kartami Geplaatst: 28 september 2003 Auteur Delen Geplaatst: 28 september 2003 beste Ronald zie de gegevens van de DB Dreambox DM7000 loaded at: 00500000 006061F8 relocated to: 00400000 005061F8 board data at: 00503128 00503168 relocated to: 0040555C 0040559C zimage at: 00405A98 00502280 avail ram: 00507000 02000000 Linux/PPC load: console=none root=/dev/mtdblock/0 console=ttyS0,115200 Uncompressing Linux...done. Now booting the kernel Linux version 2.4.19-rc3 (tmbinc@stb4500) (gcc version 3.2) #106 Mon Oct 14 15:3 1:39 CEST 2002 On node 0 totalpages: 8192 zone(0): 8192 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: console=none root=/dev/mtdblock/0 console=ttyS0,115200 Console: colour dummy device 80x25 Calibrating delay loop... 251.49 BogoMIPS Memory: 29896k available (1856k kernel code, 536k data, 84k init, 0k highmem) Dentry cache hash table entries: 4096 (order: 3, 32768 bytes) Inode cache hash table entries: 2048 (order: 2, 16384 bytes) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes) Page-cache hash table entries: 8192 (order POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket OCP uart ver 1.5 init complete Starting kswapd devfs: v1.12a (20020514) Richard Gooch (rgooch@atnf.csiro.au) devfs: boot_options: 0x1 Installing knfsd (copyright © 1996 okir@monad.swb.de). JFFS version 1.0, © 1999, 2000 Axis Communications AB JFFS2 version 2.1. © 2001, 2002 Red Hat, Inc., designed by Axis Communications AB. i2c-core.o: i2c core module i2c-dev.o: i2c /dev entries driver module i2c-core.o: driver i2c-dev dummy driver registered. i2c-proc.o version 2.6.1 (20010825) pty: 256 Unix98 ptys configured Serial driver version 5.05c (2001-07-08) with no serial options enabled ttyS00 at 0xe0040000 (irq = 20) is a 16550A ttyS01 at 0xe0000000 (irq = 21) is a 16550A ttyS02 at 0xe00e0000 (irq = 31) is a 16550A Uniform Multi-Platform E-IDE driver Revision: 6.31 ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx IBM IDE ocp driver versi ide_stb04xxx: waiting for drive ready......Drive spun up hda: Maxtor 6Y120L0, ATA DISK drive ide0 at 0xc307d1f8-0xc307d1ff,0xc307d1f6 on irq 25 hda: 240121728 sectors (122942 MB) w/2048KiB Cache, CHS=238216/16/63, UDMA(33) Partition check: /dev/ide/host0/bus0/target0/lun0: p1 RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize loop: loaded (max 8 devices) smc91111.c:v1.0saa 08/22/01 by Daris A Nevil (dnevil@snmc.com) eth0: SMC91C11xFD(r:1) at 0xc3083300 IRQ:28 INTF:<NULL> MEM:8192b NOWAIT:0 PPP generic driver version 2.4.2 PPP Deflate Compression module registered PPP BSD Compression module registered Linux video capture interface: v1.00 dreambox: flash mapping: 800000 at 7f800000 Using buffer write method Creating 5 MTD partitions on "DreamBOX rev3+": 0x00000000-0x00600000 : "DreamBOX cramfs" 0x00600000-0x007c0000 : "DreamBOX jffs2" 0x007c0000-0x00800000 : "DreamBOX OpenBIOS" 0x00000000-0x007c0000 : "DreamBOX (w/o bootloader)" 0x00000000-0x00800000 : "DreamBOX (w/ bootloader)" IBM On-chip iic (i2c) algorithm module 2002.30.04 iic_ibmocp_init: IBM on-chip iic adapter module i2c-dev.o: Registered 'IBM OCP IIC adapter' as minor 0 i2c-core.o: adapter IBM OCP IIC adapter registered as adapter 0. i2c-dev.o: Registered 'IBM OCP IIC adapter' as minor 1 i2c-core.o: adapter IBM OCP IIC adapter registered as adapter 1. NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP, IGMP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 2048 bind 4096) NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. IPv6 v0.8 for NET4.0 IPv6 over IPv4 tunneling driver NET4: Ethernet Bridge 008 for NET4.0 VFS: Mounted root (cramfs filesystem) readonly. Mounted devfs on /dev Freeing unused kernel memory: 84k init serial console