van het duitse dreamsatsoft board:
DreamBouquets changelog
version beta 1.2.0.0
- New feature compare added
Compare your opened services (trigger is your panel on the right side) with other services on your harddisk/dreambox. The dialogbox will show you all new and all obsolete services. You could import a new service or you could remove a existing obsolete service from your services.
SPECIAL-FEATURE:
You'll get the same difference dialogbox with all previous contents when you select the <show differences ...> menu and cancel the following folder-selection dialog.
- New feature edit channel properties added
Some channel properties can be modified (only for advanced user!)
- New feature show corresponding service
You could select a service of your created list and it will show you the corresponding service on the right side. The extended info-field on the bottom shows you the detailed data of the service. Special interest could be the original service-name, if you renamed your own service.
- Full implementation of service-renaming
Now you could rename services of your own created bouquet list. Also it is possible to lock or unlock each name to prevent overwriting through dreambox.
- New feature save before quitting added
Before quitting the application a dialogbox will popup and asks you about the data state. As a matter of course only on changed data this feature takes effect.
- New feature tv and radio tab added
On the left screen area you could switch between a tv and radio tab. The right screen area shows only the relevant services-types depends on left tab.
- Improved language support
Many labels are revised. Now the labels are better matching with the labels on the dreambox (software enigma ver. 1.06) All labels are translated - contextmenu, description bar, properties menu, ect.
- Bugfix switching between services/default-bouquets
Your last opened default-bouquet or the default-bouquet of a selected service is marked. Doubleclick on a service will open its default-bouquet.
- Bugfix moving multiple channel-items
When you moving multiple channels, the move order respectively the new channel order should be correct.
- Bugfix loading bouquets
Now it should be irrelevant whether you load a bouquets description file which were saved in UNIX or WINDOWS file format. (carriage return, line feed )
- Bugfix showing default-bouquet in bouquet/provider screen
The description bar shows you the default bouquet name for each service. Also when you select a channel on the left screen area.
Hemertje.Dreambox Webmaster
Sat-nerds Moderator
Plinux Member
