Gast Geplaatst: 13 augustus 2001 Geplaatst: 13 augustus 2001 I upgraded my Irdeto CAM to 4.70SE. No problems. Then I tried with 2-016. The result is the same! My CAM is still an Irdeto 4.70SE. Ird1.06.exe works perfectly during the upgrade but my receceiver tell me that I still have Irdeto 4.70SE on my CAM! Should I try with freecam2-015?<BR>Any ideas?
Gast Geplaatst: 19 augustus 2001 Geplaatst: 19 augustus 2001 Probably you had the wrong file, which someone had given the name freecam. Normally the freecam2-016 works fine.
Gast Geplaatst: 20 augustus 2001 Geplaatst: 20 augustus 2001 ...most likely you forgot to change the "ird106.ini" in the windows directory.<BR>Open the ini-file (notepad), change the bin setting to the file you downloaded (place this file also in the win-dir!) and save it.<BR>Then put in your CI-module and start "ird106.exe" (also in win-dir) and your CI-module will update correctly.<P>Greetz, CK
Ron Geplaatst: 21 augustus 2001 Geplaatst: 21 augustus 2001 This board is Dutch only! Sorry. Please ask your question at the Int. Board.<P>@aan alle leden:<BR>Ik wil jullie verzoeken niet op vragen te antwoorden in de Engelse taal. Verwijs deze mensen a.u.b. naar het internationale board.<P>Groetuh,<P>Toxic[Q]<p>[ 21-08-2001: Message edited by: Toxic[Q] ]