detected. Disabling virtual terminals. init started: BusyBox v0.61.pre (2002.05.26-17:53+0000) multi-call binary fb: loaded Console: switching to colour frame buffer device 90x36 pfb: fb0: Pallas frame buffer device load fp i2c-core.o: driver DreamBOX frontprocessor registered. i2c-core.o: client [fp] registered to adapter [iBM OCP IIC adapter](pos. 0). fp: attaching fp at 0xee to adapter IBM OCP IIC adapter error occured: 43 incomplete xfer nack load info load event event: init ... load denc load ci load ir demux core core: Loaded IBM STB04xxx core driver load mpeg write 1 event's ... load audio load dvbdev load dvb registering device. demux demux: inited xp0_clk_stop xp [XP1] Init [XP1] 896KBytes used for Queues pvr ist da doch was mit 13 load stv0299 i2c-core.o: driver stv0299 DVB demodulator registered. i2c-core.o: client [stv0299] registered to adapter [iBM OCP IIC adapter](pos. 1) . registering frontend... already got one. i2c-core.o: driver Mitel tuner driver registered. i2c-core.o: client [DBox2 Tuner Driver] registered to adapter [iBM OCP IIC adapt er](pos. 2). load lcd lcd.o: LCD driver (KS0713) module i2c-core.o: driver DreamBOX AV-Switch registered. i2c-core.o: client [avs] registered to adapter [iBM OCP IIC adapter](pos. 3). avs: attaching avs at 0x94 to adapter IBM OCP IIC adapter error occured: 43 incomplete xfer nack VFS: Can't find ext2 filesystem on dev ide0(3,1). cramfs: wrong magic Unable to identify CD-ROM format. JFFS: Trying to mount a non-mtd device. reiserfs: checking transaction log (device 03:01) ... Using r5 hash to sort names hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [50331648 37 0x0 SD] vs-2180: finish_unfinished: iget failed for [50331648 37 0x0 SD] hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-5360: reiserfs_delete_solid_item: could not delete [-1 37 0x1001 DIRECT] due to fix_nodes failure vs-15011: reiserfs_release_objectid: tried hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [50331648 37 0x0 SD] vs-2180: finish_unfinished: iget failed for [50331648 37 0x0 SD] hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-5360: reiserfs_delete_solid_item: could not delete [-1 37 0x1001 DIRECT] due to fix_nodes failure vs-15011: reiserfs_release_objectid: tried to free free object id (37) hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat da [50331648 37 0x0 SD] vs-2180: finish_unfinished: iget failed for [50331648 37 0x0 SD] hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-5360: reiserfs_delete_solid_item: could not delete [-1 37 0x1001 DIRECT] due to fix_nodes failure vs-15011: reiserfs_release_objectid: tried to free free object id (37) hda: dma_intr: status=0x51 { DriveReady SeekComplete hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [50331648 37 0x0 SD] vs-2180: finish_unfinished: iget failed for [50331648 37 0x0 SD] hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 11776877 vs-5360: reiserfs_delete_solid_item: could not delete [-1 37 0x1001 DIRECT] due to fix_nodes failure vs-15011: reiserfs_release_objectid: tried to free free object id (37) hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [50331648 37 0x0 SD] vs-2180: finish_unfinished: iget fai hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-5360: reiserfs_delete_solid_item: could not delete [-1 37 0x1001 DIRECT] due to fix_nodes failure vs-15011: reiserfs_release_objectid: tried to free free object id (37) hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [50331648 37 0x0 SD] vs-2180: finish_unfinished: iget failed for [50331648 37 0x0 SD] hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-5360: reiserfs_delete_solid_item: could not delete [-1 37 0x1001 DIRECT] due to fix_nodes failure vs-15011: