confused.gif" alt="" /> MvG Dream4ever
<img src="/ubbthreads/images/graemlins/crazy.gif" alt="" /> Heb na het doorspitten van het forum inderdaad eerdere meldingen van dit ERROR UC0 - probleem gevonden en heb alle vermelde stappen geprobeerd maar het wil gewoon niet lukken !!! <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
MvG Dream4ever
Nog meer info voor de Uco lijders:
UC0 is shown when the components in the box can't communicate with each other on the I²C bus.
Try to unplug the box from the mains. At least 1-2 minutes. Thereafter the problem should be solved. If not, repeat this for one or two more times.
Other possibility, if the above doesn't help:
Try to use DreamUP (not DreamUpLAN) to flash the newest image. You can find this program, the newest image and a description on http://www.dm7000.de
(You need a serial null-modem cable to use this program.)
Greetz van Jonas
Pioneer 506-XDE plasma met Yamaha YSP-1000 Surround receiver; DM800; DM7000; DM500; Iphone 3G(S); iMAC 2.7i met SNOW leopard OSX; PS3 en WII; Apple TV
Terug naar de dealer lijkt mij het is toch garantie... <img src="/ubbthreads/images/graemlins/biggthumpup.gif" alt="" />
Tja het is niet anders <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
AZbox ME 0,4 Tb en Dreambox 500HD met 1,5Tb + netwerk schijven
Popcorn Hour A-110 met 1 Tb Eminent 7071 met 500GB
Dreambox 500HD met 1,5Tb aan netwerk schijven
PS3- nick name JOSSIE-NL
