4in1 switsch tesamen met diseq 1.2 rotor in combo
Voor wie dit interesseerd, neem ik aan dat hij de engelse taal voldoende machtig is want anders had hij zo´n complexe sat-installatie niet in zijn bezit of in de planning staan. Bovendien heb je internet. Het gaat over combineren van 4in1 switches met zo´n dise1.2/usals rotor. Ervoor/erna/maakt niet uit??
Greetz,
Rudolf
Dear Mr. Rudolf de Beer,
Thank you for your interest in SPAUN electronic products.
The commands to switch the Relays (DiSEqC 1.0 or 2.0)
are not the same as the commands for the DiSEqC Motor (DiSEqC 1.2).
Our Relays doesn’t switch if you send them DiSEqC 1.2 commands.
If you use the SAR 411 F you have to put the DiSEqC Motor at input 1.
And you have to program your Receiver to switch to DiSEqC A before they send the rotor commands.
We know only one Receiver that can handle this exotic combination.
http://www.digenius.de/index_en
If you tried other Receivers we are very interested in the results of these tests.
If you have further questions you can contact me direct at: kkiefer@spaun.de
Best regards
Klaus Kiefer
Technische Hotline
SPAUN // electronic GmbH & Co. KG
Byk-Gulden-Str. 22
D-78224 Singen
Tel: +49 (7731) 8673 - 18
Fax: +49 (7731) 8673 - 28
eMail: kkiefer@spaun.de
Visitenkarte: http://www.spaun.de/html/klaus_kiefer.html
Hompage: http://www.spaun.de/
-----Ursprüngliche Nachricht-----
Von: Elisa Alonso Suarez [mailto:ealonso@spaun.de]
Gesendet: Mittwoch, 27. August 2003 08:21
An: Klaus Kiefer
Betreff: WG: 4in1 diseq switch usable for diseq 1.2 motor control
Elisa Alonso Suárez
Export Department
Spaun electronic GmbH & Co.KG
E-mail:ealonso@spaun.de
Telephone: +49 (0)7731/8673-14
Fax: +49 (0)7731/8673-498
More information about our company is available under the site www.spaun.de
Von: Eric Spaun [mailto:espaun@spaun.de]
Gesendet: Montag, 25. August 2003 08:17
An: Anwander
Betreff: Fw: 4in1 diseq switch usable for diseq 1.2 motor control
----- Original Message -----
To: espaun@spaun.de
Sent: Sunday, August 24, 2003 1:40 PM
Subject: 4in1 diseq switch usable for diseq 1.2 motor control
Dear Mr. Spaun,
Spaun411 4in1 diseq2.0 switch capable of controlling several diseq 1.2 motors STAB-Italia or Moteck SG2100
at the same time by one diseq 1.2/USALS receiver?
The question not specific related to the spaun411 is roaming around the dutch sat4all board internet forum for quite some time already.
I decided to forward the question to Spaun as a leading manufacturer of sat switch gear. Maybe that Spaun has an answer to the problem.
Many people want to point several fixed sat dishes at several sats and at least one diseq 1.2/usals rotor in the setup.
Favourable setups:
Dual LNB feed 80 cm dish at Astra/Hotbird
80 cm dish single LNB at Hispasat
Motorized dish with 80/60 cm driven by a Stab Italia or Moteck rotor to watch the Astra 2 and 3, Turksat, Sirius, Telecoms and Telstar sats.
The fixed dish setup is to ensure fast zapping.
Now several 4 in 1 sitches can only be introduced in the circuit after the diseq 1.2 rotor resulting in problems of automated control of said rotor. It should be favorable that the lnb of the motorized dish is selected before the motor starts turning. Personally I own a Neuling 4in1 switch not capable of the selection proces so I have to first adress the rotor then the switch.
Your product or R&D department has an solution to this may be?
Regards,
Rudolf de Beer
Retired, when I get the Urge to Work, I lay Down until the Urge passes.
Rudolf, volgens mij doe ik dit ook al met mijn Humax 5400Z. De vaste schotel ( 4 LNB ) is voorzien van een doodgewone 4-in,1-uit DiSeqC switch van het merk Visiosat.
3 van de 4 LNB in de vaste schotel zitten op 1,2,en 3 van de Switch. De STAB HH120 motor zit gewoon op de 4e ingang van de switch. De Humax is wel voorzien van de ToH 3.1 software waarmee je zelfs 4 DiSeqC motors gelijktijdig kan laten werken aan 1 ontvanger.
Wilhelm <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
DM7020S/160gbHDD + DM800/250gbHDD + Visiosat G3D (13,0/19,2/23,5/28,2 ) in cascade met de Triax TD110 + STAB HH120. Schwaiger SF 9000 Satfinder Plus.
bij mij draait deze configuratie met mijn dreambox, een motech motor, een 4/1 switch en nog 3 lnb's op een vaste schotel.
VU+ Duo met 750GB Harddisk
dreambox 7250 met 320GB Harddisk
dreambox 7000s met 200GB Harddisk
2x dreambox 500s
WaveFrontier T90
West-Vlaanderen - Belgie
