er is op de korea site nieuwe firmware beschikbaar, dit zijn de wijzigingen
1. IRD status of Aug 25 2003 version
(1) System ID : 406
(2) Device Version : v5.1.30
(3) Application Version : TF-NPC 5.10.40
(4) Last Update : Aug 25 2003
2. Improvements of this version
(1) The command of DiSEqC 1.1 was not issued in case of service change with P+/P- keys.
It is fixed.
(2) The popup message while moving dish will be kept till channel locking.
(3) The system halted when the prompt box of parental pincode shows.
It is fixed.
(4) The bootup time is much shortened, especially in case of many files in HDD.
(5) You can select the satellite with 'Sat' key in service list.
(6) There was a flickering problem in the copy function even with the normal speed.
It is fixed.
(7) The SPDIF audio will be muted when you execute 'Pause'.
(8) The audio dropout in AC3 track is fixed.
(9) The audio problem is much improved.
- The dropout in ORF service is fixed.
- There was a muting problem in some sound tracks at the services of Viasat.
It is also fixed.
- No audio in right channel at some services is fixed.
(10) A scroll bar is added in the service list.
You can estimate the current position.
Ook is er een nieuwe versie van Altair 1.10 beschikbaar en nieuwe USB drivers:
Revision history
2003.08.25
(1) Altair_v1.100.exe
- Popup menu is modified.
- Some minor bugs are fixed.
- Some messages are added.
Revision history
2003.08.26
(1) TfBulk.inf and TfBulk.sys
- improved the management of PC memory
Greetz.
Renzie
3x VU+ Uno 4K met Open Pli, 1x Zgemma h2h ,  Mag 256 iptv, Samsung 59" 1080p plasma met Yamaha RX-V381en Boston Acoustics A26-A23 en Mcenter speakers, 2x Apple TV 3, Rasperry Pi XBMC,  Synology 213+ Nas met 2x 3TB WD Red.
Wordt toch echt tijd dat ik mijn 4000 maar eens aan de kant zet en een 5000 ga kopen. Ik zie heel interessante prijzen voorbij komen.
Heb em nu ook live gezien en het is een wondermooi apparaat......
Al iets verder met het USB naar HD zetten van films etc. ? Ben juist erg benieuwd naar DIE functie ivm. branden naar DVD.
Staat een hele mooie FAQ hierover op die steeds meer bekender wordende bekende site ....hoe zeg ik dit nu weer zeg.....
Satwatcher
