Bigfoot Geplaatst: 1 juli 2003 Delen Geplaatst: 1 juli 2003 Ik kom er niet helemaal uit, kun je met het volgende apparaat nou ook de FTA zenders bekijken via de USB poort of is het alleen bedoeld voor internet? Pent@U+ Citaat: [uSB Interface] USB interface : Version 1.1 compliant Maximum USB bus speed : 12 Mbps [Tuner] Input terminal : F-type 75 Ohm Receiving frequency : 950 ~ 2150 MHz tuning range Input level : -65 ~ -25 dBm [QPSK and FEC] Symbol rate : 1~45 Msps Viterbi decoding : 1/2, 2/3. 3/4, 5/6, 7/8 and Auto ReedSolomon decoding : 204, 188, T = 8 Deinterleaving : Interleaving depth = 12 [LNB Control] LNB supply voltage : 13 V or 18 V DISEqC : 1.0 Antenna and LNB control : 22 KHz tone Max. LNB supply current : 400 mA with short circuit and surge protection [Demultiplexing] Max. no. section filtering : 32 PIDs Engine : RISC engine Buffer memory : 2 MByte DVB descrambler Streams capture : PES and TS Date rate : 60 Mbps Syntax Error : CRC or Parity [status Monitoring] Real time data transfer rate Antenna signal strength Signal lock status Display current channel name [s/W and H/W Capabilities] Easy to install USB Plug & Play 12Mbps USB maximum bus speed Antenna signal strength Signal lock status LED RX/TX status LED S/W upgrade throught the Internet Channel database update through Internet Real time data transter rate UDP/TCP/IP protocol LLC SNAP Unicast and multicast MAC filtering PID filters for data stream 8 PIDs simultaneous filtering Download firmware Support Windows 98/2000 Fixed key CAS Common interface option available [Processor] CPU : RISC CPU Working memory : 8 MByte Transport buffer : 2 MByte [Environmental] Operating temperature : 0¡Æ C to 50¡Æ C Storage temperature : -55¡Æ C to 85¡Æ C Humidity (Operating) : 0 % to 90 % [Dimension] 210 x 180 x 40 mm [security] Conditional access ready Fixed key CAS [Demux] PID filters for data stram : 8 PIDs simultaneous filtering Descrambler : DVB descrambler [Operating system] Windows 98,SE,ME : Now Windows 2000 : Now Windows XP: Now Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 1 juli 2003 Delen Geplaatst: 1 juli 2003 @Bigfoot, Volgens de website wel hoor! <img src="/ubbthreads/images/graemlins/biggthumpup.gif" alt="" /> Er staat: "The Pent@ U+ is cost effective,easy to install, Plug and Play standalone satellite to USB receiver designed for full DVB compliant satellite network. There is no need to open the PC cover. Just plug in USB cable for access to digital satellite service." Vrij (en kort door de bocht) vertaald dus: Het is een gemakkelijk te installeren satellietontvanger. Je hoeft de pc er niet voor open te maken. Gewoon de USB kabel aansluiten om toegang te krijgen tot digitale satellietdiensten. Met vriendelijke groeten <img src="/ubbthreads/images/graemlins/wink.gif" alt="" /> sattaz Link naar reactie Delen op andere sites Meer opties om te delen...
Bigfoot Geplaatst: 1 juli 2003 Auteur Delen Geplaatst: 1 juli 2003 [citaat... Plug and Play standalone satellite to USB receiver designed for full DVB compliant satellite network. Toch als je dit leest kan het ook zijn dat bedoeld wordt dat het een receiver is voor digitale services van satelliet naar usb, dat hoeft nog geen TV zenders te zijn. Link naar reactie Delen op andere sites Meer opties om te delen...
GENE Geplaatst: 3 juli 2003 Delen Geplaatst: 3 juli 2003 K'dacht dat DVB stond voor Digital Video Broadcasting. ofwel tv zenders..... <img src="/ubbthreads/images/graemlins/confused.gif" alt="" /> Koekje erbij ???? Link naar reactie Delen op andere sites Meer opties om te delen...
