Gast Geplaatst: 30 oktober 2003 Delen Geplaatst: 30 oktober 2003 Dear all, Please tell me why the firmware from atsat.be is not working on my Xtreme Hornet? When I download it all works well but when it needs to restart it does not initialize. Please tell me how to do this. I still have the standart original firmware in my xtreme so mabe it has to do with the upgrade. Also when I put the settings list in the xtreme it gives me an error. I think it has to do with the atsat firmware because it does not work so maybe when the firmware is correctly loaded it will work. Please advice. Xtreme Hornet skycrypt and MM cam. Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 31 oktober 2003 Delen Geplaatst: 31 oktober 2003 The xtreme hornet has a very different hardware, so the atsat firmware does not work as these are compatible with the normal xtreme's. For the hornet is different firmware available. Link naar reactie Delen op andere sites Meer opties om te delen...
