spirit_rules Geplaatst: 14 april 2004 Delen Geplaatst: 14 april 2004 1530 and 1630 faster then 1430 - because in 1430 used DRAM memory and in 1530, 1630 SDRAM memory. Also in 1430 CPU ST5510 and in 1350 and 1630 CPU STi5512 - but they all 60 MHZ -- only STi5512 have additional posibilities. In 1530 and 1630 main board the same - difference between them: that in 1530 more flash memory (2MB+1MB) and in 1630 only (2MB) We have service manual for TS5 - 1530 with shematics. But all 1430 1530 1630 have demodilator TDA 8083 - so low and high SR don't work - only from 8000 to 32000. In 1730 demodulator is STV299B - to it can receive SR from 1000 to 45000.. In 1730 CPU is also STi5512, but this box used shared SDRAM so it is slower even 1430 model. 1330 model based on ST20TP2BX50 - run on 50 MHZ - used slow 50 ns DRAM memory - as result slower then 1730 and others - in this model demudulator L64724 but using external filters - so L64724 should work fine with SR 1000-45000 only with internal filters - as a result of combination L64724 and external filters this box have problems with low SR - it work from SR 2500, but not very stable. 1230 model based on ST20TP2B40 - run on 40 MHZ - used even slower 70ns DRAM - I don't test this box, but it should be very slow. Don't know about demodulator. Met dank aan Dynamit [color:"blue"] Spirit_rules [/color] ------------------------------------------------- Open Firmwarmware Multi taal_171005_0430 Member van het Openfirmware Team Link naar reactie Delen op andere sites Meer opties om te delen...
joop1966 Geplaatst: 16 april 2004 Delen Geplaatst: 16 april 2004 klopt het zoals ik lees dat je met de 17x de feeds op 51xx en 6116 kan kijken maar met de 14 en 15 weer niet ?? die gaan van 8000 of heeft die waarde er weer niks mee te maken dreambox 500hd op een triax 110cm met rotordreambox 800-c dreambox800se-c dreambox500-s dreambox500-c Link naar reactie Delen op andere sites Meer opties om te delen...
spirit_rules Geplaatst: 17 april 2004 Auteur Delen Geplaatst: 17 april 2004 Ik heb geen ervaring met feeds. je zou het kunnen proberen. Wat dynamit had geschreven is het wel mogelijk [color:"blue"] Spirit_rules [/color] ------------------------------------------------- Open Firmwarmware Multi taal_171005_0430 Member van het Openfirmware Team Link naar reactie Delen op andere sites Meer opties om te delen...
joop1966 Geplaatst: 26 april 2004 Delen Geplaatst: 26 april 2004 Na veel leeswerk en informatie bij een 1730 kenner kwam ik er dus achter dat er met een 1730 wel feeds kan vangen dus kan ik binnenkort op zoek gaan naar een 1730 waar een jtag ingebouwd is (voor feeds in viacces enz )ik bezit nu 2x een 100nl2 Met een 1430 lukt het dus niet ik heb het getest met 10a 15 versies software van nieuw naar oud dreambox 500hd op een triax 110cm met rotordreambox 800-c dreambox800se-c dreambox500-s dreambox500-c Link naar reactie Delen op andere sites Meer opties om te delen...