reiserfs_release_objectid: tried to free free object id (37) hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [50331648 37 0x0 SD] vs-2180: finish_unfinished: iget failed for [50331648 37 0x0 SD] hda: dma_intr: status=0x51 { DriveReady SeekComplet hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-5360: reiserfs_delete_solid_item: could not delete [-1 37 0x1001 DIRECT] due to fix_nodes failure vs-15011: reiserfs_release_objectid: tried to free free object id (37) hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 1177 vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [50331648 37 0x0 SD] vs-2180: finish_unfinished: iget failed for [50331648 37 0x0 SD] hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-5360: reiserfs_delete_solid_item: could not delete [-1 37 0x1001 DIRECT] due to fix_nodes failure vs-15011: reiserfs_release_objectid: tried to free free object id (37) hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [50331648 37 0x0 SD] vs-2180: finish_unfinished: iget failed for [50331648 37 0x0 SD] hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-5360: reiserfs_delete_solid_item: could not delete [-1 37 0x1001 DIRECT] due to fix_nodes failure vs-15011: reiserfs_release_objectid: tried to free free object id (37) hda: dma_intr: status=0x51 { DriveReady SeekComplete Error } hda: dma_intr: error=0x40 { UncorrectableError }, LBAsect=117768777, sector=1177 68776 end_request: I/O error, dev 03:01 (hda), sector 117768776 vs-13070: reiserfs_read_inode2: i/o failure occurred trying to find stat data of [50331648 37 0x0 SD] vs-2180: finish_unfinished: iget failed for [50331648 37 0x0 SD] LED tv 60 inch Dreambox 8000 en 4 x Dreambox 800 Link naar reactie Delen op andere sites Meer opties om te delen...
Ronaldd Geplaatst: 28 september 2003 Delen Geplaatst: 28 september 2003 Je harde schijf doet gek. Kan je deze eruit halen en dan kijken of hij dan goed opstart. Ik zag ook nog een melding over je cramfs. Het zou kunnen dat na verwijderen van shijf de DB nog steeds niet goed op start, als dat zo is wil je dan de zelfde procedure herhalen zonder harde schijf. Ronald My DM(800|7025) is Ronaldd powered Link naar reactie Delen op andere sites Meer opties om te delen...
kartami Geplaatst: 28 september 2003 Auteur Delen Geplaatst: 28 september 2003 ok Ronald ga het zo doen mn adsl verbinding ligt er af en toe uit probeer zo terug te zijn ik hou je op de hoogte. anders ff stuur ik je een pm ok LED tv 60 inch Dreambox 8000 en 4 x Dreambox 800 Link naar reactie Delen op andere sites Meer opties om te delen...
SunnyHighway Geplaatst: 28 september 2003 Delen Geplaatst: 28 september 2003 Citaat: Je harde schijf doet gek. Kan je deze eruit halen en dan kijken of hij dan goed opstart. Ik zag ook nog een melding over je cramfs. Het zou kunnen dat na verwijderen van shijf de DB nog steeds niet goed op start, als dat zo is wil je dan de zelfde procedure herhalen zonder harde schijf. Ronald Ik had exact hetzelfde. De Maxtor 6Y120L0 en het reiserfs filesystem gaan om een voor mij onbekende reden niet echt lekker samen. In no-time had ik ook bad blocks. De hd was notabene hagelnieuw. Een "check" van de hd leverde geen oplossing Sinds ik de Maxtor 6Y120L0 met het ext3 filesystem heb voorzien was ik van dit probleem af. Still dreaming about the box..... Link naar reactie Delen op andere sites Meer opties om te delen...
kartami Geplaatst: 28 september 2003 Auteur Delen Geplaatst: 28 september 2003 ja yes hij werkt weer alleen heb ik de Maxtor eruit moeten halen dus nu ff opnieuw flashen en alles terug zetten allemaal bedankt ga het hopelijk nu weer doen LED tv 60 inch Dreambox 8000 en 4 x Dreambox 800 Link naar reactie Delen op andere sites Meer opties om te delen...
